    No JavaScript experience - Config.js not working
    16 Posts 3 Posters 4.6k Views 2 Watching
    • O Offline
      OlesonCrypto
      Hey guys, I’ve been running into issues the past week on this config.js file alone. I took out my some of the private links I had for obvious reasons, but I’m mostly concerned with the syntax and actually having this modules show up on my screen. I can see the Magic Mirror^2 on my Raspberry Pi monitor. When running npm run config:check I would keep getting results like: " Parsing error: Unexpected token basePath", “Parsing error: Unexpected token ipWhitelist” & “Parsing error: Unexpected token position”.
      For my setup, I’m using a monitor with the Raspberry Pi4 Model B plugged in via HDMI to MicroHDMI. I have it set up to SSH inside or use the GUI on the RP4 desktop itself. I am able to see the black Magic Mirror^2 screen, in which it asks me to “Please create a config file or check the existing one for errors”. My configuration file is located at ~/MagicMirror/config/config.js. There are no other .js files within my MagicMirror directory.
      Further Notes: I created two static IP’s for my PI: 192.168.1.101 = eth0 & 192.168.1.102 = wlan0. After modifications, I run pm2 restart 1 to restart my MagicMirror. Also I found that nano -c [File_Path] works to find the exact line and column you’re currently on as you move throughout the code.
      /* Magic Mirror Config Sample -- Edited for my project
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
              address: "localhost", "192.168.1.102", "192.168.1.101",  //.101=eth0, .102=wlan0
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              ipWhitelist: ["192.168.1.0/24"],  // Set [] to allow all IP addresses
              useHttps: "false", // Support HTTPS or not, default "false" will use HTTP
              //httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              //httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "en",
              locale: "en-US",
              timeFormat: 24,
              units: "imperial",
                              module: "alert",
                              position:"top_left"
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              module: "MMM-googlecalendar"
                              position: "middle_center"
                              header: "Google Calandar"
                              config: [
                                                      defaultSymbol: "calendar-week"
                                                      url: "https://calendar.google.com/calendar/ical/Secret_Link_Not_Provided"
                                                      //Get link by going to Google Cal -> Settings -> Select Calendar within
                                                      //'settings for my calendars' -> *Scroll down* -> Intergrate Calendar
                                                      //Copy secret address in iCal format to url section above
                                                      maximumEntries: "14"
                                                      fetchInterval: "3600000" // Update every 60 minutes
                                                      timeFormat: "DD MMM YY"
                              module: "weather",
                                      type: "forecast",
                                      locationID: "4355843",
      				apiKey: "01234567890123a4567e890c1da4e678",
                                      units: "imperial",
                                      roundTemp: "true",
                                      degreeLabel: "true",
                                      updateInterval: "600000" //Updates every minute
                                      timeFormat: "24",
                                      lang: "en",
                                      showHumidity: "true",
                                      showFeelsLike: "true",
                                      showSun: "true",
                                      colored: "true"
                                      showPrecipitationAmount: "true",
                                      //maxNumberOfDays: "3" //Default=5days, max 14
        A Former User
          sdetweil @OlesonCrypto
          @olesoncrypto in the MagicMirror folder do
          the output will report a line number of an error
          unexpected token line 45
          well, look at line 44, and see if it should have a trailing comma (meaning more to follow)
          repeat til no error
          O 2 Replies Last reply Reply Quote 1
          • O Offline
            OlesonCrypto @Guest
            • O Offline
              OlesonCrypto @sdetweil
              @sdetweil So you’re saying delete the commas above the line where it shows I have an unexpected token line?
              O S 2 Replies Last reply Reply Quote 0
              • O Offline
                OlesonCrypto @OlesonCrypto
                  @olesoncrypto no. add. but I see u fixed it
                  • O Offline
                    @sdetweil Hey I just fixed it all up thanks you to! Adding commas a line above the syntax error fixed it. I was so happy to see “Your configuration file doesn’t contain syntax errors :)” lmao. You’re a life safer
                      @olesoncrypto see my MMM-Config module. it presents a form to fill in for config.js. no more commas!!
                      https://github.com/sdetweil/MMM-Config
                      • O Offline
                        @sdetweil I have a new issue. Instead of seeing the original Magic Mirror^2 screen that says “add a config.js file or fix the syntax errors” now only shows a black screen. Both my mmstart.sh and magicmirror is active with my pm2. I also have downloaded chromium-browser. Do you know what might be the cause of this? I’ve downloaded all the module content inside of each module directory with npm.
