    MMM-NewsAPI
    103 Posts 10 Posters 92.5k Views 8 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      @sdetweil I got it all squared away thanks Sam!
        mwm341
        Will MMM-NewsAPI allow displaying full articles in an iFrame?
        M 1 Reply Last reply
          mwm341 @mwm341
          @mwm341 said in MMM-NewsAPI:
          Maybe an answer:
          Gonna try splicing template.html into a responsive iFrame.
          Wish me luck!
          mumblebajM 1 Reply Last reply
          • mumblebajM
            mumblebaj Module Developer @mwm341
            @mwm341 It is not setup for that at the moment but, you are more than welcome to make a PR. :winking_face:
            • mumblebajM
              mumblebaj Module Developer @mumblebaj
              The following updates have been made to the module. Please feel free to do a git pull and then an npm install in the module directory.
              • Removed the request module and replaced with node-fetch due to request being deprecated.
              • Update to the config.js. You have to remove the following line from you config.js.
              className: "News"
              • The CSS has been changed to avoid conflicts with other modules. Hence the above className is no longer required and must be removed from the config.js.
              • MZ-BERM
                MZ-BER
                Hey there - thanks for offering this module (NewsAPI). It works so far really well.
                But I noticed that the module doesn’t refresh the news as I am forcing it based on my config.
                The fetchInterval: is set to 1800*1000 // 30 minutes, but I still receive news that are 5 days old.
                Only if I restart the MM (npm start) it is pulling the recent news.
                And as you can see in the screenshot below, the NewsAPI doesn’t receive requests, as I’m actually expecting all 30min.
                • mumblebajM
                  mumblebaj Module Developer @MZ-BER
                  @mz-ber Hi. I just had a look and mine is running fine and has the latest articles. Can you set debug: true in the config to see if it pulls new articles or if an error is returned? I have not run my mirror the past few days due to power issues hence my stats are low but I have been running it all day today and will check back on the stats. Let me know if you see anything in debug mode please.
                  MZ-BERM 1 Reply Last reply
                  • MZ-BERM
                    MZ-BER @mumblebaj
                    Thanks for getting back. I set debug: true in the config and it is indeed pulling recent articles.
                    • mumblebajM
                      @mz-ber Thanks for the confirmation. Can you lave the debug running and check if it pulls new data when it refresh?
                      • MZ-BERM
                        MZ-BER @mumblebaj
                        Hello @mumblebaj :waving_hand:
                        Would it be possible if you have a look? Thank you very much in advance :-)
                        pi@raspberrypi:~/Dashboard/MagicMirror $ npm start
                        > magicmirror@2.17.1 start
                        [11.11.2021 09:35.56.157] [LOG]   Starting MagicMirror: v2.17.1
                        [11.11.2021 09:35.56.164] [LOG]   Loading config ...
                        [11.11.2021 09:35.56.170] [LOG]   Loading module helpers ...
                        [11.11.2021 09:35.56.544] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.56.545] [LOG]   Module helper loaded: MMM-Wallpaper
                        [11.11.2021 09:35.56.548] [LOG]   No helper found for module: clock.
                        [11.11.2021 09:35.56.551] [LOG]   No helper found for module: MMM-CountDown.
                        [11.11.2021 09:35.56.633] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.56.635] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                        [11.11.2021 09:35.57.072] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.57.073] [LOG]   Module helper loaded: MMM-MyCalendar
                        [11.11.2021 09:35.57.155] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.57.156] [LOG]   Module helper loaded: MMM-NINA
                        [11.11.2021 09:35.57.623] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.57.624] [LOG]   Module helper loaded: MMM-PublicTransportBerlin
                        [11.11.2021 09:35.57.715] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.57.716] [LOG]   Module helper loaded: MMM-Fuel
                        [11.11.2021 09:35.58.018] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.58.018] [LOG]   Module helper loaded: MMM-Todoist
                        [11.11.2021 09:35.58.400] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.58.401] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                        [11.11.2021 09:35.58.404] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.58.404] [LOG]   Module helper loaded: MMM-GoogleSheets
                        [11.11.2021 09:35.58.427] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.58.428] [LOG]   Module helper loaded: MMM-NewsAPI
                        [11.11.2021 09:35.58.429] [LOG]   No helper found for module: alert.
                        [11.11.2021 09:35.58.450] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.58.451] [LOG]   Module helper loaded: updatenotification
                        [11.11.2021 09:35.58.638] [LOG]   Initializing new module helper ...
