    Installing on a Pi Zero
    175 Posts 33 Posters 300.2k Views 33 Watching
      RushHour99 @sdetweil
      @sdetweil Thanks, error log emailed. Ive done this process before without error ~9 months ago. Maybe the rasbian version or magic mirror version has changed recently that is now causing the problem.
      S 2 Replies Last reply
        sdetweil @RushHour99
        @rushhour99 there is a new MM version every 2 months…
        I test on my own pi 0 .
        haven’t seen a problem like this
        sent email back, can u send install.log
          @rushhour99 do this
          sudo npm i -g npm@6
          this will downgrade npm to v6
          then
          rm -rf node_modules
          rm package-lock.json
          npm install --only=prod
          and check if the config.js file exists
          ls ~/MagicMirror/config/config,js -laF
          R 1 Reply Last reply
            @sdetweil said in Installing on a Pi Zero:
            sudo npm -i npm@6
            I got an error. Thanks for helping out, this is a new build so I don’t mind if it gets messed up and I need to start over.
            $ sudo npm -i npm@6
            npm ERR! code ENOENT
            npm ERR! syscall open
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
            npm ERR! enoent This is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR! /root/.npm/_logs/2021-08-03T22_48_17_691Z-debug.log
              @rushhour99 typo, sorry
              sudo npm i -g npm@6
                @sdetweil Thanks!
                I copied the config.js.sample to config.js before running the downgrade commands.
                After downgrading and rebooting, the Magic Mirror showed up on my Pi 0 with the default configuration.
                  @rushhour99 great, thanks for the update
                  I pushed a change to the installer to prevent npm going to v7.
                  • L
                    laurafox08
                    I recently purchased a pi0, and installed MagicMirror successfully. However when I go to install more modules, it starts to fail (ie. become very unstable). Other than just ‘upgrading’ to a Pi3/4, is there any reason why I couldn’t host the mirror on my website and just use the browser to display the data?
                      sdetweil @laurafox08
                      @laurafox08 said in Installing on a Pi Zero:
                      what do u mean?
                      this is a programmed app… its not just a web page.
                      did u increase the swap space… pi0 doesn’t have much memory…
                      and its under powered, so it can’t do everything that a pi3 or 4 could do…
                      L 1 Reply Last reply
                      • L
                        laurafox08 @sdetweil
                        @sdetweil sorry, my terminology isn’t great, this is my first experience doing much coding at all. I got it displaying the default modules, but it struggled to display my google calendar, and wouldn’t show background images at all. So I was wondering if instead of hosting locally on the pi, I could host it on my other computer and just call the data from there. The pi has no issue running Dakboard with background images, calendars etc, so I’m trying to see if I could run the MM in a similar fashion, as I like MM way better.
                          @laurafox08 sure, u install once, and can run full, server only or client only
                          client only really is browser to server.
                          so u can do what u want easily
                          the default install config assumes everything locally…
                          so, just change the config.js to allow any system on your network to connect
                          address:"0.0.0.0",
                          and initially disable any security filtering
                          ipWhitelist:[],
                          for pi0, my install script sets up chromium over server, as electron isn’t available pre built for armv6.
                          if u used my script see the run-start.sh script for the chromium command syntax
                          address:“0.0.0.0”,
                            see this
                            https://forum.magicmirror.builders/topic/15974/raspi-legacy-chromium-browser-broken-on-pi0w-armv6l-unable-to-install-magicmirror
                            • 9 / 9
