    MagicMirror isn't publishing 'user_presence' on start up?
    17 Posts 2 Posters 5.2k Views 2 Watching
    • F Offline
      fribse
      I’ve started rebooting my mirror once a day due to the problem with the newsreader mentioned elsewhere.
      This made another bug apparent.
      I’m turning the HDMI on and off depending on presence, and I also report the state to MQTT.
      But it seems that if the HDMI is turned off, and then a reboot is done the HDMI is turned on, but the change in USER_PRESENCE isn’t sent in notifications, so the MQTT shows the monitor as turned off (if it was turned off before the reboot).
        sdetweil @fribse
        @fribse that’s because it’s not a change. typically the code doesn’t inspect the state, just sets it
        so it doesn’t know it was off, and user_presence is different anyhow.
        if u can use curl to post a message to the mq channel, then add a line to the startup script to send the user presence notification
        F 2 Replies Last reply Reply Quote 0
        • F Offline
          fribse @sdetweil
          @sdetweil Not sure how to do that to the MQTT channel, but can I send a notification when it’s started up? That would be picked up by the MQTT mirror addon?
          • F Offline
            fribse @sdetweil
            @sdetweil Ok, I found the mosqitto_pub command, so I can publish with that to MQTT, which startup script is it, and can I make sure it’s done loading before running the command?
              sdetweil @fribse
              @fribse how do u start mm? pm2?
              if so it runs the installers/mm.sh
              pm2 info xx
              where xx is the name or number of the pm2 entry shown by pm2 status
              will show u the command used to start mm
              if you used my install script and selected pm2,
              then the script is
              ~/MagicMirror/installers/mm.sh
              • F Offline
                fribse @sdetweil
                @sdetweil Ok, yes, I used your script.
                So it just says
                # This file is still here to keep PM2 working on older installations.
                DISPLAY=:0 npm start
                So I guess that just launches it, but it’s not actually ready at that point, thus the MMM-MQTTbridge is also not ready to receive the ‘hdmi off’ command.
                Aren’t there some sort of notification that says ‘done, ready for running’ when it starts, I could put that notification in the MMM-MQTTbridge so that would also launch the ‘SCREENON’ back to MQTT.
                  sdetweil @fribse
                  @fribse there is no simple way…
                  do you get an error from trying to post the message?
                  if so, I would check and loop and sleep a little, then try again
                  • F Offline
                    fribse @sdetweil
                    @sdetweil Darned, that’s really sad, it seems logical to make a notification that says done setting up, and running. Oh well, always room for improvement in the code :-)
                      sdetweil @fribse
                      @fribse yes, inside… but u are outside (Oh I see, change the module)
                      from the doc
                      https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                      ALL_MODULES_STARTED
                      • F Offline
                        fribse @sdetweil
                        @sdetweil Ahaaaa, way cooler :-)
                        So I guess I should add this to the notiDictionary.js
                        I’m unsure of the payloadValue?
                          notiId: "ALL_MODULES_STARTED",
                          notiPayload: [
                              payloadValue: '1',
                              notiMqttCmd: ["SCREENON"]
                          sdetweil @fribse
                          @fribse sorry, now no idea, don’t know the module internals
                          • F Offline
                            fribse @sdetweil
                            @sdetweil Ok, gotcha. I’m trying to figure out the notification, currently the MMM-MQTTbridge doesn’t pick it up.
                            I’ve set up MMM-ViewNotifications, but I’m drowning in noti’s.
                            I made this config
                                  module: "MMM-ViewNotifications",
                                  header: "Notifications",
                                    excludeModules: ["clock","newsfeed","currentweather","calendar","MMM-News-QR"]
                            What did I do wrong since it still displays noti’s from these?
                              sdetweil @fribse
                              @fribse u can filter messages by placing part of the modulename in the filter field
                              • F Offline
                                fribse @sdetweil
                                @sdetweil Hey Sam, sorry you lost me, “filter field”?
                                @bugsounet If you are still around, do you have any idea about the notification format in notiDictionary.js?
                                  sdetweil @fribse
                                  @fribse sorry, I was using the dev window, console tab
                                  • F Offline
                                    fribse @sdetweil
                                    @sdetweil Ahh, yes, and there I do see the
                                    sendNotification("ALL_MODULES_STARTED");
                                    Going out, hmm, it seems that it’s main sending it out, I wonder if that is supposed to be payload Value, and notiId is supposed to be something like main? Hmm, I hope sergge1 or @bugsounet knows that.
                                      sdetweil @fribse
                                      @fribse notifications don’t have to have a payload
                                      I think the source could be null too