                        [11.11.2021 09:35.58.638] [LOG]   Module helper loaded: MMM-Remote-Control
                        [11.11.2021 09:35.58.639] [LOG]   All module helpers loaded.
                        [11.11.2021 09:35.58.729] [LOG]   Starting server on port 8080 ...
                        [11.11.2021 09:35.58.735] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [11.11.2021 09:35.58.742] [LOG]   Server started ...
                        [11.11.2021 09:35.58.743] [LOG]   Connecting socket for: MMM-Wallpaper
                        [11.11.2021 09:35.58.744] [LOG]   Starting node helper for: MMM-Wallpaper
                        [11.11.2021 09:35.58.748] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                        [11.11.2021 09:35.58.749] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                        [11.11.2021 09:35.58.749] [LOG]   Connecting socket for: MMM-MyCalendar
                        [11.11.2021 09:35.58.750] [LOG]   Starting node helper for: MMM-MyCalendar
                        [11.11.2021 09:35.58.751] [LOG]   Connecting socket for: MMM-NINA
                        [11.11.2021 09:35.58.751] [LOG]   MMM-NINA helper method started...
                        [11.11.2021 09:35.58.752] [LOG]   Connecting socket for: MMM-PublicTransportBerlin
                        [11.11.2021 09:35.58.753] [LOG]   Connecting socket for: MMM-Fuel
                        [11.11.2021 09:35.58.753] [LOG]   Starting module helper: MMM-Fuel
                        [11.11.2021 09:35.58.754] [LOG]   Connecting socket for: MMM-Todoist
                        [11.11.2021 09:35.58.755] [LOG]   Starting node helper for: MMM-Todoist
                        [11.11.2021 09:35.58.755] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                        [11.11.2021 09:35.58.756] [LOG]   Connecting socket for: MMM-GoogleSheets
                        [11.11.2021 09:35.58.757] [LOG]   ====================== Starting node_helper for module [MMM-GoogleSheets]
                        [11.11.2021 09:35.58.757] [LOG]   Connecting socket for: MMM-NewsAPI
                        [11.11.2021 09:35.58.758] [LOG]   Starting node_helper for module: MMM-NewsAPI
                        [11.11.2021 09:35.58.759] [LOG]   Connecting socket for: updatenotification
                        [11.11.2021 09:35.58.760] [LOG]   Connecting socket for: MMM-Remote-Control
                        [11.11.2021 09:35.58.761] [LOG]   Starting node helper for: MMM-Remote-Control
                        [11.11.2021 09:35.58.841] [LOG]   Sockets connected & modules started ...
                        [11.11.2021 09:35.59.134] [LOG]   Launching application.
                        [11.11.2021 09:35.59.972] [ERROR] ERROR! Could not validate main module js file.
                        [11.11.2021 09:35.59.975] [ERROR] ReferenceError: Log is not defined
                            at Object.<anonymous> (/home/pi/Dashboard/MagicMirror/modules/MMM-NINA/MMM-NINA.js:14:1229)
                            at Module._compile (internal/modules/cjs/loader.js:1078:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                            at Module.load (internal/modules/cjs/loader.js:935:32)
                            at Module._load (internal/modules/cjs/loader.js:776:14)
                            at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                            at Module.require (internal/modules/cjs/loader.js:959:19)
                            at require (internal/modules/cjs/helpers.js:88:18)
                            at Class.loadModuleDefaultConfig (/home/pi/Dashboard/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                            at /home/pi/Dashboard/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                        [11.11.2021 09:36.00.032] [ERROR] ERROR! Could not find main module js file for MMM-NINA2
                        [11.11.2021 09:36.03.598] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/sXXXXX.ics - Interval: 300000
                        [11.11.2021 09:36.03.663] [LOG]   [MMM-NEWSAPI] Invalid Option specified. Country not allowed with 'everything'!
