    Bullseye
    45 Posts 8 Posters 27.2k Views 9 Watching
      bert269
      Interesting - no ~/install.log file after the npm install. Not in the MagicMirror directory either. Ideas?
        bert269
        ~ dir layout:
        pi@piMirror:~ $ ls -al
        total 116
        pi 4096 Nov 12 11:16 .
        root 4096 Oct 30 05:12 …
        pi 132 Nov 12 10:49 .bash_history
        pi 220 Oct 30 05:12 .bash_logout
        pi 3523 Oct 30 05:12 .bashrc
        pi 4096 Oct 30 05:21 Bookshelf
        pi 4096 Nov 12 11:16 .cache
        pi 4096 Nov 12 11:16 .config
        pi 4096 Oct 30 05:53 Desktop
        pi 4096 Nov 12 10:35 Documents
        pi 4096 Oct 30 05:53 Downloads
        pi 4096 Oct 30 05:21 .local
        pi 4096 Nov 12 11:16 MagicMirror
        pi 4096 Oct 30 05:53 Music
        pi 0 Nov 1 22:55 NAS6604T
        pi 4096 Nov 12 11:04 .npm
        pi 4096 Oct 30 05:53 Pictures
        pi 12974 Nov 12 10:59 piMirror.sh
        pi 4096 Nov 12 11:02 .pki
        pi 807 Oct 30 05:12 .profile
        pi 4096 Oct 30 05:53 Public
        pi 4096 Oct 30 05:53 Templates
        pi 4096 Oct 30 05:53 Videos
        pi 4096 Nov 12 10:35 .vnc
        pi 53 Nov 12 10:49 .Xauthority
        pi 2361 Nov 12 10:49 .xsession-errors
        pi 2361 Nov 12 10:39 .xsession-errors.old
        pi@piMirror:~ $
        MagicMirror dir layout:
        pi 4096 Nov 12 11:16 …
        pi 57014 Nov 12 11:16 CHANGELOG.md
        pi 4096 Nov 12 11:16 clientonly
        pi 4096 Nov 12 11:16 config
        pi 4096 Nov 12 11:16 css
        pi 238 Nov 12 11:16 .editorconfig
        pi 34 Nov 12 11:16 .eslintignore
        pi 610 Nov 12 11:16 .eslintrc.json
        pi 4096 Nov 12 11:17 fonts
        pi 4096 Nov 12 11:17 .git
        pi 4096 Nov 12 11:16 .github
        pi 1094 Nov 12 11:16 .gitignore
        pi 4096 Nov 12 11:17 .husky
        pi 2858 Nov 12 11:16 index.html
        pi 4096 Nov 12 11:16 installers
        pi@piMirror:~/MagicMirror $
          sdetweil @bert269
          @bert269 u didn’t use my script… now idea
          see https://github.com/sdetweil/MagicMirror_scripts
          booting up on pi4 now
            bert269
            Apologies, sorry - no I did not used:
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            I only used npm install. Let me try and will let you know.
              sdetweil @bert269
              @bert269 we need node 14 for MM… the bullseye is only node 12
              S bugsounetB 2 Replies Last reply
                looks like trouble
                /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb
                E: Sub-process /usr/bin/dpkg returned an error code (1)
                node version is node: error while loading shared libraries: libnode.so.72: cannot open shared object file: No such file or directory
                can’t install node 14…
                  bert269
                  Ok, run your install script. This time it worked. The screensaver interfered - but I can fix that. This is what I saw during install
                  Check current Node installation …
                  Minimum Node version: v14.0.0
                  Installed Node version: v17.1.0
                  No Node.js upgrade necessary.
                  Check current NPM installation …
                  Minimum npm version: V6.0.0
                  Installed npm version: V8.1.2
                  No npm upgrade necessary.
                  Cloning MagicMirror …
                  Cloning into ‘MagicMirror’…
                  remote: Enumerating objects: 325, done.
                  remote: Counting objects: 100% (325/325), done.
                  remote: Compressing objects: 100% (290/290), done.
                  remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
                  Receiving objects: 100% (325/325), 477.94 KiB | 330.00 KiB/s, done.
                  Resolving deltas: 100% (53/53), done.
                  Cloning MagicMirror Done!
                  touch: cannot touch ‘/etc/chromium-browser/customizations/01-disable-update-check’: No such file or directory
                  tee: /etc/chromium-browser/customizations/01-disable-update-check: No such file or directory
                  Installing dependencies …
                  npm WARN EBADENGINE Unsupported engine {
                  npm WARN EBADENGINE package: ‘eslint-plugin-jsdoc@36.1.1’,
                  npm WARN EBADENGINE required: { node: ‘^12 || ^14 || ^16’ },
                  npm WARN EBADENGINE current: { node: ‘v17.1.0’, npm: ‘8.1.2’ }
                  npm WARN EBADENGINE }
                  npm WARN EBADENGINE package: ‘@es-joy/jsdoccomment@0.10.8’,
                  Dependencies installation Done!
