    MMM-EARTH-Live & MMM-ISS-Live
    Scheduled Pinned Locked Moved Education
    47 Posts 13 Posters 31.7k Views 14 Watching
      sdetweil @ruskythegreat
      @ruskythegreat that string needs quotes
      in JavaScript
      the thing to the left of : does not need quotes
      if the thing to the right is a number or true/false
      no quotes
      if the thing to the right is a symbol { or [ no quotes
      otherwise
      if it contains letters, it needs quotes.
      single or double does matter as long as they are the same on both ends
      R 1 Reply Last reply
        ruskythegreat @sdetweil
        Sorry, I did try that but forgot to update the post!
        It currently reads: -
        autoplayPolicy: “no-user-gesture-required”
        But still doesn’t autoplay
          @ruskythegreat yes, I mentioned that others had found the same issue…
          try this one thing, (I don’t think it will help but)
          clear the Electron config folder, will be recreated on next electron startup
          (zoom setting is saved here somewhere)
          stop MagicMirror
          rm .rf ~/.config/Electron
          start MagicMirror
            @sdetweil No change ;(
              @ruskythegreat yes, and the doc says it defaults
               Defaults to no-user-gesture-required.
              it would be interesting if you used chromium instead , if your config says
              address:"0.0.0.0",
              then try from any other system
              http://pi_address:MM_port
                ruskythegreat
                @sdetweil It doesn’t work from Chrome 95.0.4638.54
                  @ruskythegreat boooooo
                  • 3 / 3
