    Problems after Update
    17 Posts 3 Posters 2.2k Views 3 Watching
    • Dotmatrix812D
      Dotmatrix812 @sdetweil
      @sdetweil Thanks for the fast reply. That’s why I disabled NOAA3. But the problem still exists. See second code. But with no error shown in log. I just stops the server and is starting again every minute ?!
        sdetweil @Dotmatrix812
        @dotmatrix812 how did you do the update?
        Dotmatrix812D 1 Reply Last reply
        • Dotmatrix812D
          I did it with the script. Due to the problem I installed MM new.
          I moved the magic mirror folder and installed it new with the install script. After that I installed all modules again from GitHub and I set up the config.js
          But the problem is still there :-(
          S 2 Replies Last reply
            @dotmatrix812 probably this
            tho I don’t know why u don’t see the errors…
            if u use the sample config does it still happen? (config.js.sample in the config folder)
              @dotmatrix812 can u send me the ~/MagicMirror/installers/upgrade.log if u still have it, via email
              same userid as here , at gmail
              • mumblebajM
                @sdetweil That error indicates that the API key has expired. I get it once a year when the key expires. After renewing the key that error goes away for me.
                  sdetweil @mumblebaj
                  @mumblebaj but that shouldn’t kill MM, which is his problem
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    @sdetweil Correct and it doesn’t for me so I would eliminate that as an issue.
                    • Dotmatrix812D
                      Sorry for the late reply. I was busy. I will check if I have the file tomorrow.
                      I will try what happens with the sample config.
                      And I will renew my api key.
                      Then I will come back to you all.
                      Many thanks for the help up till now !!!
                      • Dotmatrix812D
                        So I tried with new API Key. But same problem:
                        0|MagicMirror  | [23.11.2021 08:27.50.025] [LOG]   Shutting down server...
                        0|MagicMirror  | [23.11.2021 08:27.50.029] [LOG]   Stopping module helper: updatenotification
                        0|MagicMirror  | [23.11.2021 08:27.50.030] [LOG]   Stopping module helper: MMM-MotionDetector
                        0|MagicMirror  | [23.11.2021 08:27.50.032] [LOG]   Stopping module helper: calendar
                        0|MagicMirror  | [23.11.2021 08:27.50.035] [LOG]   Stopping module helper: MMM-MyGarbage
                        0|MagicMirror  | [23.11.2021 08:27.50.040] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                        0|MagicMirror  | [23.11.2021 08:27.50.045] [LOG]   Stopping module helper: MMM-NOAA3
                        0|MagicMirror  | [23.11.2021 08:27.50.050] [LOG]   Stopping module helper: MMM-DWD-WarnWeather
                        0|MagicMirror  | [23.11.2021 08:27.50.055] [LOG]   Stopping module helper: MMM-TelegramBot
                        0|MagicMirror  | [23.11.2021 08:27.50.058] [LOG]   Stopping module helper: MMM-COVID19-AMPEL
                        0|MagicMirror  | [23.11.2021 08:27.50.060] [LOG]   Stopping module helper: newsfeed
                        0|MagicMirror  | > magicmirror@2.17.1 start
                        0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        0|MagicMirror  | [23.11.2021 08:28.01.293] [LOG]
                        0|MagicMirror  | Starting MagicMirror: v2.17.1
                        0|MagicMirror  | [23.11.2021 08:28.01.321] [LOG]
                        0|MagicMirror  | Loading config ...
                        0|MagicMirror  | [23.11.2021 08:28.01.342] [LOG]
                        0|MagicMirror  | Loading module helpers ...
                        0|MagicMirror  | [23.11.2021 08:28.01.353] [LOG]   No helper found for module: alert.
                        0|MagicMirror  | [23.11.2021 08:28.01.400] [LOG]
                        0|MagicMirror  | Initializing new module helper ...
                        0|MagicMirror  | [23.11.2021 08:28.01.405] [LOG]   Module helper loaded: updatenotification
                        0|MagicMirror  | [23.11.2021 08:28.01.412] [LOG]   No helper found for module: clock.
                        0|MagicMirror  | [23.11.2021 08:28.01.429] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.01.431] [LOG]   Module helper loaded: MMM-MotionDetector
                        0|MagicMirror  | [23.11.2021 08:28.01.858] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.01.859] [LOG]   Module helper loaded: calendar
                        0|MagicMirror  | [23.11.2021 08:28.01.921] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.01.922] [LOG]   Module helper loaded: MMM-MyGarbage
                        0|MagicMirror  | [23.11.2021 08:28.02.243] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.02.246] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                        0|MagicMirror  | [23.11.2021 08:28.03.172] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.03.175] [LOG]   Module helper loaded: MMM-NOAA3
                        0|MagicMirror  | [23.11.2021 08:28.03.945] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.03.948] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
                        0|MagicMirror  | [23.11.2021 08:28.03.953] [LOG]   No helper found for module: MMM-Homematic.
                        0|MagicMirror  | [23.11.2021 08:28.05.902] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.05.905] [LOG]   Module helper loaded: MMM-TelegramBot
                        0|MagicMirror  | [23.11.2021 08:28.06.126] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.06.127] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
                        0|MagicMirror  | [23.11.2021 08:28.06.205] [LOG]
                        0|MagicMirror  | [23.11.2021 08:28.06.208] [LOG]   Module helper loaded: newsfeed
                        0|MagicMirror  | [23.11.2021 08:28.06.211] [LOG]   All module helpers loaded.
                        0|MagicMirror  | [23.11.2021 08:28.06.543] [LOG]
                        0|MagicMirror  | Starting server on port 8080 ...
                        0|MagicMirror  | [23.11.2021 08:28.06.588] [LOG]
                        0|MagicMirror  | Server started ...
