    Mouse arrow doesn't hide after MagicMirror is loaded
    3 Posts 2 Posters 2.9k Views 2 Watching
    • Cr4z33C Offline
      Cr4z33
      I am testing my final MM build on the TV when I just noticed that the mouse arrow doesn’t hide.
      Any reason why it is showing and how can I automatically hide it after MM loading?
      • ejay-ibmE Offline
        ejay-ibm Project Sponsor Module Developer
        From the doc here:
        https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
        Autohiding the Mouse Pointer
        Install unclutter:
        sudo apt-get install unclutter
        You can create an .xinitrc script to run the tool.
        See https://wiki.archlinux.org/index.php/Unclutter
        But a simpler option is to add a line to the end of the file:
        $ nano ~/.config/lxsession/LXDE-pi/autostart
        @unclutter -display :0 -idle 3 -root -noevents
        This will add a 3 second delay, before the pointer disappears from the screen when not using it.
        Hope this helps
        Ejay
        Cr4z33C 1 Reply Last reply Reply Quote 1
        • Cr4z33C Offline
          Cr4z33 @ejay-ibm
          @ejay-ibm it helps A LOT thanks! 👍🏼
