    No JavaScript experience - Config.js not working
    16 Posts 3 Posters 7.1k Views 2 Watching
    • O
      OlesonCrypto
      Hey guys, I’ve been running into issues the past week on this config.js file alone. I took out my some of the private links I had for obvious reasons, but I’m mostly concerned with the syntax and actually having this modules show up on my screen. I can see the Magic Mirror^2 on my Raspberry Pi monitor. When running npm run config:check I would keep getting results like: " Parsing error: Unexpected token basePath", “Parsing error: Unexpected token ipWhitelist” & “Parsing error: Unexpected token position”.
      For my setup, I’m using a monitor with the Raspberry Pi4 Model B plugged in via HDMI to MicroHDMI. I have it set up to SSH inside or use the GUI on the RP4 desktop itself. I am able to see the black Magic Mirror^2 screen, in which it asks me to “Please create a config file or check the existing one for errors”. My configuration file is located at ~/MagicMirror/config/config.js. There are no other .js files within my MagicMirror directory.
      Further Notes: I created two static IP’s for my PI: 192.168.1.101 = eth0 & 192.168.1.102 = wlan0. After modifications, I run pm2 restart 1 to restart my MagicMirror. Also I found that nano -c [File_Path] works to find the exact line and column you’re currently on as you move throughout the code.
      /* Magic Mirror Config Sample -- Edited for my project
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
              address: "localhost", "192.168.1.102", "192.168.1.101",  //.101=eth0, .102=wlan0
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              ipWhitelist: ["192.168.1.0/24"],  // Set [] to allow all IP addresses
              useHttps: "false", // Support HTTPS or not, default "false" will use HTTP
              //httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              //httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "en",
              locale: "en-US",
              timeFormat: 24,
              units: "imperial",
                              module: "alert",
                              position:"top_left"
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              module: "MMM-googlecalendar"
                              position: "middle_center"
                              header: "Google Calandar"
                              config: [
                                                      defaultSymbol: "calendar-week"
                                                      url: "https://calendar.google.com/calendar/ical/Secret_Link_Not_Provided"
                                                      //Get link by going to Google Cal -> Settings -> Select Calendar within
                                                      //'settings for my calendars' -> *Scroll down* -> Intergrate Calendar
                                                      //Copy secret address in iCal format to url section above
                                                      maximumEntries: "14"
                                                      fetchInterval: "3600000" // Update every 60 minutes
                                                      timeFormat: "DD MMM YY"
                              module: "weather",
                                      type: "forecast",
                                      locationID: "4355843",
      				apiKey: "01234567890123a4567e890c1da4e678",
                                      units: "imperial",
                                      roundTemp: "true",
                                      degreeLabel: "true",
                                      updateInterval: "600000" //Updates every minute
                                      timeFormat: "24",
                                      lang: "en",
                                      showHumidity: "true",
                                      showFeelsLike: "true",
                                      showSun: "true",
                                      colored: "true"
                                      showPrecipitationAmount: "true",
                                      //maxNumberOfDays: "3" //Default=5days, max 14
        A Former User
        O 1 Reply Last reply
          sdetweil @OlesonCrypto
          @olesoncrypto in the MagicMirror folder do
          the output will report a line number of an error
          unexpected token line 45
          well, look at line 44, and see if it should have a trailing comma (meaning more to follow)
          repeat til no error
          O 2 Replies Last reply
          • O
            OlesonCrypto @Guest
            • O
              OlesonCrypto @sdetweil
              @sdetweil So you’re saying delete the commas above the line where it shows I have an unexpected token line?
              O S 2 Replies Last reply
              • O
                OlesonCrypto @OlesonCrypto
                  @olesoncrypto no. add. but I see u fixed it
                  • O
                    @sdetweil Hey I just fixed it all up thanks you to! Adding commas a line above the syntax error fixed it. I was so happy to see “Your configuration file doesn’t contain syntax errors :)” lmao. You’re a life safer
                      @olesoncrypto see my MMM-Config module. it presents a form to fill in for config.js. no more commas!!
                      https://github.com/sdetweil/MMM-Config
                      • O
                        @sdetweil I have a new issue. Instead of seeing the original Magic Mirror^2 screen that says “add a config.js file or fix the syntax errors” now only shows a black screen. Both my mmstart.sh and magicmirror is active with my pm2. I also have downloaded chromium-browser. Do you know what might be the cause of this? I’ve downloaded all the module content inside of each module directory with npm.
                          @olesoncrypto this is typically caused by a missing library.
                          we removed some, and it turns out modules didn’t document using them
                          look at the pm2 log
                          command
                          pm2 logs --lines=100
                          looking for module not found.
                          for each of those, go to the module folder
                          if there is NOT a package.json file do
                          npm init -y
                          then in either case do
                          npm install xxx -- save
                          where xx is the name of the not found thing
                          we know about
                          request
                          rrule-alt
                          and
                          valid-url
                          then restart mm
                          • O
                            0|mmstart  | /home/pi/MagicMirror/js/app.js:20
                            0|mmstart  | Log.log("Starting MagicMirror: v" + global.version);
                            0|mmstart  |     ^
                            0|mmstart  | TypeError: Log.log is not a function
                            I’m not sure how to fix this one. I nano’d into the file and they show a bunch of these log.log within the app.js file
                              @olesoncrypto yeh, its provided by the logger
                              so,
                              give me output of
                              node -v
                              and npm -v
                              if u rename your config.js to save.config.js (mv is the rename command in lnux)
                              and copy the sample.config.js to config.js (in the config folder)
                              does it work ?
                              • O
                                @sdetweil I was able to finally make it work! I just completed deleted the MagicMirror with sudo rm -r ~/MagicMirror and then reinstalled it. I copied the config.js.sample to my real config.js file. I ran that and it finally worked! I was fixing it up and then it happened again as I was imputing parts of my old code. I realized that my issue was that I had the useHTTPs: "false", instead of useHTTPs: false, which was the real reason there was just a blank screen. I appreciate your time and effort to help me out, especially with the fast responses. You’re a true life saver @sdetweil :)
                                  @olesoncrypto awesome, glad u got it working
                                    @olesoncrypto yes, that will get you
                                    general rules for config.js
                                    the thing to the left of :  does not need quotes
                                    for the thing to the right of :
                                          if it is a number (9, -1.234) or true/false  , no quotes
                                          if it contains a letter 12ff234, bob,   then needs quotes,
                                    single or double doesn't matter  as long as they are the same start and end
                                    every { needs a  matching }
                                    every [ needs a  matching ]
                                    [] is a list [ 1,2,3,4] or [ first,second,third]
                                    {} is a structure/object with name/value pairs
                                        {    x: value, y: othervalue }
                                    u can write lists and objects all on one line (what a pain)
                                    or across multiple lines... (much more readable)
                                        BUT, you STILL need the commas between items in either
                                    if u get an error, unexpected token, 99% of the time,
                                    u forgot a trailing comma on the line ABOVE the one reported (error on line 45, look at line 44)
                                    a good debug process is to join the list or object to a single line in your editor,
                                     and get the , between the items, then split it again after each comma...
                                    so u have a separate item on each line.
