    How do I use notfications
    tutorialhelpnotifications
    18 Posts 2 Posters 6.1k Views 2 Watching
      Alyx @sdetweil
      @sdetweil I did there with no results, how would you usually set this up? I’ve tried following the documentation but its hard for myself to understand.
      https://github.com/mykle1/Hello-Lucy/blob/master/How to add modules to Hello-Lucy
      The dev of the custom config I use said to follow this but it doesnt make sense to me
        Alyx
        I was playing around with the default compliments module and apparently it is supposed to work out of the box with the voice_commands config I have although that doesnt seem to be the case… Am I doing something wrong form the start?
          sdetweil @Alyx
          @alyx are u an english speaker? if not translate the file to your language
            Alyx @sdetweil
            @sdetweil yep I am, I’m thinking of moving to another module. I’m thinking Hello Lucy, do you have any recommendations? As long as I can make it communicate with a module I dont care haha
              sdetweil @Alyx
              @alyx hello-lucy never worked for me… poor voice recognition, have to repeat myself 4 or 5 times…
                Alyx
                @sdetweil Ah damn, what would you recommend then? I need the interface to be voice driven
                  sdetweil @Alyx
                  @alyx as I said before, then only one I KNOW works is GoogleAssistant, BUT you ALSO have to do extra work to make YOUR command choice work. but there is little documentation on that, you have to discover it…
                  so its a lot MORE difficult than what u are already working on.
                    Alyx @sdetweil
                    @sdetweil Right so i’m not left with much choice then, is magic mirror left in the past then with the lack of support/ documentation?
                      sdetweil @Alyx
                      @alyx no… magic mirror is the runtime the modules plug into …
                      I am here providing support, voluntary… but module support is up to the author.
                      the voice_command thing is 3 years old.
                      there are 100’s of modules… i don’t even TRY to learn them… but I look for install and config problems, and new users.
                      but in many cases you the user, have to do extraordinary things to make some of these older modules work. BUT u need skills to do it
                      we are a shared community… some users jump in to help on specific modules, or types of modules. .
                      but still voluntary… some authors take the summer off, and work on modules in the winter…
                        Alyx @sdetweil
                        @sdetweil Understandable Sam, the support is of course appreciated as I mentioned before. My self studies can only take me so far in a certain amount of time is all.
                        I’ll take your advise with google assistant for now and se if I can find some documentation regarding implementing other modules. I saw some PM2 ones working with Alexa in videos so that my plan after.
                          sdetweil @Alyx
                          @alyx ok, alexa here is a pain in the rear…
                          for GA, look at the recipes folder
                            Alyx @sdetweil
                            @sdetweil ah ok will do then haha cheers
