    Updated to 2.17 but MM not launching
    28 Posts 5 Posters 9.4k Views 5 Watching
    • W Offline
      Wenike
      Instead, I have a window labeled Electron running with nothing displayed. I did a git pull && npm install to do the update and had to remove both instances of package-lock.json (in the root MM folder and in the vendor subfolder) to do the update and I don’t remember modifying those. Is there some additional steps I need to do to make Electron behave?
      • swvalentiS Offline
        swvalenti Project Sponsor
        Try using Sam scripts
          sdetweil @swvalenti
          @swvalenti thx…
          @Wenike also not listed (ever) on the MM site
          for every module that has a package.json file do npm install
          note that its possible that IF you had to add request back in on 2.16, it will be gone on 2.17 again
          NOTE : because u already did the ‘ugrade’, you will need to use force instead of apply on the upgrade script
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor @sdetweil
            Hi, need help too
            i have installed the update and when i start the mirror …
            [02.10.2021 10:25.40.721] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
            Require stack:
            - /Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js
            - /Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/index.js
            - /Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
            - /Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/node_helper.js
            - /Users/patrickhahn/MagicMirror/js/app.js
            - /Users/patrickhahn/MagicMirror/js/electron.js
            - /Users/patrickhahn/MagicMirror/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
            [02.10.2021 10:25.40.722] [LOG]   Loading module helpers ...
            [02.10.2021 10:25.40.722] [LOG]   No helper found for module: alert.
            [02.10.2021 10:25.40.722] [LOG]   Initializing new module helper ...
            [02.10.2021 10:25.40.723] [LOG]   Module helper loaded: MMM-Remote-Control
            [02.10.2021 10:25.40.723] [LOG]   Initializing new module helper ...
            [02.10.2021 10:25.40.723] [LOG]   Module helper loaded: updatenotification
            [02.10.2021 10:25.40.723] [LOG]   No helper found for module: MMM-Snow.
            [02.10.2021 10:25.40.723] [LOG]   No helper found for module: MMM-WordClock.
            [02.10.2021 10:25.40.723] [LOG]   No helper found for module: clock.
            [02.10.2021 10:25.40.723] [LOG]   No helper found for module: calendar_monthly.
            [02.10.2021 10:25.40.723] [LOG]   Module helper loaded: calendar
            [02.10.2021 10:25.40.725] [ERROR] App threw an error during load
            [02.10.2021 10:25.40.726] [ERROR] Error: Cannot find module 'request'
            Require stack:
                at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                at Function.Module._resolveFilename (/Users/patrickhahn/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (internal/modules/cjs/loader.js:732:27)
                at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                at Module.require (internal/modules/cjs/loader.js:959:19)
                at require (internal/modules/cjs/helpers.js:88:18)
                at Object.<anonymous> (/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js:2:15)
                at Module._compile (internal/modules/cjs/loader.js:1078:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
            [02.10.2021 10:25.40.726] [ERROR] Whoops! There was an uncaught exception...
            [02.10.2021 10:25.40.729] [ERROR] Error: Cannot find module 'request'
            Require stack:
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
              code: 'MODULE_NOT_FOUND',
              requireStack: [
                '/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js',
                '/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/index.js',
                '/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js',
                '/Users/patrickhahn/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
                '/Users/patrickhahn/MagicMirror/js/app.js',
                '/Users/patrickhahn/MagicMirror/js/electron.js',
                '/Users/patrickhahn/MagicMirror/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js',
                undefined
            thanks for helping
              @stoffbeuteluwe said in Updated to 2.17 but MM not launching:
              Cannot find module ‘request’
              same problem for the last few months. and last release
              see
              https://forum.magicmirror.builders/topic/15666/add-request-to-modules
              • O Offline
                OberfragGER @sdetweil
                Happens to me to.
                MMM-SystemStats stops MM from working. reinstall and everything are not working so i had to quit using both MMM-SystemStats Modules.
                  sdetweil @OberfragGER
                  @oberfragger did u look for the errors to decide what to do?
                  • O Offline
                    @sdetweil Uuups.
                    Sorry for the “short” information. I did´nt realised that i sent the topic.
                    Both “MMM-SystemStats” seems to unmantained and both are stopping MM from starting. I just uncommented them in the config.js and openend an issue.
                    /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | at require
                    (internal/modules/cjs/helpers.js:88:18) 0|mm | at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-SystemS tats/node_helper.js:13:15) 0|mm | at Module._compile (internal/modules/cjs/loader.js:1078:30) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.j s:1108:10) { 0|mm | code: 'MODULE_NOT_FOUND', 0|mm | requireStack: [ 0|mm | '/home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js', 0|mm | '/home/pi/MagicMirror/js/app.js', 0|mm | '/home/pi/MagicMirror/js/electron.js', 0|mm | '/home/pi/MagicMirror/node_modules/electron/dist/resources/defa ult_app.asar/main.js', 0|mm | undefined 0|mm | ] 0|mm | } 0|mm | [04.10.2021 13:13.47.982] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [04.10.2021 13:13.47.982] [ERROR] If you think this really is an is sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss ues
                    I dont have any clus what i cloud do more.
                      @oberfragger it says module not found
                      we deleted a bunch of older libraries because one was discontinued (deprecated) due to a security problem not going to be fixed
                      many mm modules used them but didn’t document the usage. oops
                      I don’t see the name of the library
                      but looking at the node_helper.js shows
                      require('request')
                      which is the trouble lib
                      u can add it back for this module , do
                      npm init -y
                      npm install request -- save
                      O StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                      • O Offline
                        @sdetweil said in Updated to 2.17 but MM not launching:
                        Thanks a lot. That did the job for me!
