    MM Not Displaying after update
    20 Posts 2 Posters 3.7k Views 2 Watching
      Achilles
      Hello, I attempted to update my MagicMirror today via a git pull, and ever since then, my MM will not display. Here is the Log:
      pi@raspberrypi:~ $ cd MagicMirror
      magicmirror@2.16.0 start /home/pi/MagicMirror
      electron js/electron.js
      /home/pi/MagicMirror/node_modules/electron/index.js:14
          throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
          at Module._compile (internal/modules/cjs/loader.js:654:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
          at Function.Module._load (internal/modules/cjs/loader.js:498:3)
          at Module.require (internal/modules/cjs/loader.js:598:17)
      Thanks.
        sdetweil @Achilles
        @achilles and u did npm install after the pull?
          Achilles @sdetweil
          @sdetweil Yes. I read that a little bit after I did the pull, so, could the issue be that I didnt do it right after? I did try to run MM again before I read that you needed to do the install…
            sdetweil @Achilles
            @achilles sometimes the module need refresh too…
            AND
            we have been having a bunch of module failures because we removed a couple dead libraries that modules didn’t document they used
            So, where u start MM
            npm start
            or pm2 (if pm2 then use the command pm2 logs --lines=100)
            look at the startup messages and see if u see
            module not found
              Achilles @sdetweil
              @sdetweil I executed that command, and it returned a LOT of results.
              pi@raspberrypi:~ $ pm2 logs --lines=100
              PM2        | [2021-08-08T22:29:56.400Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:29:56.447Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:29:59.262Z] PM2 log: App [mm] with id [0] and pid [855], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:29:59.268Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:29:59.281Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:01.122Z] PM2 log: App [mm] with id [0] and pid [932], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:01.127Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:01.138Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:02.980Z] PM2 log: App [mm] with id [0] and pid [962], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:02.984Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:02.995Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:04.800Z] PM2 log: App [mm] with id [0] and pid [992], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:04.805Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:04.816Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:06.749Z] PM2 log: App [mm] with id [0] and pid [1010], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:06.753Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:06.764Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:08.579Z] PM2 log: App [mm] with id [0] and pid [1040], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:08.586Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:08.598Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:10.468Z] PM2 log: App [mm] with id [0] and pid [1070], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:10.473Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:10.484Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:12.511Z] PM2 log: App [mm] with id [0] and pid [1088], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:12.514Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:12.525Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:14.368Z] PM2 log: App [mm] with id [0] and pid [1128], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:14.371Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:14.381Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:16.296Z] PM2 log: App [mm] with id [0] and pid [1158], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:16.300Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:16.311Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:39.892Z] PM2 log: App [mm] with id [0] and pid [1188], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:39.895Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:39.906Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:41.774Z] PM2 log: App [mm] with id [0] and pid [1208], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:41.779Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:41.789Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:43.634Z] PM2 log: App [mm] with id [0] and pid [1226], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:43.637Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:43.648Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:45.549Z] PM2 log: App [mm] with id [0] and pid [1259], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:45.553Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:45.563Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:47.471Z] PM2 log: App [mm] with id [0] and pid [1289], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:47.476Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:47.487Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:47.852Z] PM2 log: Stopping app:mm id:0
              PM2        | [2021-08-08T22:30:47.936Z] PM2 log: App [mm] with id [0] and pid [1313], exited with code [0] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:48.032Z] PM2 log: pid=1313 msg=process killed
              PM2        | [2021-08-08T22:30:48.037Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:48.048Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:49.923Z] PM2 log: App [mm] with id [0] and pid [1334], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:49.928Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:49.938Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:51.823Z] PM2 log: App [mm] with id [0] and pid [1352], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:51.826Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:51.839Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:53.696Z] PM2 log: App [mm] with id [0] and pid [1382], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:53.701Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:53.711Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:55.542Z] PM2 log: App [mm] with id [0] and pid [1400], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:55.546Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:55.562Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:57.487Z] PM2 log: App [mm] with id [0] and pid [1430], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:57.492Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:57.502Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:30:59.380Z] PM2 log: App [mm] with id [0] and pid [1460], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:30:59.384Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:30:59.394Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:01.224Z] PM2 log: App [mm] with id [0] and pid [1478], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:01.227Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:01.238Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:03.115Z] PM2 log: App [mm] with id [0] and pid [1508], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:03.118Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:03.128Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:04.939Z] PM2 log: App [mm] with id [0] and pid [1538], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:04.943Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:04.952Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:06.819Z] PM2 log: App [mm] with id [0] and pid [1556], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:06.822Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:06.832Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:08.698Z] PM2 log: App [mm] with id [0] and pid [1586], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:08.701Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:08.712Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:10.517Z] PM2 log: App [mm] with id [0] and pid [1604], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:10.520Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:10.530Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:12.460Z] PM2 log: App [mm] with id [0] and pid [1634], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:12.464Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:12.474Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:14.300Z] PM2 log: App [mm] with id [0] and pid [1664], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:14.304Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:14.318Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:16.267Z] PM2 log: App [mm] with id [0] and pid [1682], exited with code [1] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:16.274Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
              PM2        | [2021-08-08T22:31:16.285Z] PM2 log: App name:mm id:0 online
              PM2        | [2021-08-08T22:31:17.278Z] PM2 log: Stopping app:mm id:0
              PM2        | [2021-08-08T22:31:17.350Z] PM2 log: App [mm] with id [0] and pid [1718], exited with code [0] via signal [SIGINT]
              PM2        | [2021-08-08T22:31:17.443Z] PM2 log: pid=1718 msg=process killed
              0|mm       |
              0|mm       | > magicmirror@2.16.0 start /home/pi/MagicMirror
              0|mm       | > electron js/electron.js
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       |
              0|mm       | /home/pi/MagicMirror/node_modules/electron/index.js:14
              0|mm       |     throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
              0|mm       |     ^
              0|mm       |
              0|mm       | Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
              0|mm       |     at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
              0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
              0|mm       |     at Module._compile (internal/modules/cjs/loader.js:654:30)
              0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
              0|mm       |     at Module.load (internal/modules/cjs/loader.js:566:32)
              0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
              0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:498:3)
              0|mm       |     at Module.require (internal/modules/cjs/loader.js:598:17)
              0|mm       |     at require (internal/modules/cjs/helpers.js:11:18)
              0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              0|mm       | npm ERR! code ELIFECYCLE
              0|mm       | npm ERR! errno 1
              0|mm       | npm ERR! magicmirror@2.16.0 start: `electron js/electron.js`
              0|mm       | npm ERR! Exit status 1
              0|mm       | npm ERR!
