    MagicMirror isn't publishing 'user_presence' on start up?
    17 Posts 2 Posters 5.3k Views 2 Watching
      sdetweil @fribse
      @fribse there is no simple way…
      do you get an error from trying to post the message?
      if so, I would check and loop and sleep a little, then try again
      • F Offline
        fribse @sdetweil
        @sdetweil Darned, that’s really sad, it seems logical to make a notification that says done setting up, and running. Oh well, always room for improvement in the code :-)
          sdetweil @fribse
          @fribse yes, inside… but u are outside (Oh I see, change the module)
          from the doc
          https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
          ALL_MODULES_STARTED
          • F Offline
            fribse @sdetweil
            @sdetweil Ahaaaa, way cooler :-)
            So I guess I should add this to the notiDictionary.js
            I’m unsure of the payloadValue?
              notiId: "ALL_MODULES_STARTED",
              notiPayload: [
                  payloadValue: '1',
                  notiMqttCmd: ["SCREENON"]
              sdetweil @fribse
              @fribse sorry, now no idea, don’t know the module internals
              • F Offline
                fribse @sdetweil
                @sdetweil Ok, gotcha. I’m trying to figure out the notification, currently the MMM-MQTTbridge doesn’t pick it up.
                I’ve set up MMM-ViewNotifications, but I’m drowning in noti’s.
                I made this config
                      module: "MMM-ViewNotifications",
                      header: "Notifications",
                        excludeModules: ["clock","newsfeed","currentweather","calendar","MMM-News-QR"]
                What did I do wrong since it still displays noti’s from these?
                  sdetweil @fribse
                  @fribse u can filter messages by placing part of the modulename in the filter field
                  • F Offline
                    fribse @sdetweil
                    @sdetweil Hey Sam, sorry you lost me, “filter field”?
                    @bugsounet If you are still around, do you have any idea about the notification format in notiDictionary.js?
                      sdetweil @fribse
                      @fribse sorry, I was using the dev window, console tab
                      • F Offline
                        fribse @sdetweil
                        @sdetweil Ahh, yes, and there I do see the
                        sendNotification("ALL_MODULES_STARTED");
                        Going out, hmm, it seems that it’s main sending it out, I wonder if that is supposed to be payload Value, and notiId is supposed to be something like main? Hmm, I hope sergge1 or @bugsounet knows that.
                          sdetweil @fribse
                          @fribse notifications don’t have to have a payload
                          I think the source could be null too
