    Blank screen on start when installing modules
    3 Posts 2 Posters 646 Views 2 Watching
    • N Offline
      natebrown
      I just installed MM on my Pi 400 and it was working fine until i tried installing 3rd party modules. When I start it up i get the following code:
      > magicmirror@2.17.1 start
      > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "run"
      App threw an error during load
      Error: Cannot find module 'logger'
      Require stack:
          at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
          at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:732:27)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
          at Module.require (internal/modules/cjs/loader.js:959:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:13:13)
          at Module._compile (internal/modules/cjs/loader.js:1078:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      ^C/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      Thank you for your help.
        sdetweil @natebrown
        @natebrown I would do another
        npm install
        in the MagicMirror folder
          sdetweil @natebrown
          @natebrown i don’t think it applies here at the moment (unless there was a mistake in the module installation and it overlayed some MM files) delete MagicMirror/node_modules and redo npm install in the MagicMirror folder
          but see this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
