    MMM-Canvas and MMM-Stocks not working
    13 Posts 2 Posters 3.8k Views 2 Watching
    • G Offline
      Gabe21
      Hi! I’m new to the raspberry pi. I’m using the MMM-Pages to have 2 pages that the mirror cycles through. I installed the MMM-Canvas and MMM-Stocks to add to the second page. When I try to launch the mirror it shows a black screen and on the tab it shows “Electron”. When I comment out both the Canvas and Stocks module it works fine. What am I doing wrong?
      Thank you in advance!
        sdetweil @Gabe21
        @gabe21 https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
        probably
        • G Offline
          Gabe21 @sdetweil
          @sdetweil I’m doing it and I get this:
          pi@raspberrypi:~ $ npm init -y
          Wrote to /home/pi/package.json:
            "name": "pi",
            "version": "1.0.0",
            "description": "",
            "main": "index.js",
            "scripts": {
              "test": "echo \"Error: no test specified\" && exit 1"
            "keywords": [],
            "author": "",
            "license": "ISC"
          pi@raspberrypi:~ $ npm install MMM-Canvas
          npm ERR! code E404
          npm ERR! 404 Not Found - GET https://registry.npmjs.org/MMM-Canvas - Not found
          npm ERR! 404
          npm ERR! 404  'MMM-Canvas@latest' is not in the npm registry.
          npm ERR! 404 Your package name is not valid, because
          npm ERR! 404  1. name can no longer contain capital letters
          npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, http url, or git url.
          npm ERR!     /home/pi/.npm/_logs/2021-10-31T18_07_21_746Z-debug.log
          S G 2 Replies Last reply Reply Quote 0
            sdetweil @Gabe21
            @gabe21 in the module folder that is causing the problem
            cd MagicMirror/modules/MMM-Canvas
            THEN the commands
            from the text of the post
            to fix this you need to install the library in the module folder
            • G Offline
              Gabe21 @Gabe21
              @gabe21 I tried that it is says
              pi@raspberrypi:~/MagicMirror/modules/MMM-Canvas $ npm init -y
              Wrote to /home/pi/MagicMirror/modules/MMM-Canvas/package.json:
                "name": "MMM-Canvas",
                "version": "1.0.0",
                "description": "This is a module for `MagicMirror²` which displays upcoming assignments from the Canvas LMS. The Canvas LMS is used by colleges, universities and other institutions for coursework.",
                "main": "MMM-Canvas.js",
                "scripts": {
                "repository": {
                  "type": "git",
                  "url": "git+https://github.com/chase-cromwell/MMM-Canvas.git"
                "keywords": [],
                "author": "",
                "license": "ISC",
                "bugs": {
                  "url": "https://github.com/chase-cromwell/MMM-Canvas/issues"
                "homepage": "https://github.com/chase-cromwell/MMM-Canvas#readme"
              pi@raspberrypi:~/MagicMirror/modules/MMM-Canvas $ npm install MMM-Canvas
              npm ERR! code E404
              npm ERR! 404
              npm ERR! 404
              npm ERR!     /home/pi/.npm/_logs/2021-10-31T18_19_03_220Z-debug.log
                sdetweil @Gabe21
                @gabe21 after you do the npm init
                then u need to add the missing library
                request
                valid-url
                or whatever
                npm install XXX
                where XXX is one of the above, as needed by the messages shown in the MM startup messages
                • G Offline
                  Gabe21 @sdetweil
                  @sdetweil Sorry I’m pretty new to the raspberry-where would I get the missing library from?
                    @gabe21 said in MMM-Canvas and MMM-Stocks not working:
                    the messages output by MM starting up
                    you either did
                    npm start
                    and it spews out messages
                    or you used pm2
                    and it captures the messages
                    pm2 logs --lines=??? (default 15) will show the messages
                    you are looking for
                    cannot find module xxx
                    • G Offline
                      Gabe21 @sdetweil
                      code: 'MODULE_NOT_FOUND',
                        requireStack: [
                          '/home/pi/MagicMirror/modules/MMM-Canvas/node_helper.js',
                          '/home/pi/MagicMirror/js/app.js',
                          '/home/pi/MagicMirror/js/electron.js',
                          '/code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      So
                      npm install /home/pi/MagicMirror/modules/MMM-Canvas/node_helper.js
                        sdetweil @Gabe21
                        @gabe21 no… up further in the messages
                        before
                          requireStack: [
