    Bullseye
    45 Posts 8 Posters 26.8k Views 9 Watching
      DJBOOB66
      I have to do it again but will do it as soon as i can or is log found on file and were?
      • BKeyportB
        @sdetweil Failed all over the place.
        I’ll upload install.log, then nuking card and starting over.
          sdetweil @BKeyport
          @bkeyport did u use the bullseye link ?
          before then if u used the old link, things get messed up w no recovery (well there is but it’s half an hour of ugly work)
          reflash
          • BKeyportB
            @sdetweil Yes, I used the bullseye link. installing a new card now.
              DJBOOB66
              the install went without problem this time only thing did diff was i SSH not VNC will test VNC install and see if error.
              the only think i get is
              “Installing dependencies …
              npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforke d package instead: postcss-markdown
              npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details.
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/je st-haste-map/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”} )
              npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta | | >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dep endencies yourself.”
              Do i need to fix anything??
              Hope this helps.
                sdetweil @DJBOOB66
                @djboob66 no, nothing to fix
                • BKeyportB
                  On new card it worked flawlessly. I’m assuming the old conditions of partial installs and whatnot had the old install broke things.
                  Nothing but warnings about depreciated modules.
                    sdetweil @BKeyport
                    @bkeyport said in Bullseye:
                    that we can’t do anything about. not our code
                    • AssassinsA
                      Assassins
                      Dont Update, Bulleyes is so much slow, and it not drive 100% yet.
                      Buster work 100%, and much faster
                        sdetweil @Assassins
                        @assassins on what device? pi4 seems faster
                        pi3 seems slower
                        AssassinsA 1 Reply Last reply Reply Quote 0
                        • AssassinsA
                          Assassins @sdetweil
                          Both, pi3+ is much slower, and pi4 8gb is a little bit slower, But restart Big time hole time, so i mean Bulleyes is not 100% y’et, But Buster run without trouble on both.
                          • BKeyportB
                            BKeyport Module Developer @Assassins
                            An FYI to the issues within Bullseye. If you’re using OMX, it won’t work by default in Bullseye, and as it’s depreciated, we’re kinda on our own. Basically, They’ve gone through and renamed most of the libraries used by OMX.
                            Issue these commands in a sudo session to get OMX to work until you figure out a new video streaming solution:
                            cd /usr/lib/arm-linux-gnueabihf
                            ln -s libmmal_core.so.0 libmmal_core.so
                            ln -s libmmal_util.so.0 libmmal_util.so
                            ln -s libmmal_vc_client.so.0 libmmal_vc_client.so
                            ln -s libbcm_host.so.0 libbcm_host.so
                            ln -s libvcsm.so.0 libvcsm.so
                            ln -s libvchiq_arm.so.0 libvchiq_arm.so
                            ln -s libvcos.so.0 libvcos.so
                            curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libbrcmEGL.so'
                            curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libbrcmGLESv2.so'
                            curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libopenmaxil.so'
                            – B
                            • 3 / 3
