    MM Config File not matching Dashboard
    10 Posts 2 Posters 993 Views 2 Watching
      droidus @sdetweil
      > magicmirror@2.16.0 start /home/pi/MagicMirror
      > ./run-start.sh $1
      [29.10.2021 11:04.03.983] [LOG]   Starting MagicMirror: v2.16.0
      [29.10.2021 11:04.03.988] [LOG]   Loading config ...
      [29.10.2021 11:04.03.994] [LOG]   Loading module helpers ...
      [29.10.2021 11:04.03.996] [LOG]   No helper found for module: alert.
      [29.10.2021 11:04.04.163] [LOG]   Initializing new module helper ...
      [29.10.2021 11:04.04.164] [LOG]   Module helper loaded: updatenotification
      [29.10.2021 11:04.04.164] [LOG]   No helper found for module: clock.
      [29.10.2021 11:04.04.345] [LOG]   Initializing new module helper ...
      [29.10.2021 11:04.04.346] [LOG]   Module helper loaded: calendar
      [29.10.2021 11:04.04.346] [LOG]   No helper found for module: compliments.
      [29.10.2021 11:04.04.347] [LOG]   No helper found for module: weather.
      [29.10.2021 11:04.04.372] [LOG]   Initializing new module helper ...
      [29.10.2021 11:04.04.373] [LOG]   Module helper loaded: newsfeed
      [29.10.2021 11:04.04.373] [LOG]   All module helpers loaded.
      [29.10.2021 11:04.04.465] [LOG]   Starting server on port 8080 ...
      [29.10.2021 11:04.04.479] [LOG]   Server started ...
      [29.10.2021 11:04.04.480] [LOG]   Connecting socket for: updatenotification
      [29.10.2021 11:04.04.481] [LOG]   Connecting socket for: calendar
      [29.10.2021 11:04.04.482] [LOG]   Starting node helper for: calendar
      [29.10.2021 11:04.04.482] [LOG]   Connecting socket for: newsfeed
      [29.10.2021 11:04.04.483] [LOG]   Starting node helper for: newsfeed
      [29.10.2021 11:04.04.483] [LOG]   Sockets connected & modules started ...
      [29.10.2021 11:04.04.757] [LOG]   Launching application.
      [29.10.2021 11:04.06.997] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [29.10.2021 11:04.07.068] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [29.10.2021 11:04.07.534] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
      [29.10.2021 11:04.08.232] [INFO]  Newsfeed-Fetcher: Broadcasting 51 items.
        sdetweil @droidus
        @droidus ok, tell me more
        where is the config.js u modified? should be ~/MagicMirror/config/config.js
        u are running this on raspi OS
        and NOT using MagicMirrorOS, right?
          droidus @sdetweil
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          pi@raspberrypi:~/MagicMirror/config $ ls
          config.js  config.js.sample
            sdetweil @droidus
            @droidus only reason it fails is if some syntax error
            in the mm folder do
            npm run config:check
              droidus @sdetweil
              @sdetweil said in MM Config File not matching Dashboard:
              > magicmirror@2.16.0 config:check /home/pi/MagicMirror
              > node js/check_config.js
              [29.10.2021 11:40.35.104] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
              [29.10.2021 11:40.35.173] [INFO]  Your configuration file doesn't contain syntax errors :)
              EDIT:
              Here is my config file:
              /* Magic Mirror Config Sample
               * By Michael Teeuw https://michaelteeuw.nl
               * MIT Licensed.
               * see https://docs.magicmirror.builders/getting-started/configuration.html#general
               * and https://docs.magicmirror.builders/modules/configuration.html
              let config = {
              	address: "localhost", 	// Address to listen on, can be:
              	port: 8080,
              	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
              	language: "en",
              	locale: "en-US",
              	timeFormat: 12,
              	units: "metric",
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			clockBold: "true",
              			position: "top_left"
              			header: "US Holidays",
              						symbol: "calendar-check",
              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
              			module: "compliments",
              			position: "lower_third",
              				morning: [
              					"Good Morning, name!"
              				afternoon: [
              					"Good Afternoon, name!"
              				evening: [
              					"Good Evening, name!"
              				"....-01-01": [
              					"Happy New Year, name!"
              			module: "weather",
              				type: "current",
              				locationID: "x", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              				apiKey: "x",
              				units: "imperial",
              				tempUnits: "imperial",
              				windUnits: "imperial",
              				timeFormat: "12",
              				tableClass: "large",
              				colored: "true"
               			module: "weather",
               			header: "Weather Forecast",
               				type: "forecast",
               				apiKey: "x"
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
              S D 2 Replies Last reply Reply Quote 0
                sdetweil @droidus
                @droidus in my car but incorrect config for clock and compliments
                  droidus @droidus
                  I just found the issue… It is using /home/pi/MagicMirror/modules/default/compliments/compliments.js instead of the config.js file defined compliments…
                  How do I have it use the compliments in the config.js file?
                    sdetweil @droidus
                    @droidus use the correct syntax…
                     module:
                    config:{
                            compliments:
                                      what u have
                    from the documentation
                    	compliments: {
                    		day_sunny: [
                    			"Today is a sunny day",
                    			"It's a beautiful day"
                    		snow: [
                    			"Snowball battle!"
                    		rain: [
                    			"Don't forget your umbrella"
