    Could not load config file.
    3 Posts 2 Posters 1.2k Views 2 Watching
    • 0 Offline
      01ZerosOnes01
      I hope someone can help with this error.
      This is a new installation on a Raspberry Pi 4 2GB
      Latest Buster OS and MagicMirror v2.17.1
      I am getting this and other similar errors with certain Third Party modules. I have tried the manual and script install of MagicMirror.
      Same errors.
      Any help would be greatly appreciated.
      This is the error using the MMM-MyScoreboard module.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘json-parse-async’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-MyScoreboard/providers/SNET.js
      • /home/pi/MagicMirror/modules/MMM-MyScoreboard/node_helper.js
      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai
        sdetweil @01ZerosOnes01
        @01zerosones01 said in Could not load config file.:
        looks like you didn’t do step 2 of the module install
        MMM-MyScoreboard/
        • 0 Offline
          01ZerosOnes01
          Thanks so much for your help. That was my mistake. I didn’t run the command (npm install) inside the MMM-MyScoreboard folder.
          Thank you. That did it.
