    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.9k Views 31 Watching
    • uros76U
      uros76 @sdetweil
      Hi. I am trying to implement it on my MM and get only get below header in the browser. I am trying to open it with this address http://raspberrypi:8080/modules/MMM-Config/review
      The same happens if I open MM via IP address.
      Did I miss something? I saw on page6 of this thread someone else had same problem but that solution didn’t help me.
      Doing ctrl+shift+I and looking at console output I get this error:
      S 2 Replies Last reply
        sdetweil @uros76
        @uros76 can u show me the config.js for the module?
        does it show on the MM screen?
        is your config.js address:“localhost”
        if so, you can only access from the PI system itself (localhost means only apps INSIDE the pi can access that app)
        uros76U 1 Reply Last reply
          sdetweil @uros76
          @uros76 ok, can u send me config.js and the defaults.js from the MMM-Config folder…
          have to rename them to .txt to add as attachments
          via email…to my same userid at gmail…
          • uros76U
            uros76 @sdetweil
            @sdetweil yes the module shows on screen in form of QR code. That part works.
            My basics from config file:
            address: "0.0.0.0",
            useHttps: false,
            port: 8080,
            ipWhitelist: [],
            • uros76U
              uros76 @sdetweil
              @sdetweil ok will send you now…
                sdetweil @uros76
                @uros76 thanks… there was probably an error reported in the console where u do npm start (or pm2 logs if using pm2)
                  sdetweil @uros76
                  @uros76 posted a fix, sent email back
                  • uros76U
                    uros76 @sdetweil
                    @sdetweil it works! Mega quick assistance. Tnx
                    • F
                      Fonzi03
                      i too am getting the blank homescreen which only shows
                      “configure magic mirror and modules”
                      it wont let me upload the jsconfig or default config here how can i send them?
                        sdetweil @Fonzi03
                        @fonzi03 send to my same userid at gmail. have to rename them to .txt instead of .js to attach to email
                          sdetweil @Fonzi03
                          @fonzi03 i sent email back
                            Dinschal
                            I’m not able to pull your module from github. I got this error.
                            Greetings
                              sdetweil @Dinschal
                              @dinschal hm… I don’t see that
                              rename the module folder and and git clone again
                              then delete the old folder
                                Dinschal
                                There is no module folder…
                                Okay everything fine… i have to go to bed :D my fault sry :D
                                Change pull to clone and it works ;) too much code today.
                                I’m really sorry :(
                                  sdetweil @Dinschal
                                  @dinschal huh?
                                  ah, I see… to get the 1ST copy you use
                                  git clone
                                  to UPDATE later you do
                                  git pull
                                  with no extra parms…
                                  see the two topics in my signature… I didn’t write em, but they are helpful
                                  D 1 Reply Last reply
                                    Dinschal @sdetweil
                                    @sdetweil thanks a lot… sometimes this is the best time to go to bed :D
                                    my brain isnt working much longer today :D
                                      sdetweil @Dinschal
                                      @dinschal I’ve been there… get some rest
                                        Dinschal @sdetweil
                                        first of all… my english is very bad :D
                                        today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
                                        So i have to change the localhost in my config :D
                                        I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
                                          sdetweil @Dinschal
                                          @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                          I tired to read the error message but its to tiny the only thing i can read is localhost
                                          what error message?
                                          u mean the module output when address:“localhost” is set??
                                          localhost means ONLY apps running inside the SAME system can access
                                          so a phone (use the qr code) , or another computer (use the url) cannot…
                                            Dinschal @sdetweil
                                            @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
                                            I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
                                            • 14
                                            • 15
                                            • 5 / 15
