    Bullseye
    45 Posts 8 Posters 27.2k Views 9 Watching
      bert269
      ~ dir layout:
      pi@piMirror:~ $ ls -al
      total 116
      pi 4096 Nov 12 11:16 .
      root 4096 Oct 30 05:12 …
      pi 132 Nov 12 10:49 .bash_history
      pi 220 Oct 30 05:12 .bash_logout
      pi 3523 Oct 30 05:12 .bashrc
      pi 4096 Oct 30 05:21 Bookshelf
      pi 4096 Nov 12 11:16 .cache
      pi 4096 Nov 12 11:16 .config
      pi 4096 Oct 30 05:53 Desktop
      pi 4096 Nov 12 10:35 Documents
      pi 4096 Oct 30 05:53 Downloads
      pi 4096 Oct 30 05:21 .local
      pi 4096 Nov 12 11:16 MagicMirror
      pi 4096 Oct 30 05:53 Music
      pi 0 Nov 1 22:55 NAS6604T
      pi 4096 Nov 12 11:04 .npm
      pi 4096 Oct 30 05:53 Pictures
      pi 12974 Nov 12 10:59 piMirror.sh
      pi 4096 Nov 12 11:02 .pki
      pi 807 Oct 30 05:12 .profile
      pi 4096 Oct 30 05:53 Public
      pi 4096 Oct 30 05:53 Templates
      pi 4096 Oct 30 05:53 Videos
      pi 4096 Nov 12 10:35 .vnc
      pi 53 Nov 12 10:49 .Xauthority
      pi 2361 Nov 12 10:49 .xsession-errors
      pi 2361 Nov 12 10:39 .xsession-errors.old
      pi@piMirror:~ $
      MagicMirror dir layout:
      pi 4096 Nov 12 11:16 …
      pi 57014 Nov 12 11:16 CHANGELOG.md
      pi 4096 Nov 12 11:16 clientonly
      pi 4096 Nov 12 11:16 config
      pi 4096 Nov 12 11:16 css
      pi 238 Nov 12 11:16 .editorconfig
      pi 34 Nov 12 11:16 .eslintignore
      pi 610 Nov 12 11:16 .eslintrc.json
      pi 4096 Nov 12 11:17 fonts
      pi 4096 Nov 12 11:17 .git
      pi 4096 Nov 12 11:16 .github
      pi 1094 Nov 12 11:16 .gitignore
      pi 4096 Nov 12 11:17 .husky
      pi 2858 Nov 12 11:16 index.html
      pi 4096 Nov 12 11:16 installers
      pi@piMirror:~/MagicMirror $
        sdetweil @bert269
        @bert269 u didn’t use my script… now idea
        see https://github.com/sdetweil/MagicMirror_scripts
        booting up on pi4 now
          bert269
          Apologies, sorry - no I did not used:
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
          I only used npm install. Let me try and will let you know.
            sdetweil @bert269
            @bert269 we need node 14 for MM… the bullseye is only node 12
            S bugsounetB 2 Replies Last reply
              looks like trouble
              /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb
              E: Sub-process /usr/bin/dpkg returned an error code (1)
              node version is node: error while loading shared libraries: libnode.so.72: cannot open shared object file: No such file or directory
              can’t install node 14…
                bert269
                Ok, run your install script. This time it worked. The screensaver interfered - but I can fix that. This is what I saw during install
                Check current Node installation …
                Minimum Node version: v14.0.0
                Installed Node version: v17.1.0
                No Node.js upgrade necessary.
                Check current NPM installation …
                Minimum npm version: V6.0.0
                Installed npm version: V8.1.2
                No npm upgrade necessary.
                Cloning MagicMirror …
                Cloning into ‘MagicMirror’…
                remote: Enumerating objects: 325, done.
                remote: Counting objects: 100% (325/325), done.
                remote: Compressing objects: 100% (290/290), done.
                remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
                Receiving objects: 100% (325/325), 477.94 KiB | 330.00 KiB/s, done.
                Resolving deltas: 100% (53/53), done.
                Cloning MagicMirror Done!
                touch: cannot touch ‘/etc/chromium-browser/customizations/01-disable-update-check’: No such file or directory
                tee: /etc/chromium-browser/customizations/01-disable-update-check: No such file or directory
                Installing dependencies …
                npm WARN EBADENGINE Unsupported engine {
                npm WARN EBADENGINE package: ‘eslint-plugin-jsdoc@36.1.1’,
                npm WARN EBADENGINE required: { node: ‘^12 || ^14 || ^16’ },
                npm WARN EBADENGINE current: { node: ‘v17.1.0’, npm: ‘8.1.2’ }
                npm WARN EBADENGINE }
                npm WARN EBADENGINE package: ‘@es-joy/jsdoccomment@0.10.8’,
                Dependencies installation Done!
                Check plymouth installation …
                Splashscreen: Checking themes directory.