              0|mm       | npm ERR! Failed at the magicmirror@2.16.0 start script.
              0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              0|mm       |
              0|mm       | npm ERR! A complete log of this run can be found in:
              0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_10_490Z-debug.log
              0|mm       |     ^
              0|mm       |
              0|mm       | npm ERR!
              0|mm       |
              0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_12_433Z-debug.log
              0|mm       |     ^
              0|mm       |
              0|mm       | npm ERR!
              0|mm       |
              0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_14_271Z-debug.log
              0|mm       |     ^
              0|mm       |
              0|mm       | npm ERR!
              0|mm       |
              0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_16_238Z-debug.log
              Is this trying to find a needle in a haystack?
                sdetweil @Achilles
                @achilles (a lot or lines ) aka 100
                So, this is another case where to update didn’t work well… as electron didn’t get upgraded, but messed up …
                SO…
                ugly recovery
                rename the MagiMirror/modules/default folder to default2
                rename the MM folder to something else
                install MM again
                (Use my script) see https://github.com/sdetweil/MagicMirror_scripts
                verify it works
                then copy the savedMagicMirror/modules folder over the MagicMirror folder
                cp -r -p ~/oldMMname/modules ~/Magicmirror/modules
                and then copy your old config,js to the new MM/config folder
                test it out
                Now, its still possible to have the module not found problem.
                I am going to bed now, but in case
                if u find module not found, take the name (valid-url, request) and do npm install ??? while in the MM folder
                my upgrade script MIGHT have helped avoid all this… (I say might, cause I haven’t seen it myself, but I never upgrade manually)
                A 3 Replies Last reply Reply Quote 0
                  Achilles @sdetweil
                  @sdetweil Thanks, I am doing this now. Will respond back when I finish…
                    Achilles @sdetweil
                      Achilles @sdetweil
                      @sdetweil Thank you so much for your help on this. I ran your script, and the MagicMirror was working minus my modules, of course. I copied over my config file, and only three of my modules displayed. I rebooted my raspberry pi, and then MagicMirror would not display at all. Here are the logs:
                      Use `pm2 show <id|name>` to get more details about an app
                      pi@raspberrypi:~ $ pm2 logs MagicMirror
                      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [09.08.2021 01:34.41.419] [LOG]   Connecting socket for: currentweather
                      0|MagicMir | [09.08.2021 01:34.41.423] [LOG]   Connecting socket for: newsfeed
                      0|MagicMir | [09.08.2021 01:34.41.425] [LOG]   Starting node helper for: newsfeed
                      0|MagicMir | [09.08.2021 01:34.41.426] [LOG]   Sockets connected & modules started ...
                      0|MagicMir | [09.08.2021 01:34.42.061] [LOG]   Launching application.
                      0|MagicMir | [09.08.2021 01:34.49.566] [LOG]   Shutting down server...
                      0|MagicMir | [09.08.2021 01:36.01.706] [LOG]   Starting MagicMirror: v2.16.0
                      0|MagicMir | [09.08.2021 01:37.27.498] [LOG]   [SIGINT] Received. Shutting down server...
                      0|MagicMir | [09.08.2021 01:37.29.125] [LOG]   Starting MagicMirror: v2.16.0
                      0|MagicMir | [09.08.2021 02:01.15] [LOG]   [SIGINT] Received. Shutting down server...
                      0|MagicMir | [09.08.2021 02:01.17.151] [LOG]   Starting MagicMirror: v2.16.0
                      0|MagicMir | [09.08.2021 02:06.47.453] [LOG]   [SIGINT] Received. Shutting down server...
                      0|MagicMir | [09.08.2021 02:06.49.001] [LOG]   Starting MagicMirror: v2.16.0
                      0|MagicMir | [09.08.2021 02:07.10.237] [LOG]   [SIGINT] Received. Shutting down server...
                      0|MagicMir | [09.08.2021 02:07.11.810] [LOG]   Starting MagicMirror: v2.16.0
                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                      0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:778:12)
                      0|MagicMir | [09.08.2021 02:07.11.831] [ERROR] Whoops! There was an uncaught exception...
                      0|MagicMir | [09.08.2021 02:07.11.835] [ERROR] TypeError: Cannot read property 'on' of undefined
                      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:98:5)
                      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:1072:14)
                      0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
                      0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:937:32)
                      0|MagicMir |     at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:75:21)
                      0|MagicMir | [09.08.2021 02:07.11.837] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|MagicMir | [09.08.2021 02:07.11.839] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      I do have an internet connection working, so that is not the issue…you see anything?
                      Thanks again.
                        sdetweil @Achilles
                        @achilles I would go thru each module folder and check for package.json file
                        if present do an npm install in each such module folder.
                        I would use npm start in the MagicMirror folder (and ctrl-q on mm screen) til u get it all working, then use pm2 to start
                        so pm2 stop all
                        then do above, then pm2 start 0
                        then reboot
