    Updated to 2.17 but MM not launching
    28 Posts 5 Posters 11.5k Views 5 Watching
    • O
      OberfragGER @sdetweil
      @sdetweil Uuups.
      Sorry for the “short” information. I did´nt realised that i sent the topic.
      Both “MMM-SystemStats” seems to unmantained and both are stopping MM from starting. I just uncommented them in the config.js and openend an issue.
      /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | at require
      (internal/modules/cjs/helpers.js:88:18) 0|mm | at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-SystemS tats/node_helper.js:13:15) 0|mm | at Module._compile (internal/modules/cjs/loader.js:1078:30) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.j s:1108:10) { 0|mm | code: 'MODULE_NOT_FOUND', 0|mm | requireStack: [ 0|mm | '/home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js', 0|mm | '/home/pi/MagicMirror/js/app.js', 0|mm | '/home/pi/MagicMirror/js/electron.js', 0|mm | '/home/pi/MagicMirror/node_modules/electron/dist/resources/defa ult_app.asar/main.js', 0|mm | undefined 0|mm | ] 0|mm | } 0|mm | [04.10.2021 13:13.47.982] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [04.10.2021 13:13.47.982] [ERROR] If you think this really is an is sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss ues
      I dont have any clus what i cloud do more.
        sdetweil @OberfragGER
        @oberfragger it says module not found
        we deleted a bunch of older libraries because one was discontinued (deprecated) due to a security problem not going to be fixed
        many mm modules used them but didn’t document the usage. oops
        I don’t see the name of the library
        but looking at the node_helper.js shows
        require('request')
        which is the trouble lib
        u can add it back for this module , do
        npm init -y
        npm install request -- save
        O StoffbeuteluweS 2 Replies Last reply
        • O
          @sdetweil said in Updated to 2.17 but MM not launching:
          Thanks a lot. That did the job for me!
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor @sdetweil
            Hi Sam, i have to do this for 11 modules :grinning_face_with_big_eyes: …but that’s not the problem it takes a little time…but do I have to do all this again on every next MM Update?:dizzy_face:
            Greeting from Germany
            StoffbeuteluweS S 2 Replies Last reply
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
              The Mirror works but there are some errors…
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'cat' of module exports inside circular dependency
              (Use `Electron --trace-warnings ...` to show where the warning was created)
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'cd' of module exports inside circular dependency
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'chmod' of module exports inside circular dependency
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'cp' of module exports inside circular dependency
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'dirs' of module exports inside circular dependency
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'pushd' of module exports inside circular dependency
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'popd' of module exports inside circular dependency
              [14.10.2021 21:09.11.218] [ERROR] (node:48778) Warning: Accessing non-existent property 'echo' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'tempdir' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'pwd' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'exec' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'ls' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'find' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'grep' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'head' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'ln' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'mkdir' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'rm' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'mv' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'sed' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'set' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'sort' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'tail' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'test' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'to' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'toEnd' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'touch' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'uniq' of module exports inside circular dependency
              [14.10.2021 21:09.11.219] [ERROR] (node:48778) Warning: Accessing non-existent property 'which' of module exports inside circular dependency
                sdetweil @Stoffbeuteluwe
                @stoffbeuteluwe said in Updated to 2.17 but MM not launching:
                if you do the
                npm init
                in the module folder before npm install request (or whatever is missing)
                then that library will be loaded in the module node_modules list
                if NOT, then it looks for the 1st node_modules folder up the directory tree , finds one under MagicMirror and installs the module there
                BUT…
                on the next update, npm will check and see that this library was not required by MM, and so delete it, (security, so someone can’t sneak libraries into the installed folder)…
                so… answer to your question is ‘maybe’…
                  how did u do the upgrade?
                  can u tell me
                  node -v
                  npm -v
                  output?
                  this version of electron needs node 14. my script does NOT upgrade node
                  • StoffbeuteluweS
                    @sdetweil when I’m home from work I will tell you….thanks in advance
                    • StoffbeuteluweS
                      @sdetweil Hi…
                      git pull & npm install
                      node -v v14.17.3
                      npm -v 6.14.13
                        @stoffbeuteluwe ok, thx… did u use my upgrade script?
                        if not, I would go thru every module (not defaults) and look for package.json
                        if present, in the module folder I would
                        rm package-lock.json
                        rm -rf node_modules
                        npm install
                        to reload the dependencies based on the new MM.
                        (this is what my upgrade script does)
                        after that, I would disable one module at a time to find the culprit…
                        StoffbeuteluweS 1 Reply Last reply
                        • StoffbeuteluweS
                          npm install
                          Ok thank you Sam i will try…
                            @stoffbeuteluwe u could use my upgrade script with force
                            to accomplish the same thing
                            I would disable modules to find it first, and then check after redoing npm install
                            • StoffbeuteluweS
                              @sdetweil do you think the error came from a module?
                                @stoffbeuteluwe don’t know, but think so
                                • StoffbeuteluweS
                                  @sdetweil thanks …will try to find it
                                  • StoffbeuteluweS
                                    @sdetweil Sooo:grinning_face_with_big_eyes: after long searching …I know it is the MMM-AlexaControl module but what does the error mean and what can I do?
                                      @stoffbeuteluwe did u try the recovery steps I provided before, in the module folder
                                      delete a file
                                      delete a folder
                                      npm install
                                      • StoffbeuteluweS
                                        @sdetweil Hi , yes I have done that and done a new install but the same error …but it works fine :man_shrugging_medium_skin_tone:
                                          @stoffbeuteluwe ok. I don’t remember seeing that on my setup. will check
                                            @stoffbeuteluwe i just reinstalled AC
                                            and see the same error… its a problem in a library used by a library that the module uses.
                                            nothing u can do to fix it…