                  Check plymouth installation …
                  Splashscreen: Checking themes directory.
                  Splashscreen: Create theme directory if not exists.
                  Splashscreen: Changed theme to MagicMirror successfully.
                  Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                  install and setup pm2
                  Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                  [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                  [PM2] PM2 Successfully daemonized
                  [PM2][WARN] Applications MagicMirror not running, starting…
                  [PM2] App [MagicMirror] launched (1 instances)
                  │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                  │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4352 │ 0s │ 0 │ online │ 0% │ 2.7mb │ pi │ enabled │
                  [PM2] Saving current process list…
                  [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                  Do you want to disable the screen saver? (y/N)?y
                  xscreensaver running
                  grep: /home/pi/.xscreensaver: No such file or directory
                  bash: line 587: [: !=: unary operator expected
                  We’re ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                  pi@piMirror:~ $ cd MagicMirror/
                  pi@piMirror:~/MagicMirror $ pm2 start MagicMirror
                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                  [PM2] MagicMirror ✓
                  [PM2] Process successfully started
                  │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4551 │ 0s │ 1 │ online │ 0% │ 2.7mb │ pi │ disabled │
                    sdetweil @bert269
                    @bert269 said in Bullseye:
                    no worky on node 17
                    BKeyportB 1 Reply Last reply
                      bert269
                      it seems fine - it works for me with 17.1. I do not know which modules witll fail/break, but the vanilla config.js brought up MagiMirror2.
                      Thanks - let me know if you do need any more info I supply/help with.
                        bert269
                        Something seems off with the screensaver stop script too:
                        pi@piMirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
                        bash: line 42: [: !=: unary operator expected
                        I guess there is a lot involved with the fact that they changed from fkms to kms
                          sdetweil @bert269
                          @bert269 thanks will fix
                            bert269 @sdetweil
                            @sdetweil No problem - thank you for the help and support. I will attach the install.log - if you still need that.[0_1636743781431_install.log.txt](Uploading 100%)
                              sdetweil @bert269
                              @bert269 don’t attach here… attach to the issue in github
                                bert269 @sdetweil
                                @sdetweil ok Sorry (is that why it’s not working…oops!)
                                • BKeyportB
                                  @sdetweil I don’t think you’re gonna be able to get around it.
                                  Manual install is failing too - apparently there’s a file in several packages that’s being locked by the system and causing errors in the nodejs installer.
                                  dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
                                   trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
                                  dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                                  Errors were encountered while processing:
                                  Any further installs will require this to finish, which won’t because of this error, etc.
                                  N S 2 Replies Last reply
                                  • N
                                    nmwust @BKeyport
                                    @bkeyport
                                    Any chance you are using a full image and not a basic image. Thinking it may be related to the nodeRed install on the full image that is not there on the basic image. I hit what i think was the same error on a full image and had no problems if i swapped cards and went back to a basic image.
                                      sdetweil @BKeyport
                                      @bkeyport yeh, I installed nvm, then installed 14 and it was ok… then switched to 17 with nvm and its ok…
                                      not sure how to correct script yet
                                        I have updated the scripts… for bullseye…
                                        give it a try
                                        in each of the urls, replace master with bullseye to get the latest version
                                        for example install
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                        replace master
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
                                        raspiberry.sh, fixuppm2.sh and screensaver.sh have been updated
                                        let me know
                                        • BKeyportB
                                          Installing helper tools ...
                                          Updating packages ...
                                          [     <=>        ]Check current Node installation ...
                                          Node.js is not installed.
                                          Installing Node.js ...
                                          chmod: cannot access '/usr/share/doc/nodejs/api/embedding.json.gz': No such file or directory
                                          Reading package lists... Done
                                          Building dependency tree... Done
                                            libc-ares2 libjs-highlight.js nodejs-doc
                                          Use 'sudo apt autoremove' to remove them.
                                          The following NEW packages will be installed:
                                            nodejs
                                          0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                          Need to get 0 B/22.9 MB of archives.
                                          After this operation, 116 MB of additional disk space will be used.
                                          Selecting previously unselected package nodejs.
                                          (Reading database ... 99829 files and directories currently installed.)
                                          Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
                                          Unpacking nodejs (14.18.1-deb-1nodesource1) ...
                                          node version is bash: line 227: node: command not found
                                          bash: line 229: node: command not found
                                          Node.js installation Done! version=
                                          /usr/bin/env: ‘node’: No such file or directory
                                          npm should be upgraded.
                                          Installing npm ...
                                          E: Unable to correct problems, you have held broken packages.
                                          npm installation Done! version=V
                                          Cloning MagicMirror ...
                                          Cloning into 'MagicMirror'...
                                          Receiving objects: 100% (325/325), 477.94 KiB | 4.78 MiB/s, done.
                                          touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
                                          Installing dependencies ...
                                          Unable to install dependencies!
                                          log added to issue…
                                            sdetweil @BKeyport
                                            @bkeyport wonderful…
