    MMM-AQI stopped working
    8 Posts 2 Posters 1.7k Views 2 Watching
      dwburger
      In recent days, the MMM-AQI module on my MM2 has stopped working. I’ve checked my token on the World AQI website and it delivers the correct data so that part’s OK. Can anyone suggest other things to check? The module depends on “request” that’s been deprecated. Could that be an issue? Thanks for any suggestions provided!
        sdetweil @dwburger
        @dwburger said in MMM-AQI stopped working:
        request still works.
        there was a problem with a certificate authority expired cert starting on Friday.
        u should see that in your mm messages
        2.17.1 had a fix for that problem
          dwburger @sdetweil
          @sdetweil Thanks so much for the reply! Unfortunately, I only understood the first part. OK…“request” still works. How do I view mm messages? I used your script to update to the latest version earlier. How do I go about determining whether 2.17.1 was installed properly?
            sdetweil @dwburger
            @dwburger did u say yes to PM2 when u installed MM?
            pm2 log --lines=100
            or
            grep version ~/MagicMirror/package.json
            or review the ~/MagicMirror/installers/upgrade.log
              dwburger @sdetweil
              @sdetweil Yes…I use pm2 to start/stop MM2.
                dwburger @sdetweil
                @sdetweil said in MMM-AQI stopped working:
                pm2 log --lines=100
                OK…now I get it. I used:
                pm2 log --lines=100
                to view the log. Lots of red text having to do with the RTSP MM module. I’ll keep looking for errors having to do with expired certificates.
                  sdetweil @dwburger
                  @dwburger u can also view the files at
                  ~/.pm2/logs
                  note the dot in front of pm2
                  use a good editor, then u can search the files
                    dwburger @sdetweil
                    @sdetweil I must have made a mistake when using your script command to upgrade:
                    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                    After I backed-up altered files and modules, I used the command:
                    git pull && npm install
                    and the MMM-AQI module works again. Thanks for pointing me in the right direction!