                Splashscreen: Create theme directory if not exists.
                Splashscreen: Changed theme to MagicMirror successfully.
                Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                install and setup pm2
                Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                [PM2] PM2 Successfully daemonized
                [PM2][WARN] Applications MagicMirror not running, starting…
                [PM2] App [MagicMirror] launched (1 instances)
                │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4352 │ 0s │ 0 │ online │ 0% │ 2.7mb │ pi │ enabled │
                [PM2] Saving current process list…
                [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                Do you want to disable the screen saver? (y/N)?y
                xscreensaver running
                grep: /home/pi/.xscreensaver: No such file or directory
                bash: line 587: [: !=: unary operator expected
                We’re ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                pi@piMirror:~ $ cd MagicMirror/
                pi@piMirror:~/MagicMirror $ pm2 start MagicMirror
                [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                [PM2] MagicMirror ✓
                [PM2] Process successfully started
                │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4551 │ 0s │ 1 │ online │ 0% │ 2.7mb │ pi │ disabled │
                  sdetweil @bert269
                  @bert269 said in Bullseye:
                  no worky on node 17
                  BKeyportB 1 Reply Last reply
                    bert269
                    it seems fine - it works for me with 17.1. I do not know which modules witll fail/break, but the vanilla config.js brought up MagiMirror2.
                    Thanks - let me know if you do need any more info I supply/help with.
                      bert269
                      Something seems off with the screensaver stop script too:
                      pi@piMirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
                      bash: line 42: [: !=: unary operator expected
                      I guess there is a lot involved with the fact that they changed from fkms to kms
                        sdetweil @bert269
                        @bert269 thanks will fix
                          bert269 @sdetweil
                          @sdetweil No problem - thank you for the help and support. I will attach the install.log - if you still need that.[0_1636743781431_install.log.txt](Uploading 100%)
                            sdetweil @bert269
                            @bert269 don’t attach here… attach to the issue in github
                              bert269 @sdetweil
                              @sdetweil ok Sorry (is that why it’s not working…oops!)
                              • BKeyportB
                                @sdetweil I don’t think you’re gonna be able to get around it.
                                Manual install is failing too - apparently there’s a file in several packages that’s being locked by the system and causing errors in the nodejs installer.
                                dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
                                 trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
                                dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                                Errors were encountered while processing:
                                Any further installs will require this to finish, which won’t because of this error, etc.
                                N S 2 Replies Last reply
                                • N
                                  nmwust @BKeyport
                                  @bkeyport
                                  Any chance you are using a full image and not a basic image. Thinking it may be related to the nodeRed install on the full image that is not there on the basic image. I hit what i think was the same error on a full image and had no problems if i swapped cards and went back to a basic image.
                                    sdetweil @BKeyport
                                    @bkeyport yeh, I installed nvm, then installed 14 and it was ok… then switched to 17 with nvm and its ok…
                                    not sure how to correct script yet
                                      I have updated the scripts… for bullseye…
                                      give it a try
                                      in each of the urls, replace master with bullseye to get the latest version
                                      for example install
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                      replace master
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
                                      raspiberry.sh, fixuppm2.sh and screensaver.sh have been updated
                                      let me know
                                      • BKeyportB
                                        Installing helper tools ...
                                        Updating packages ...
                                        [     <=>        ]Check current Node installation ...
                                        Node.js is not installed.
                                        Installing Node.js ...
                                        chmod: cannot access '/usr/share/doc/nodejs/api/embedding.json.gz': No such file or directory
                                        Reading package lists... Done
                                        Building dependency tree... Done
                                          libc-ares2 libjs-highlight.js nodejs-doc
                                        Use 'sudo apt autoremove' to remove them.
                                        The following NEW packages will be installed:
                                          nodejs
                                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 0 B/22.9 MB of archives.
                                        After this operation, 116 MB of additional disk space will be used.
                                        Selecting previously unselected package nodejs.
                                        (Reading database ... 99829 files and directories currently installed.)
                                        Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
                                        Unpacking nodejs (14.18.1-deb-1nodesource1) ...
                                        node version is bash: line 227: node: command not found
                                        bash: line 229: node: command not found
                                        Node.js installation Done! version=
                                        /usr/bin/env: ‘node’: No such file or directory
                                        npm should be upgraded.
                                        Installing npm ...
                                        E: Unable to correct problems, you have held broken packages.
                                        npm installation Done! version=V
                                        Cloning MagicMirror ...
                                        Cloning into 'MagicMirror'...
                                        Receiving objects: 100% (325/325), 477.94 KiB | 4.78 MiB/s, done.
                                        touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
                                        Installing dependencies ...
                                        Unable to install dependencies!
                                        log added to issue…
                                          sdetweil @BKeyport
                                          @bkeyport wonderful…
                                            sdetweil @BKeyport
                                            @bkeyport think I fixed it… give it a try, still bullseye in the urls
