    MM Config File not matching Dashboard
    10 Posts 2 Posters 1.0k Views 2 Watching
      sdetweil @droidus
      @droidus if it has an error it falls back to the default
      minimize mm.
      alt-spacebar, n
      open a terminal window,
      ctrl-alt-t
      pm2 stop all
      npm start >somefile.txt
      wait 15 seconds
      ctrl-c to stop
      nano somefile.txt
      scroll down look for errors
      ctrl-x to exit nano
        droidus @sdetweil
        > magicmirror@2.16.0 start /home/pi/MagicMirror
        > ./run-start.sh $1
        [29.10.2021 11:04.03.983] [LOG]   Starting MagicMirror: v2.16.0
        [29.10.2021 11:04.03.988] [LOG]   Loading config ...
        [29.10.2021 11:04.03.994] [LOG]   Loading module helpers ...
        [29.10.2021 11:04.03.996] [LOG]   No helper found for module: alert.
        [29.10.2021 11:04.04.163] [LOG]   Initializing new module helper ...
        [29.10.2021 11:04.04.164] [LOG]   Module helper loaded: updatenotification
        [29.10.2021 11:04.04.164] [LOG]   No helper found for module: clock.
        [29.10.2021 11:04.04.345] [LOG]   Initializing new module helper ...
        [29.10.2021 11:04.04.346] [LOG]   Module helper loaded: calendar
        [29.10.2021 11:04.04.346] [LOG]   No helper found for module: compliments.
        [29.10.2021 11:04.04.347] [LOG]   No helper found for module: weather.
        [29.10.2021 11:04.04.372] [LOG]   Initializing new module helper ...
        [29.10.2021 11:04.04.373] [LOG]   Module helper loaded: newsfeed
        [29.10.2021 11:04.04.373] [LOG]   All module helpers loaded.
        [29.10.2021 11:04.04.465] [LOG]   Starting server on port 8080 ...
        [29.10.2021 11:04.04.479] [LOG]   Server started ...
        [29.10.2021 11:04.04.480] [LOG]   Connecting socket for: updatenotification
        [29.10.2021 11:04.04.481] [LOG]   Connecting socket for: calendar
        [29.10.2021 11:04.04.482] [LOG]   Starting node helper for: calendar
        [29.10.2021 11:04.04.482] [LOG]   Connecting socket for: newsfeed
        [29.10.2021 11:04.04.483] [LOG]   Starting node helper for: newsfeed
        [29.10.2021 11:04.04.483] [LOG]   Sockets connected & modules started ...
        [29.10.2021 11:04.04.757] [LOG]   Launching application.
        [29.10.2021 11:04.06.997] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        [29.10.2021 11:04.07.068] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        [29.10.2021 11:04.07.534] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
        [29.10.2021 11:04.08.232] [INFO]  Newsfeed-Fetcher: Broadcasting 51 items.
          sdetweil @droidus
          @droidus ok, tell me more
          where is the config.js u modified? should be ~/MagicMirror/config/config.js
          u are running this on raspi OS
          and NOT using MagicMirrorOS, right?
            droidus @sdetweil
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            pi@raspberrypi:~/MagicMirror/config $ ls
            config.js  config.js.sample
              sdetweil @droidus
              @droidus only reason it fails is if some syntax error
              in the mm folder do
              npm run config:check
                droidus @sdetweil
                @sdetweil said in MM Config File not matching Dashboard:
                > magicmirror@2.16.0 config:check /home/pi/MagicMirror
                > node js/check_config.js
                [29.10.2021 11:40.35.104] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                [29.10.2021 11:40.35.173] [INFO]  Your configuration file doesn't contain syntax errors :)
                EDIT:
                Here is my config file:
                /* Magic Mirror Config Sample
                 * By Michael Teeuw https://michaelteeuw.nl
                 * MIT Licensed.
                 * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                 * and https://docs.magicmirror.builders/modules/configuration.html
                let config = {
                	address: "localhost", 	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                	language: "en",
                	locale: "en-US",
                	timeFormat: 12,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			clockBold: "true",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                			module: "compliments",
                			position: "lower_third",
                				morning: [
                					"Good Morning, name!"
                				afternoon: [
                					"Good Afternoon, name!"
                				evening: [
                					"Good Evening, name!"
                				"....-01-01": [
                					"Happy New Year, name!"
                			module: "weather",
                				type: "current",
                				locationID: "x", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: "x",
                				units: "imperial",
                				tempUnits: "imperial",
                				windUnits: "imperial",
                				timeFormat: "12",
                				tableClass: "large",
                				colored: "true"
                 			module: "weather",
                 			header: "Weather Forecast",
                 				type: "forecast",
                 				apiKey: "x"
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                S D 2 Replies Last reply Reply Quote 0
                  sdetweil @droidus
                  @droidus in my car but incorrect config for clock and compliments
                    droidus @droidus
                    I just found the issue… It is using /home/pi/MagicMirror/modules/default/compliments/compliments.js instead of the config.js file defined compliments…
                    How do I have it use the compliments in the config.js file?
                      sdetweil @droidus
                      @droidus use the correct syntax…
                       module:
                      config:{
                              compliments:
                                        what u have
                      from the documentation
                      	compliments: {
                      		day_sunny: [
                      			"Today is a sunny day",
                      			"It's a beautiful day"
                      		snow: [
                      			"Snowball battle!"
                      		rain: [
                      			"Don't forget your umbrella"
