    Bullseye
    45 Posts 8 Posters 22.5k Views 9 Watching
      bert269
      I am the only crazy person that wants to get MagicMirror working under Bullseye? It was working fine under Buster - but oh my, upgrading to Bullseye is a mess. Halfway through the upgrade, everything just freezes.
      Ok - re-image the SD-card and run the installation scripts (which all used to work fine under Buster) after Bullseye have been installed and "apt upgrad"ed…Magic mirror seems to initializes, but nothing displays on the screen. No config errors.
      Could it be because the change from dtoverlay=vc4-fkms-v3d to dtoverlay=vc4-kms-v3d ??
      Any suggestions would be helpful. I tried to search on here, but could not find anything about Bullseye in this forum.
        sdetweil @bert269
        @bert269 this is the second report… I have not had a chance to look at it yet… have and sd card flashed…
        https://github.com/sdetweil/MagicMirror_scripts/issues/36
        I asked the other user to post the ~/install.log for me to look at , can u add to the issue with the log file
          bert269
          Interesting - no ~/install.log file after the npm install. Not in the MagicMirror directory either. Ideas?
            bert269
            ~ dir layout:
            pi@piMirror:~ $ ls -al
            total 116
            pi 4096 Nov 12 11:16 .
            root 4096 Oct 30 05:12 …
            pi 132 Nov 12 10:49 .bash_history
            pi 220 Oct 30 05:12 .bash_logout
            pi 3523 Oct 30 05:12 .bashrc
            pi 4096 Oct 30 05:21 Bookshelf
            pi 4096 Nov 12 11:16 .cache
            pi 4096 Nov 12 11:16 .config
            pi 4096 Oct 30 05:53 Desktop
            pi 4096 Nov 12 10:35 Documents
            pi 4096 Oct 30 05:53 Downloads
            pi 4096 Oct 30 05:21 .local
            pi 4096 Nov 12 11:16 MagicMirror
            pi 4096 Oct 30 05:53 Music
            pi 0 Nov 1 22:55 NAS6604T
            pi 4096 Nov 12 11:04 .npm
            pi 4096 Oct 30 05:53 Pictures
            pi 12974 Nov 12 10:59 piMirror.sh
            pi 4096 Nov 12 11:02 .pki
            pi 807 Oct 30 05:12 .profile
            pi 4096 Oct 30 05:53 Public
            pi 4096 Oct 30 05:53 Templates
            pi 4096 Oct 30 05:53 Videos
            pi 4096 Nov 12 10:35 .vnc
            pi 53 Nov 12 10:49 .Xauthority
            pi 2361 Nov 12 10:49 .xsession-errors
            pi 2361 Nov 12 10:39 .xsession-errors.old
            pi@piMirror:~ $
            MagicMirror dir layout:
            pi 4096 Nov 12 11:16 …
            pi 57014 Nov 12 11:16 CHANGELOG.md
            pi 4096 Nov 12 11:16 clientonly
            pi 4096 Nov 12 11:16 config
            pi 4096 Nov 12 11:16 css
            pi 238 Nov 12 11:16 .editorconfig
            pi 34 Nov 12 11:16 .eslintignore
            pi 610 Nov 12 11:16 .eslintrc.json
            pi 4096 Nov 12 11:17 fonts
            pi 4096 Nov 12 11:17 .git
            pi 4096 Nov 12 11:16 .github
            pi 1094 Nov 12 11:16 .gitignore
            pi 4096 Nov 12 11:17 .husky
            pi 2858 Nov 12 11:16 index.html
            pi 4096 Nov 12 11:16 installers
            pi@piMirror:~/MagicMirror $
              sdetweil @bert269
              @bert269 u didn’t use my script… now idea
              see https://github.com/sdetweil/MagicMirror_scripts
              booting up on pi4 now
                bert269
                Apologies, sorry - no I did not used:
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                I only used npm install. Let me try and will let you know.
                  sdetweil @bert269
                  @bert269 we need node 14 for MM… the bullseye is only node 12
                  S bugsounetB 2 Replies Last reply Reply Quote 0
                    looks like trouble
                    /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb
                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                    node version is node: error while loading shared libraries: libnode.so.72: cannot open shared object file: No such file or directory
                    can’t install node 14…
                      bert269
                      Ok, run your install script. This time it worked. The screensaver interfered - but I can fix that. This is what I saw during install
                      Check current Node installation …
                      Minimum Node version: v14.0.0
                      Installed Node version: v17.1.0
                      No Node.js upgrade necessary.
                      Check current NPM installation …
                      Minimum npm version: V6.0.0
                      Installed npm version: V8.1.2
                      No npm upgrade necessary.
