    Connecting Modules to Each Other
    16 Posts 3 Posters 6.3k Views 3 Watching
    • T Offline
      tonkxy @sdetweil
      @sdetweil great callout! I did not know I could debug. I do get a type back. I did the break trick on where its in an if statement and the type is still undefined in setImage
        sdetweil @tonkxy
        @tonkxy well
        setImage: function () {
          let rand = Math.floor(Math.random() * 4)+1; //randomn number to pick gif
        	var day = new Date();
        	var hour = day.getHours();
        	var type = this.currentWeatherTemperature;   // < ----
        notification
        //From data currentweather set weather type
        	setCurrentWeatherType: function(type){
        	this.currentWeatherType = type;    // < ----
        notificationReceived: function (notification, payload, sender) {
        	  if (notification === 'DOM_OBJECTS_CREATED') {
        	    this.job()
        //weather dom
        	if(notification === "CURRENTWEATHER_TYPE"){
        		this.setCurrentWeatherType(payload.type);
        this.currentWeatherTemperature is NOT this.currentWeatherType
        • T Offline
          tonkxy @sdetweil
          @sdetweil that definitely was part of it.
          I am able to successfully see the payload in notifications. Just working a way to retain it and be able to use in setImage. Thank you!
            sdetweil @tonkxy
            @tonkxy should be able to save the payload pointer and then use that day later. I do it all the time
            this.weatherInfo = payload
            for example
            remember your module could get called at getDom() long before the other module sends the notification, so u need to check if it has arrived yet.
            • T Offline
              tonkxy @sdetweil
              @sdetweil funny you say that. Ive been reading and you offered the solution on someone using compliments + weather. My issue is when i step through to set image, the type is back to undefined and not carried from the notification. Im wondering if its in my order as to why its going back to undefined
                sdetweil @tonkxy
                @tonkxy I would put a stop everywhere u set it.
                make sure the this. pointer is pointing to the same place set vs use
                • T Offline
                  tonkxy @sdetweil
                  @sdetweil when you say stop you mean in my debug to see where im losing the value?
                    sdetweil @tonkxy
                    @tonkxy correct
                    • T Offline
                      tonkxy @sdetweil
                      @sdetweil Great advice.
                      I stepped through and you were right on two things. When it starts, it defaults with the else case, because it hasn’t fetched the type yet. Once it does fetch the type I was resetting it in the myJob() function causing it to be undefined again.
                      I appreciate the break down on this. JS is definitely giving me a run for my money on learning it.
                        sdetweil @tonkxy
                        @tonkxy glad you are making progress.
                        not a JS problem. any language would have the same problem…