                        [11.11.2021 09:36.03.665] [LOG]   everything callscript:  https://newsapi.org/v2/everything?domains=berliner-zeitung.de%2Cmorgenpost.de%2Ctagesschau.de&pageSize=3&apiKey=XXXXXXX
                        [11.11.2021 09:36.03.678] [INFO]  Checking git for module: default
                        [11.11.2021 09:36.03.716] [INFO]  Checking git for module: MMM-Wallpaper
                        [11.11.2021 09:36.03.757] [INFO]  Checking git for module: MMM-CountDown
                        [11.11.2021 09:36.03.794] [INFO]  Checking git for module: MMM-OpenWeatherForecast
                        [11.11.2021 09:36.03.828] [INFO]  Checking git for module: MMM-MyCalendar
                        [11.11.2021 09:36.03.858] [INFO]  Checking git for module: MMM-NINA
                        [11.11.2021 09:36.03.899] [INFO]  Checking git for module: MMM-PublicTransportBerlin
                        [11.11.2021 09:36.03.939] [INFO]  Checking git for module: MMM-Fuel
                        [11.11.2021 09:36.03.980] [INFO]  Checking git for module: MMM-Todoist
                        [11.11.2021 09:36.04.023] [INFO]  Checking git for module: MMM-NowPlayingOnSpotify
                        [11.11.2021 09:36.04.058] [INFO]  Checking git for module: MMM-GoogleSheets
                        [11.11.2021 09:36.04.097] [INFO]  Checking git for module: MMM-NewsAPI
                        [11.11.2021 09:36.04.127] [INFO]  Checking git for module: MMM-Remote-Control
                        [11.11.2021 09:36.04.171] [ERROR] (node:3286) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                        (Use `electron --trace-deprecation ...` to show where the warning was created)
                        [11.11.2021 09:36.05.079] [LOG]   Refreshed access token because it has expired. Expired at: 09:36:03 now is: 09:36:05
                        [11.11.2021 09:36.05.089] [LOG]   Refreshed access token because it has expired. Expired at: 10:36:05 now is: 09:36:05
                        [11.11.2021 09:36.05.162] [LOG]   response received:  {"status":"ok","totalResults":7435,"articles":[{"source":{"id":null,"name":"Berliner Morgenpost"},"author":"dpa","title":"Gewerkschaften: Beschäftigte an Kitas und Schulen sind im Warnstreik","description":"Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft...","url":"https://www.morgenpost.de/berlin/article233810097/Beschaeftigte-an-Kitas-und-Schulen-sind-im-Warnstreik.html","urlToImage":"https://img.morgenpost.de/img/incoming/crop233810095/400260911-w820-cv16_9-q85/Warnstreik-steht-auf-einem-Schild.jpg","publishedAt":"2021-11-11T08:06:57Z","content":"Berlin. Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft Erziehung und Wissenschaft (GEW)… [+1166 chars]"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Belarus: Tausende Geflüchtete warten weiter auf Hilfe","description":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie in Sicht.","url":"https://www.tagesschau.de/ausland/europa/belarus-polen-migranten-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/belarus-gefluechtete-101~_v-original.jpg","publishedAt":"2021-11-11T07:56:59Z","content":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie i… [+3150 chars]"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Nach Ausfällen: 110 und 112 vielerorts wieder erreichbar","description":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungsschutz und Katastrophenhilfe mit.","url":"https://www.tagesschau.de/inland/notruf-ausfall-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/polizei-255~_v-original.jpg","publishedAt":"2021-11-11T07:46:58Z","content":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungss… [+1871 chars]"}]}
                        [11.11.2021 09:36.05.277] [LOG]   sending articles:  [{"source":{"id":null,"name":"Berliner Morgenpost"},"author":"dpa","title":"Gewerkschaften: Beschäftigte an Kitas und Schulen sind im Warnstreik","description":"Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft...","url":"https://www.morgenpost.de/berlin/article233810097/Beschaeftigte-an-Kitas-und-Schulen-sind-im-Warnstreik.html","urlToImage":"https://img.morgenpost.de/img/incoming/crop233810095/400260911-w820-cv16_9-q85/Warnstreik-steht-auf-einem-Schild.jpg","publishedAt":"29 minutes ago","content":"Berlin. Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft Erziehung und Wissenschaft (GEW)… [+1166 chars]","sourceName":"Berliner Morgenpost"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Belarus: Tausende Geflüchtete warten weiter auf Hilfe","description":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie in Sicht.","url":"https://www.tagesschau.de/ausland/europa/belarus-polen-migranten-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/belarus-gefluechtete-101~_v-original.jpg","publishedAt":"39 minutes ago","content":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie i… [+3150 chars]","sourceName":"tagesschau.de"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Nach Ausfällen: 110 und 112 vielerorts wieder erreichbar","description":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungsschutz und Katastrophenhilfe mit.","url":"https://www.tagesschau.de/inland/notruf-ausfall-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/polizei-255~_v-original.jpg","publishedAt":"49 minutes ago","content":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungss… [+1871 chars]","sourceName":"tagesschau.de"}]