                      Cloning MagicMirror …
                      Cloning into ‘MagicMirror’…
                      remote: Enumerating objects: 325, done.
                      remote: Counting objects: 100% (325/325), done.
                      remote: Compressing objects: 100% (290/290), done.
                      remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
                      Receiving objects: 100% (325/325), 477.94 KiB | 330.00 KiB/s, done.
                      Resolving deltas: 100% (53/53), done.
                      Cloning MagicMirror Done!
                      touch: cannot touch ‘/etc/chromium-browser/customizations/01-disable-update-check’: No such file or directory
                      tee: /etc/chromium-browser/customizations/01-disable-update-check: No such file or directory
                      Installing dependencies …
                      npm WARN EBADENGINE Unsupported engine {
                      npm WARN EBADENGINE package: ‘eslint-plugin-jsdoc@36.1.1’,
                      npm WARN EBADENGINE required: { node: ‘^12 || ^14 || ^16’ },
                      npm WARN EBADENGINE current: { node: ‘v17.1.0’, npm: ‘8.1.2’ }
                      npm WARN EBADENGINE }
                      npm WARN EBADENGINE package: ‘@es-joy/jsdoccomment@0.10.8’,
                      Dependencies installation Done!
                      Check plymouth installation …
                      Splashscreen: Checking themes directory.
                      Splashscreen: Create theme directory if not exists.
                      Splashscreen: Changed theme to MagicMirror successfully.
                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                      install and setup pm2
                      Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                      [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                      [PM2] PM2 Successfully daemonized
                      [PM2][WARN] Applications MagicMirror not running, starting…
                      [PM2] App [MagicMirror] launched (1 instances)
                      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                      │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4352 │ 0s │ 0 │ online │ 0% │ 2.7mb │ pi │ enabled │
                      [PM2] Saving current process list…
                      [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                      Do you want to disable the screen saver? (y/N)?y
                      xscreensaver running
                      grep: /home/pi/.xscreensaver: No such file or directory
                      bash: line 587: [: !=: unary operator expected
                      We’re ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                      pi@piMirror:~ $ cd MagicMirror/
                      pi@piMirror:~/MagicMirror $ pm2 start MagicMirror
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                      [PM2] MagicMirror ✓
                      [PM2] Process successfully started
                      │ 0 │ MagicMirror │ default │ 2.17.1 │ fork │ 4551 │ 0s │ 1 │ online │ 0% │ 2.7mb │ pi │ disabled │
                        sdetweil @bert269
                        @bert269 said in Bullseye:
                        no worky on node 17
                          bert269
                          it seems fine - it works for me with 17.1. I do not know which modules witll fail/break, but the vanilla config.js brought up MagiMirror2.
                          Thanks - let me know if you do need any more info I supply/help with.
                            bert269
                            Something seems off with the screensaver stop script too:
                            pi@piMirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
                            bash: line 42: [: !=: unary operator expected
                            I guess there is a lot involved with the fact that they changed from fkms to kms
                              sdetweil @bert269
                              @bert269 thanks will fix
                                bert269 @sdetweil
                                @sdetweil No problem - thank you for the help and support. I will attach the install.log - if you still need that.[0_1636743781431_install.log.txt](Uploading 100%)
                                  sdetweil @bert269
                                  @bert269 don’t attach here… attach to the issue in github
                                    bert269 @sdetweil
                                    @sdetweil ok Sorry (is that why it’s not working…oops!)
                                    • BKeyportB Offline
                                      @sdetweil I don’t think you’re gonna be able to get around it.
                                      Manual install is failing too - apparently there’s a file in several packages that’s being locked by the system and causing errors in the nodejs installer.
                                      dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
                                       trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
                                      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                                      Errors were encountered while processing:
                                      Any further installs will require this to finish, which won’t because of this error, etc.
                                      N S 2 Replies Last reply Reply Quote 0
                                      • N Offline
                                        nmwust @BKeyport
                                        @bkeyport
                                        Any chance you are using a full image and not a basic image. Thinking it may be related to the nodeRed install on the full image that is not there on the basic image. I hit what i think was the same error on a full image and had no problems if i swapped cards and went back to a basic image.
                                          sdetweil @BKeyport
                                          @bkeyport yeh, I installed nvm, then installed 14 and it was ok… then switched to 17 with nvm and its ok…
                                          not sure how to correct script yet
                                            I have updated the scripts… for bullseye…
                                            give it a try
                                            in each of the urls, replace master with bullseye to get the latest version
                                            for example install
                                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                            replace master
                                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
                                            raspiberry.sh, fixuppm2.sh and screensaver.sh have been updated
                                            let me know
