    Stocks
    36 Posts 15 Posters 36.5k Views 14 Watching
    • Z Offline
      ZTA0796 @alexyak
      • Z Offline
        ZTA0796 @alexyak
        @alexyak Thanks! I have one more question about syntax that I’m having trouble with.
        I can pull the Yahoo JSON into the node_helper file and print it to the terminal without a problem. But when I try to reference it in the “getDom” function, I get nothing. I haven’t changed the code at the start of that function at all. But when it runs “this.result.length”, the length returned is 0.
        I’m not super-familiar with the “this” syntax, but was hoping you or someone else might have an idea of why the JSON you pass would work, but not the JSON that I pass?
        Thanks!
          chrisfoerg
          great! would also be good for rss feeds :-)
            alexyak @ZTA0796
            @ZTA0796 Could you show your code?
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              ZTA0796 @alexyak
              @alexyak Sure…see below.
              In the node_helper.js:
              getStocks: function (url) {
              var self = this;
                request({ url: url, method: 'GET' }, function (error, response, body) {
                    if (!error && response.statusCode == 200) {
                        var result = JSON.parse(body);
                        console.log(result.query.results.row);  //prints the JSON as expected to the terminal
                        self.sendSocketNotification('STOCKS_RESULT', result);
              //Subclass socketNotificationReceived received.
              if (notification === ‘GET_STOCKS’) {
              this.getStocks(payload);
              in stocks.js:
              getDom: function() {
                  var wrapper = document.createElement("table");
                  wrapper.className = 'normal regular small';
                  var count = 0;
                  var _this = this;
              	console.log("in the DOM function");
              	console.log("result is " + this);  //prints [object Object]
              	console.log("result is " + _this); //prints [object Object]
              	console.log("result length is " + this.result.length); //prints 0
                  if (this.result.length > 0){
                      this.result.forEach(function(stock) {
              			//since length=0, it never gets in this loop
              scheduleUpdate: function(delay) {
              	console.log("scheduled update check");
              	var nextLoad = this.config.updateInterval;
              	if (typeof delay !== "undefined" && delay >= 0) {
              		nextLoad = delay;
              	var self = this;
              	setInterval(function() {
              		self.getStocks();
              	}, nextLoad);
              roundValue: function(value) {
                 return Math.round(value*100)/100;
              getStocks: function () {
                  var url = 'https://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20csv%20where%20url%3D%27http%3A%2F%2Fdownload.finance.yahoo.com%2Fd%2Fquotes.csv%3Fs%3D' + this.config.stocks + '%26f%3Dsl1d1t1c1ohgv%26e%3D.csv%27%20and%20columns%3D%27symbol%2Cprice%2Cdate%2Ctime%2Cchange%2Ccol1%2Chigh%2Clow%2Ccol2%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys';
                  this.sendSocketNotification('GET_STOCKS', url);
                  if (notification === "STOCKS_RESULT") {
              		console.log("notification received");
              		console.log(payload);  //prints Object { query: Object }
                      this.result = payload;
                      this.updateDom(self.config.fadeSpeed);
              • Z Offline
                ZTA0796
                Upon looking at it further-- in the “socketNotificationReceived: function(notification, payload)” function in the module.js file, it seems that when I run console.log(this.result), it outputs my JSON:
                Object { symbol: “MSFT”, price: “62.30”, date: “12/16/2016”, time: “4:00pm”, change: “-0.28”, col1: “62.95”, high: “62.95”, low: “62.12”, col2: “42453083” }
                When I go to the “getDom” function and run “console.log(this.result)”, I get:
                [object Object]
                I’m just not sure why that change occurs, but that seems to be my issue. Any help is massively appreciated!
                  alexyak @ZTA0796
                  @ZTA0796 The object that you get int the stocks.js is the deserialized javascript object. In your case it’s going to be a single row object. You could just access the properties list this:
                  this.result.symbol, this.result.price, etc…
                  -Alex
                  • Z Offline
                    ZTA0796 @alexyak
                    @alexyak So that’s what I expected as well. Unfortunately, it is somehow getting messed up between the “socketNotificationReceived” function and the “getDom” function.
                            console.log(this.result);  //prints my JSON correctly console
                    So the above works correctly. Below, however, it doesn’t seem to maintain and I can’t figure out why.
                        var count = 0;
                        var _this = this;
                    	console.log("result is " + this.result); //prints "result is [object Object]"
                    	console.log("result length is " + this.result.length); //prints "result length is 0"
                    	console.log(this.symbol);  //prints "undefined"
                    I apologize if I’m being thick, but I can’t figure out why it’s not working…
                    • Z Offline
                      ZTA0796
                      Ok, so I think i figured it out. Still not sure why it worked, but for some reason, running a console.log("descriptive text " + this) seems to corrupt or change the type of “this”. If I put two consecutive console.log() calls–first with descriptive text, second with just “this”–then it works. Basically in the example above, if I just comment out the first two console.log() calls, then it no longer prints “undefined” and instead prints “MSFT”. Sorry for all the trouble!
                      • Mitch1138M Offline
                        Mitch1138
                        Several weeks ago this module seemed to stop working. It doesn’t generate any errors, just won’t display. Has anyone else seen this?
                        Thanks, Dave
                        pugslyP Mykle1M 2 Replies Last reply Reply Quote 0
                        • 1 / 4