                        [11.11.2021 09:36.06.497] [LOG]   Refreshed access token because it has expired. Expired at: 10:36:05 now is: 09:36:06
                        [11.11.2021 09:36.07.033] [LOG]   Created transportation fetcher for station Albertinenstr. (toward all directions). (Station ID: 900000140005, Direction ID: undefined)
                        [11.11.2021 10:36.07.407] [LOG]   Refreshed access token because it has expired. Expired at: 10:36:06 now is: 10:36:07
                        [11.11.2021 11:36.08.386] [LOG]   Refreshed access token because it has expired. Expired at: 11:36:07 now is: 11:36:08
                        [11.11.2021 12:36.09.138] [LOG]   Refreshed access token because it has expired. Expired at: 12:36:08 now is: 12:36:09
                        [11.11.2021 13:36.10.367] [LOG]   Refreshed access token because it has expired. Expired at: 13:36:09 now is: 13:36:10
                        [11.11.2021 14:36.11.153] [LOG]   Refreshed access token because it has expired. Expired at: 14:36:10 now is: 14:36:11
                        [11.11.2021 14:54.36.340] [ERROR] Can’t retrieve current song. Reason:
                        [11.11.2021 14:54.36.350] [ERROR] RequestError: Error: Client network socket disconnected before secure TLS connection was established
                            at new RequestError (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/errors.js:14:15)
                            at Request.plumbing.callback (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:87:29)
                            at Request.RP$callback [as _callback] (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:46:31)
                            at self.callback (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:185:22)
                            at Request.emit (events.js:315:20)
                            at Request.onRequestError (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:877:8)
                            at ClientRequest.emit (events.js:315:20)
                            at TLSSocket.socketErrorListener (_http_client.js:469:9)
                            at TLSSocket.emit (events.js:315:20)
                            at emitErrorNT (internal/streams/destroy.js:106:8) {
                          cause: Error: Client network socket disconnected before secure TLS connection was established
                              at connResetException (internal/errors.js:607:14)
                              at TLSSocket.onConnectEnd (_tls_wrap.js:1544:19)
                              at TLSSocket.emit (events.js:327:22)
                              at endReadableNT (internal/streams/readable.js:1327:12)
                              at processTicksAndRejections (internal/process/task_queues.js:80:21) {
                            code: 'ECONNRESET',
                            path: null,
                            host: 'api.spotify.com',
                            port: 443,
                            localAddress: undefined
                          error: Error: Client network socket disconnected before secure TLS connection was established
                            code: 'ECONNRESET',
                            path: null,
                            port: 443,
                          options: {
                            url: 'https://api.spotify.com/v1/me/player',
                            headers: {
                              Authorization: 'XXXXX'
                            json: true,
                            method: 'GET',
                            callback: [Function: RP$callback],
                            transform: undefined,
                            simple: true,
                            resolveWithFullResponse: false,
                            transform2xxOnly: false
                          response: undefined
                        [11.11.2021 15:36.12.131] [LOG]   Refreshed access token because it has expired. Expired at: 15:36:11 now is: 15:36:12
                        [11.11.2021 16:24.43.352] [LOG]   Shutting down server...
                        [11.11.2021 16:24.43.358] [LOG]   Stopping module helper: MMM-Wallpaper
                        [11.11.2021 16:24.43.359] [LOG]   Stopping module helper: MMM-OpenWeatherForecast
                        [11.11.2021 16:24.43.360] [LOG]   Stopping module helper: MMM-MyCalendar
                        [11.11.2021 16:24.43.361] [LOG]   Stopping module helper: MMM-NINA
                        [11.11.2021 16:24.43.361] [LOG]   Stopping module helper: MMM-PublicTransportBerlin
                        [11.11.2021 16:24.43.363] [LOG]   Stopping module helper: MMM-Fuel
                        [11.11.2021 16:24.43.364] [LOG]   Stopping module helper: MMM-Todoist
                        [11.11.2021 16:24.43.365] [LOG]   Stopping module helper: MMM-NowPlayingOnSpotify
                        [11.11.2021 16:24.43.368] [LOG]   Stopping module helper: MMM-GoogleSheets
                        [11.11.2021 16:24.43.370] [LOG]   Stopping module helper: MMM-NewsAPI
                        [11.11.2021 16:24.43.377] [LOG]   Stopping module helper: updatenotification
                        • mumblebajM
                          @mz-ber said in MMM-NewsAPI:
                          [MMM-NEWSAPI] Invalid Option specified. Country not allowed with ‘everything’!
