Unsolved Help! - Adding and Changing Modules - Newbe
Using the Office 365 calendar should be easy.
if you’re using a calendar that shows up on https://outlook.live.com/, you can get an ICS to the file easily, by going to https://outlook.live.com/calendar/0/options/calendar/SharedCalendars.
From there, use the publish links to grab the ICS file and path for MM.
@sdetweil You know, not including the ending comma (optional, I know) is gonna mess 'em up when they go to add more than one module…
@bkeyport use MMM-Config!
@sdetweil True. :)
