    MMM-Canvas and MMM-Stocks not working
    13 Posts 2 Posters 3.8k Views 2 Watching
      sdetweil @Gabe21
      @gabe21 in the module folder that is causing the problem
      cd MagicMirror/modules/MMM-Canvas
      THEN the commands
      from the text of the post
      to fix this you need to install the library in the module folder
      • G Offline
        Gabe21 @Gabe21
        @gabe21 I tried that it is says
        pi@raspberrypi:~/MagicMirror/modules/MMM-Canvas $ npm init -y
        Wrote to /home/pi/MagicMirror/modules/MMM-Canvas/package.json:
          "name": "MMM-Canvas",
          "version": "1.0.0",
          "description": "This is a module for `MagicMirror²` which displays upcoming assignments from the Canvas LMS. The Canvas LMS is used by colleges, universities and other institutions for coursework.",
          "main": "MMM-Canvas.js",
          "scripts": {
            "test": "echo \"Error: no test specified\" && exit 1"
          "repository": {
            "type": "git",
            "url": "git+https://github.com/chase-cromwell/MMM-Canvas.git"
          "keywords": [],
          "author": "",
          "license": "ISC",
          "bugs": {
            "url": "https://github.com/chase-cromwell/MMM-Canvas/issues"
          "homepage": "https://github.com/chase-cromwell/MMM-Canvas#readme"
        pi@raspberrypi:~/MagicMirror/modules/MMM-Canvas $ npm install MMM-Canvas
        npm ERR! code E404
        npm ERR! 404 Not Found - GET https://registry.npmjs.org/MMM-Canvas - Not found
        npm ERR! 404
        npm ERR! 404  'MMM-Canvas@latest' is not in the npm registry.
        npm ERR! 404 Your package name is not valid, because
        npm ERR! 404  1. name can no longer contain capital letters
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR!     /home/pi/.npm/_logs/2021-10-31T18_19_03_220Z-debug.log
          sdetweil @Gabe21
          @gabe21 after you do the npm init
          then u need to add the missing library
          request
          valid-url
          or whatever
          npm install XXX
          where XXX is one of the above, as needed by the messages shown in the MM startup messages
          • G Offline
            Gabe21 @sdetweil
            @sdetweil Sorry I’m pretty new to the raspberry-where would I get the missing library from?
              @gabe21 said in MMM-Canvas and MMM-Stocks not working:
              the messages output by MM starting up
              you either did
              npm start
              and it spews out messages
              or you used pm2
              and it captures the messages
              pm2 logs --lines=??? (default 15) will show the messages
              you are looking for
              cannot find module xxx
              • G Offline
                Gabe21 @sdetweil
                code: 'MODULE_NOT_FOUND',
                  requireStack: [
                    '/home/pi/MagicMirror/modules/MMM-Canvas/node_helper.js',
                    '/home/pi/MagicMirror/js/app.js',
                    '/home/pi/MagicMirror/js/electron.js',
                    '/code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                So
                npm install /home/pi/MagicMirror/modules/MMM-Canvas/node_helper.js
                  sdetweil @Gabe21
                  @gabe21 no… up further in the messages
                  before
                    requireStack: [
                  • G Offline
                    Gabe21 @sdetweil
                    @sdetweil Sorry, I’m a bit confused. Wouldn’t it just be npm install MMM-Canvas then? Since canvas is the module that it can’t find…
                    Sorry again
                      sdetweil @Gabe21
                      @gabe21
                      no… IN the MMM-Canvas folder
                      it is
                      npm install request
                      or
                      npm install valid-url
                      or
                      npm install ???
                      whatever other lib might be missing…
                      u have to read the messages to get the name of the missing thing
                      from someone else’s same problem
                      [31.10.2021 20:10.49.037] [ERROR] App threw an error during load
                      [31.10.2021 20:10.49.039] [ERROR] Error: Cannot find module  'request'  <----------------------------
                      Require stack:
                      - /home/pi/MagicMirror/modules/MMM-NetworkConnection/node_modules/lzma-native/index.js
                      • G Offline
                        Gabe21 @sdetweil
                        @sdetweil Ohh. Now I get it, works too!
                        Thank you so much and sry about that.