                          That is your issue with the NewsAPI. Please check the Readme for the valid options.
                          You seem to have loads of issues with loads of different modules. Maybe you want to start cleaning up some of those as well as they could obscure some other issues as well.
                          • MZ-BERM
                            MZ-BER @mumblebaj
                            @mumblebaj Alright, thank you!
                            • mumblebajM
                              @mz-ber Let me know if you need any further assistance.
                              • MZ-BERM
                                MZ-BER @mumblebaj
                                @mumblebaj I guess I need your help again because the module isnt showing any news anymore. The console is showing me following error:
                                [15.11.2021 18:23.33.169] [LOG]   Refreshed access token because it has expired. Expired at: 18:23:32 now is: 18:23:33
                                [15.11.2021 18:23.33.191] [LOG]   response received:  {"status":"error","code":"parametersMissing","message":"Required parameters are missing. Please set any of the following parameters and try again: sources, q, language, country, category."}
                                [15.11.2021 18:23.33.192] [LOG]   sending articles:  []
                                [15.11.2021 18:23.33.483] [LOG]   Refreshed access token because it has expired. Expired at: 19:23:33 now is: 18:23:33
                                For testing prupose I used also your default config setting:
                                                module: "MMM-NewsAPI",
                                                header: "news",
                                                position: "bottom_bar",
                                                        apiKey: "XXXXXXXXX",
                                                        type: "horizontal",
                                                        choice: "everything",
                                                        pageSize: 10,
                                                        sortby: "publishedAt",
                                                        drawInterval: 1000*30,
                                                        templateFile: "template.html",
                                                        fetchInterval: 1000*60*60,
                                                        query: {
        country: "",
        category: "",
        q: "",
        qInTitle: "",
        sources: "",
        domains: "cnn.com,nytimes.com,news24.com",
        excludeDomains: "",
        language: ""
                                I also created another API Key but same error.
                                And yes, I tested multiple parameter settings. Always the same.
                                mumblebajM 2 Replies Last reply
                                • mumblebajM
                                  @mz-ber Is your new API key active? I am using the exact same config as you posted and it seems to be working for me.
                                  Can you test via the browser and see what it says? Replace the key with your own key.
                                  https://newsapi.org/v2/everything?domains=cnn.com%2Cnytimes.com%2Cnews24.com&pageSize=10&apiKey=xxxxxxxxxxxxxxx
                                  • mumblebajM
                                    @mz-ber Also, could you add a language option, i.e. “en” or “de” and try again?
                                    language: "de"
                                    • MZ-BERM
                                      MZ-BER @mumblebaj
                                      @mumblebaj I guess I found the problem. The new option sortBy was causing the issue. In the everything config example is sortbywith a small b and not with a capital B sortBy.
                                      • mumblebajM
                                        @mz-ber Ah, will have a look at the Readme and fix accordingly. Thanks for letting me know that the Readme had an issue.
                                          DarrenHill
                                          I’m trying to set up this module on my mirror, as a replacement for the “MMM-News” one which seems to have stopped working.
                                          I tried a few configs including the example ones (adding in my own API key) but all i get on the mirror is the title and nothing else?
                                          The API key itself is working fine (tested via their website) but nothing is coming through to the mirror.
                                          My config entry is below - can anyone see an issue?
        header: "news",
        apiKey: "<redacted>",
        type: "horizontal",
        pageSize: 20,
        sortBy: "publishedAt",
        query: {
        country: "",
        category: "",
        q: "",
        qInTitle: "",
        sources: "",
        domains: "Cnn.com,Sky.com,News24.com",
        excludeDomains: "",
        language: ""
                                          I used to have just BBC.co.uk in the old one and it worked fine, but now I can’t get anything to work?
                                          • mumblebajM
                                            mumblebaj Module Developer @DarrenHill
                                            @darrenhill Your domains are incorrect. Should be all lowercase. Did you also run npm install in the MMM-NewsApi folder?
                                            D 1 Reply Last reply
                                            • 2 / 6
