Magic Mirror on Rancher
13 Posts 4 Posters 2.2k Views 4 Watching
  • W Offline
    Wmsmckay
    I’m not sure where to post this so I hope I can find some help here.
    I’ve been running my magic mirror on a raspberry pi for a few months plugged into a Roku smart tv. I would like to repurpose the pi for other projects but I’m very attached to my magic mirror dashboard. My solution right now is to run the magic mirror on my home server and access it over a browser from my roku TV. This would allow the pi to be reused and the tv would be able to just display the page without anything else plugged into it.
    I’ve seen one issue is that Roku doesn’t have a web browser but I have found a few work arounds that I will try.
    My server has Kubernetes running on it to manage all of my docker containers and I manage that with Rancher. I have been using this docker image and setup to create the container, which works. The problem is that when I go to the port that I publish it on (8075) I get an “unable to connect” error.
    I have tried changing the address in the config file from 0.0.0.0 to my server’s ip to see if that would help but I just get a crash error from the container.
    Any help with this issue would be much appreciated. Thanks in advance.
    S 2 Replies Last reply Aug 12, 2021, 11:14 PM Reply Quote 0
      sdetweil @Wmsmckay
      @wmsmckay connecting from where?
      can u show a diagram
      W 1 Reply Last reply Aug 12, 2021, 11:17 PM Reply Quote 0
      • W Offline
        Wmsmckay @sdetweil
        I’m connecting from a device on the same network that the server is running on.
        Are you just wanting a network diagram?
        S 1 Reply Last reply Aug 12, 2021, 11:24 PM Reply Quote 0
          sdetweil @Wmsmckay
          @wmsmckay so u have a docker container, app running on address:“0.0.0.0”, port??? exposed on the server as port?? and the firewall on the server allows access for outside the server.
          if u run a default http server container on that same server, can u access from the other system?
          W 1 Reply Last reply Aug 12, 2021, 11:29 PM Reply Quote 0
          • W Offline
            Wmsmckay @sdetweil
            @sdetweil I have a VM running Rancher, Kubernetes and Docker at 10.0.0.16. I deployed a service running the Magic Mirror image from that on port 8075. When I navigate to 10.0.0.16:8075 I get nothing.
            I have other service running on the stack that I can reach just fine e.g. pihole, mysql databases, a web server.
            S 1 Reply Last reply Aug 12, 2021, 11:34 PM Reply Quote 0
              sdetweil @Wmsmckay
              @wmsmckay the container cannot use it’s host address directly
                sdetweil @Wmsmckay
                @wmsmckay so mm config inside the container says port 8080, address:“0.0.0.0”, ipWhitelist:[]
                and u map that to 8075 on the host
                W 1 Reply Last reply Aug 12, 2021, 11:39 PM Reply Quote 0
                • W Offline
                  Wmsmckay @sdetweil
                  @sdetweil Corrent. I used the docker image above which maps port 80 in the container to an external port on the host which I set to 8075.
                  The config file is set to the default which is
                  var config = {
                    address: "0.0.0.0", // Address to listen on, can be:
                    port: 8075,
                    ipWhitelist: [], // Set [] to allow all IP addresses
                  S 1 Reply Last reply Aug 12, 2021, 11:55 PM Reply Quote 0
                    sdetweil @Wmsmckay
                    @wmsmckay no, inside the container it’s port 80
                    the mapping is done outside, nat translation
                    the app inside doesn’t know
                    app configured to port 80
                    docker does nat and exposes that on the docker host as 8075 (-p 8075:80)
                    this is exactly the same as if u wanted your mm on a pi, exposed to the internet
                    8080 on pi, router says map requests from 8075 on internet to port 8080 on the pi.
                    pi doesn’t know
                    W 1 Reply Last reply Aug 13, 2021, 1:33 AM Reply Quote 0
                    • W Offline
                      Wmsmckay @sdetweil
                      @sdetweil Right. I have that port mapped but when I navigate to host:8075, I just get an error.
                      In my logs it says
                      Ready to go! Please point your browser to: http://0.0.0.0:8075
                      But going to 10.0.0.16:8075 there is nothing there.
                      S 2 Replies Last reply Aug 13, 2021, 1:36 AM Reply Quote 0
