Current weather doesn't work
My setup is almost done but my current weather module doesn’t work, the Weather Forecast module is working without problem. The settings are the same for the two modules, i tried a separate api-key for current weather module but that didn’t help. The header for the module is working but the data is no go.
Any suggestions on how to solve this?
can you post your config?
Thx for reply
module: ‘currentweather’,
position: ‘top_right’,
header: ‘Värt just nu’,
locationID: ‘2711537’, //ID from http://www.openweathermap.org
appid: ‘12345’
module: ‘weatherforecast’,
header: ‘Värt’,
appid: ‘12345’
I think there is a problem with the js files. Your config is working on my magic mirror
is it running without the header part?
I replaced “currentweather.js” from github and now it’s working. Thanks for your help!
you’re welcome
