Unsolved Cursor shown in v2.16.0
I have a solid black cursor on my MM v2.16.0. The cursor disappears as soon as I move the mouse the first time.
In the main.css I see:
html { cursor: none; overflow: hidden; background: var(--color-background); user-select: none; font-size: var(--font-size); }
I used the script from @sdetweil to update and install my MM.
Any ideas how to fix that? I think, I saw this behavior first time after updating to v2.15.0.
I have that too but am still in the setup phase from the Magic Mirror. The mouse and keyboard are still connected. Have you seen these solutions?
https://forum.magicmirror.builders/topic/9859/mouse-arrow-doesn-t-hide-after-magicmirror-is-loaded
https://github.com/evghenix/MMM-CursorA transparent PNG or GIF file will probably not work either, because a mouse movement is expected.
cursor: url(pointer.png), none;
the “none” is a necessary fallback.
@majorc maybe install unclutter?
@sdetweil as it was working fine before, I am not 100% happy to just install something over.
Fun fact, if I move the the mouse, the cursor disappears immediately.
@majorc so, it sounds like a defect in the electron version in 2.16
@sdetweil I do not know what that mean. Is there a way that I can fix it?
Or do I have to wait for version 17?
@majorc if u use chrome do u see the cursor
my prior comment was that maybe WE don’t have a solution
@sdetweil I see the cursor only on the pi. And it disappears if I move the mouse the first time on the pi. But the cursor is visible again after i do a
pm2 restart 0
On my windows machine witch chrome, I don’t see the cursor at no time.
@majorc so, that confirms it’s an electron issue.
you could change to run server mode with chrome on the pi.
