    Auto power on and off
    14 Posts 10 Posters 10.0k Views 9 Watching
    • BKeyportB
      BKeyport Module Developer
      If you use a time switch to turn on and off the entire construction, you should still have a crontab to shut down the pi prior to shutting down the power, so you don’t corrupt your media.
      • thgmirrorT
        thgmirror
        Yes, @BKeyport idea is highly recommended:-)
        • E
          ember1205
          I have a WiFi plug that switches the device on at a specific time in the morning.
          I use a cron job entry to shut the Pi down at a specific time at night.
          I have the WiFi plug turn off at a specific time at night, five minutes after the time I’ve configured the cron job to shut the Pi down.
          There is also an IFTTT integration where you can have the shutdown script make a specific call to create a calendar entry on a Google calendar and IFTTT will pick up that entry and use it to trigger the power-off event for the plug. I used to do this until IFTTT changed their account structure and I’ve been moving away from using any of their integrations.
          • N
            natebrown @garbleflux
            @garbleflux
            Thanks, so i want it to turn on at 6:30 every morning and turn off at 9 every night, If i copy and paste that into crontab -e, will that work? What is the exact code i need?
            • H
              hamid
              I did not test with there are motion detectors that turn on the screen when moving the front screen does not know how it works
              https://www.swedx.se/product_info.php?cPath=137_12800030&products_id=1955
              rejasR 1 Reply Last reply
              • T
                TJuTZu
                You can use also MMM-ModuleScheduler with MMM-Remote-Control to turn monitor on/off if you don’t need to turn off the whole system.
                It works similar to crontab
                Here is example from my mirror configuration
                      module: 'MMM-Remote-Control'
                      // , position: 'bottom_left'
                        module: 'MMM-ModuleScheduler',
                            notification_schedule: [
                                // TURN THE MONITOR/SCREEN ON At 10:00
                                {notification: 'REMOTE_ACTION', schedule: '00 10 * * *', payload: {action: "MONITORON"}},
                                // TURN THE MONITOR/SCREEN OFF At 00:00
                                {notification: 'REMOTE_ACTION', schedule: '00 00 * * *', payload: {action: "MONITOROFF"}}
                • BKeyportB
                  If you wanna go down that path, there’s MMM-Remote-Control, too.
                  • rejasR
                    rejas Module Developer @hamid
                    @hamid you can use a standard webcam (like the pi cam or a playstation camera like I do) and my module https://github.com/rejas/MMM-MotionDetector to detect motion and turn your monitor off and on.
                      Socrates @BKeyport
                      @bkeyport said in Auto power on and off:
                      I was looking at the option of turning off the monitor instead the rpi.
                      I have the MMM-Remote-Control installed, but i dont see a way to turn off the monitor automatically, there’s an option to turn on and off the monitor and it works well, but how do i automate it?
                        sdetweil @Socrates
                        @socrates I use a webcam and turn off the monitor, motion turns it back on.
                        some use IR (PIR) sensors to detect people heat and turn on…
                          Socrates @sdetweil
                          @sdetweil Thank you. I have Home Assistant in place, the only gripe is that I wont have enough space between the mm frame and the outlet to shove another smart outlet. I guess i will need to replace the single gang smart outlet.
