Unsolved MagicMirror isn't publishing 'user_presence' on start up?
@sdetweil Not sure how to do that to the MQTT channel, but can I send a notification when it’s started up? That would be picked up by the MQTT mirror addon?
@sdetweil Ok, I found the mosqitto_pub command, so I can publish with that to MQTT, which startup script is it, and can I make sure it’s done loading before running the command?
@fribse how do u start mm? pm2?
if so it runs the installers/mm.sh
pm2 info xx
where xx is the name or number of the pm2 entry shown by pm2 status
will show u the command used to start mmif you used my install script and selected pm2,
then the script is
~/MagicMirror/installers/mm.sh -
@sdetweil Ok, yes, I used your script.
So it just says
# This file is still here to keep PM2 working on older installations. cd ~/MagicMirror DISPLAY=:0 npm start
So I guess that just launches it, but it’s not actually ready at that point, thus the MMM-MQTTbridge is also not ready to receive the ‘hdmi off’ command.
Aren’t there some sort of notification that says ‘done, ready for running’ when it starts, I could put that notification in the MMM-MQTTbridge so that would also launch the ‘SCREENON’ back to MQTT. -
@fribse there is no simple way…
do you get an error from trying to post the message?
if so, I would check and loop and sleep a little, then try again
@sdetweil Darned, that’s really sad, it seems logical to make a notification that says done setting up, and running. Oh well, always room for improvement in the code :-)
@fribse yes, inside… but u are outside (Oh I see, change the module)
from the doc
https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methodsALL_MODULES_STARTED
@sdetweil Ahaaaa, way cooler :-)
So I guess I should add this to the notiDictionary.js
I’m unsure of the payloadValue?{ notiId: "ALL_MODULES_STARTED", notiPayload: [ { payloadValue: '1', notiMqttCmd: ["SCREENON"] } ] }
@fribse sorry, now no idea, don’t know the module internals
@sdetweil Ok, gotcha. I’m trying to figure out the notification, currently the MMM-MQTTbridge doesn’t pick it up.
I’ve set up MMM-ViewNotifications, but I’m drowning in noti’s.
I made this config{ module: "MMM-ViewNotifications", position: "top_left", header: "Notifications", config: { excludeModules: ["clock","newsfeed","currentweather","calendar","MMM-News-QR"] } },
What did I do wrong since it still displays noti’s from these?
