    MagicMirror isn't publishing 'user_presence' on start up?
    17 Posts 2 Posters 5.7k Views 2 Watching
    • F Offline
      fribse @sdetweil
      @sdetweil Ok, I found the mosqitto_pub command, so I can publish with that to MQTT, which startup script is it, and can I make sure it’s done loading before running the command?
        sdetweil @fribse
        @fribse how do u start mm? pm2?
        if so it runs the installers/mm.sh
        pm2 info xx
        where xx is the name or number of the pm2 entry shown by pm2 status
        will show u the command used to start mm
        if you used my install script and selected pm2,
        then the script is
        ~/MagicMirror/installers/mm.sh
        • F Offline
          fribse @sdetweil
          @sdetweil Ok, yes, I used your script.
          So it just says
          # This file is still here to keep PM2 working on older installations.
          DISPLAY=:0 npm start
          So I guess that just launches it, but it’s not actually ready at that point, thus the MMM-MQTTbridge is also not ready to receive the ‘hdmi off’ command.
          Aren’t there some sort of notification that says ‘done, ready for running’ when it starts, I could put that notification in the MMM-MQTTbridge so that would also launch the ‘SCREENON’ back to MQTT.
            sdetweil @fribse
            @fribse there is no simple way…
            do you get an error from trying to post the message?
            if so, I would check and loop and sleep a little, then try again
            • F Offline
              fribse @sdetweil
              @sdetweil Darned, that’s really sad, it seems logical to make a notification that says done setting up, and running. Oh well, always room for improvement in the code :-)
                sdetweil @fribse
                @fribse yes, inside… but u are outside (Oh I see, change the module)
                from the doc
                https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                ALL_MODULES_STARTED
                • F Offline
                  fribse @sdetweil
                  @sdetweil Ahaaaa, way cooler :-)
                  So I guess I should add this to the notiDictionary.js
                  I’m unsure of the payloadValue?
                    notiId: "ALL_MODULES_STARTED",
                    notiPayload: [
                        payloadValue: '1',
                        notiMqttCmd: ["SCREENON"]
                    sdetweil @fribse
                    @fribse sorry, now no idea, don’t know the module internals
                    • F Offline
                      fribse @sdetweil
                      @sdetweil Ok, gotcha. I’m trying to figure out the notification, currently the MMM-MQTTbridge doesn’t pick it up.
                      I’ve set up MMM-ViewNotifications, but I’m drowning in noti’s.
                      I made this config
                            module: "MMM-ViewNotifications",
                            header: "Notifications",
                              excludeModules: ["clock","newsfeed","currentweather","calendar","MMM-News-QR"]
                      What did I do wrong since it still displays noti’s from these?
                        sdetweil @fribse
                        @fribse u can filter messages by placing part of the modulename in the filter field
                        • F Offline
                          fribse @sdetweil
                          @sdetweil Hey Sam, sorry you lost me, “filter field”?
                          @bugsounet If you are still around, do you have any idea about the notification format in notiDictionary.js?
                            sdetweil @fribse
                            @fribse sorry, I was using the dev window, console tab
                            • F Offline
                              fribse @sdetweil
                              @sdetweil Ahh, yes, and there I do see the
                              sendNotification("ALL_MODULES_STARTED");
                              Going out, hmm, it seems that it’s main sending it out, I wonder if that is supposed to be payload Value, and notiId is supposed to be something like main? Hmm, I hope sergge1 or @bugsounet knows that.
                                sdetweil @fribse
                                @fribse notifications don’t have to have a payload
                                I think the source could be null too
