    MMM-EARTH-Live & MMM-ISS-Live
    Scheduled Pinned Locked Moved Education
    47 Posts 13 Posters 30.5k Views 14 Watching
      sdetweil @ruskythegreat
      @ruskythegreat i understand… did u try to change the code to the new webPreferences object parm?
      in general they are stopping autoplay because customers are screaming at them (I hate it too in general purpose use)…
        ruskythegreat @sdetweil
        @sdetweil No, Sorry, I’m not familiar with the webPreferences object param Can I trouble you to ELI5 :)
          @ruskythegreat there is already a WebPreferences object in the electron.js file, just down a few lines from your change.
          line 30
          look at the doc link for autoplay, to get the right syntax/spelling
          and add the key and value to the WebPreferences object
            @sdetweil Thanks for all your help with this.
            It’s still not autoplaying :(
            I tried with the autoplayPolicy with the no-user-gesture-required so: -
            autoplayPolicy: no-user-gesture-required,
            C&P to eliminate typos!
            So now the whole webpreferences entry reads: -
                        webPreferences: {
                                contextIsolation: true,
                                nodeIntegration: false,
                                zoomFactor: config.zoom
            But MM doesn’t start!
              @ruskythegreat that string needs quotes
              in JavaScript
              the thing to the left of : does not need quotes
              if the thing to the right is a number or true/false
              no quotes
              if the thing to the right is a symbol { or [ no quotes
              otherwise
              if it contains letters, it needs quotes.
              single or double does matter as long as they are the same on both ends
                Sorry, I did try that but forgot to update the post!
                It currently reads: -
                autoplayPolicy: “no-user-gesture-required”
                But still doesn’t autoplay
                  @ruskythegreat yes, I mentioned that others had found the same issue…
                  try this one thing, (I don’t think it will help but)
                  clear the Electron config folder, will be recreated on next electron startup
                  (zoom setting is saved here somewhere)
                  stop MagicMirror
                  rm .rf ~/.config/Electron
                  start MagicMirror
                    @sdetweil No change ;(
                      @ruskythegreat yes, and the doc says it defaults
                       Defaults to no-user-gesture-required.
                      it would be interesting if you used chromium instead , if your config says
                      address:"0.0.0.0",
                      then try from any other system
                      http://pi_address:MM_port
                        ruskythegreat
                        @sdetweil It doesn’t work from Chrome 95.0.4638.54
                          @ruskythegreat boooooo
                          • 3 / 3
