    MM fails to start after update
    7 Posts 2 Posters 2.0k Views 2 Watching
      requiemmg
      after running @sdetweil’s upgrade script to upgrade from 2.13 to 2.17, my MM is not starting anymore. I cannot run it again (says that I am up to date) and I don’t know what to do or which info I should provide here to fix this issue. Is there a repair installation?
        requiemmg @sdetweil
        @sdetweil Thank you. Took me a while to find the time but now I apllied your fix (mentioned above, saw your updated script afterwars only) and had to reinstall “request”-library to some addons.
        Now working.
          sdetweil @requiemmg
          @requiemmg not starting, or showing black screen?
          https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
          R 1 Reply Last reply
            requiemmg @sdetweil
            @sdetweil Not starting. I guess there was some error during the upgrade instalaltion, but it scrolled so fast that I could not read it.
            S 3 Replies Last reply
              sdetweil @requiemmg
              @requiemmg installers/upgrade.log has the processing
              and if u use pm2, then pm2 stop all
              cd MagicMirror
              npm start >somefile.txt
              wait
              ctrl-c to stop MM
              then somefile.txt has the messages
                sdetweil @requiemmg
                @requiemmg it could also be the mode/npm versions, which upgrade currently doesn’t fix.
                short workaround
                rename mm folder to MagicMirror.save
                mv MagicMirror MagicMirror.save
                run the installer script which DOES check and upgrade node/npm
                erase the new MagicMirror folder
                rm -rf MagicMirror
                rename the old one back
                mv MagicMirror.save MagicMirror
                the run upgrade again with force at the end instead of apply
                I will fix upgrade.
                  sdetweil @requiemmg
                  @requiemmg I just posted changes to the upgrade script to check and do the node/npm upgrade and to check and fix any modules needed the missing libraries…
                  both only ACTUALLY done for apply/force, but describe what would be done otherwise
                  u can use it now by using force to reupgrade already upgraded…
                    requiemmg @sdetweil
                    Now working.