                        0|MagicMirror  | [23.11.2021 08:28.06.590] [LOG]   Connecting socket for: updatenotification
                        0|MagicMirror  | [23.11.2021 08:28.06.593] [LOG]   Connecting socket for: MMM-MotionDetector
                        0|MagicMirror  | [23.11.2021 08:28.06.652] [LOG]
                        0|MagicMirror  | Connecting socket for: calendar
                        0|MagicMirror  | [23.11.2021 08:28.06.656] [LOG]   Starting node helper for: calendar
                        0|MagicMirror  | [23.11.2021 08:28.06.658] [LOG]   Connecting socket for: MMM-MyGarbage
                        0|MagicMirror  | [23.11.2021 08:28.06.659] [LOG]   Starting node_helper for module: MMM-MyGarbage
                        0|MagicMirror  | [23.11.2021 08:28.06.661] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                        0|MagicMirror  | [23.11.2021 08:28.06.665] [LOG]   Connecting socket for: MMM-NOAA3
                        0|MagicMirror  | [23.11.2021 08:28.06.683] [LOG]
                        0|MagicMirror  | Connecting socket for: MMM-DWD-WarnWeather
                        0|MagicMirror  | [23.11.2021 08:28.06.689] [LOG]   MMM-DWD-WarnWeather helper started...
                        0|MagicMirror  | [23.11.2021 08:28.06.692] [LOG]   Connecting socket for: MMM-TelegramBot
                        0|MagicMirror  | [23.11.2021 08:28.06.694] [LOG]   Connecting socket for: MMM-COVID19-AMPEL
                        0|MagicMirror  | [23.11.2021 08:28.06.696] [LOG]   Starting node helper for: MMM-COVID19-AMPEL
                        0|MagicMirror  | [23.11.2021 08:28.06.699] [LOG]
                        0|MagicMirror  | Connecting socket for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:28.06.706] [LOG]   Starting node helper for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:28.06.712] [LOG]   Sockets connected & modules started ...
                        0|MagicMirror  | [23.11.2021 08:28.07.229] [INFO]
                        0|MagicMirror  | MMM-MotionDetector: monitor status is display_power=1
                        0|MagicMirror  | [23.11.2021 08:28.07.231] [INFO]  MMM-MotionDetector: monitor is ON.
                        0|MagicMirror  | [23.11.2021 08:28.07.290] [LOG]
                        0|MagicMirror  | Launching application.
                        0|MagicMirror  | [23.11.2021 08:28.14.631] [LOG]
                        0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f3hc4hvoq0kmkb20vu5mt7tbvo%40group.calendar.google.com/private-***************93989171bfe71/basic.ics - Interval: 300000
                        0|MagicMirror  | [23.11.2021 08:28.15.126] [INFO]
                        0|MagicMirror  | MMM-MotionDetector: activating monitor.
                        0|MagicMirror  | [23.11.2021 08:28.15.312] [INFO]  MMM-MotionDetector: monitor status is display_power=1
                        0|MagicMirror  | [23.11.2021 08:28.15.397] [LOG]
                        0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/klmriov1e3toti8ab9gf8phchk%40group.calendar.google.com/private-*****************47f366685/basic.ics - Interval: 300000
                        0|MagicMirror  | [23.11.2021 08:28.15.429] [LOG]   wb
                        0|MagicMirror  | [23.11.2021 08:28.15.536] [LOG]
                        0|MagicMirror  | 1637652495
                        0|MagicMirror  | [23.11.2021 08:28.15.592] [LOG]
                        0|MagicMirror  | [TELBOT] MMM-TelegramBot Version: 1.3.8
                        0|MagicMirror  | [23.11.2021 08:28.15.725] [LOG]
                        0|MagicMirror  | [TELBOT] Ready!
                        0|MagicMirror  | [23.11.2021 08:28.15.837] [LOG]
                        0|MagicMirror  | Create new newsfetcher for url: https://www.wiesbadener-kurier.de/rss/lokales/rheingau - Interval: 300000
                        0|MagicMirror  | [23.11.2021 08:28.15.864] [LOG]   Create new newsfetcher for url: https://www.hessenschau.de/rheinmain/index.rss - Interval: 300000
                        0|MagicMirror  | [23.11.2021 08:28.16.062] [INFO]
                        0|MagicMirror  | Checking git for module: default
                        0|MagicMirror  | [23.11.2021 08:28.16.158] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-MotionDetector
                        0|MagicMirror  | [23.11.2021 08:28.16.240] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-MyGarbage
                        0|MagicMirror  | [23.11.2021 08:28.16.381] [INFO]  Checking git for module: MMM-BackgroundSlideshow
                        0|MagicMirror  | [23.11.2021 08:28.16.463] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-NOAA3
                        0|MagicMirror  | [23.11.2021 08:28.16.615] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-DWD-WarnWeather
                        0|MagicMirror  | [23.11.2021 08:28.16.837] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-Homematic
                        0|MagicMirror  | [23.11.2021 08:28.16.997] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-TelegramBot
                        0|MagicMirror  | [23.11.2021 08:28.17.099] [INFO]
                        0|MagicMirror  | Checking git for module: MMM-COVID19-AMPEL
                        0|MagicMirror  | [23.11.2021 08:28.17.327] [INFO]
                        0|MagicMirror  | BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/wir/" for images.
                        0|MagicMirror  | [23.11.2021 08:28.17.353] [INFO]
                        0|MagicMirror  | BACKGROUNDSLIDESHOW: 16 files found
                        0|MagicMirror  | [23.11.2021 08:28.19.049] [INFO]
                        0|MagicMirror  | BACKGROUNDSLIDESHOW_NEXT_IMAGE
                        0|MagicMirror  | [23.11.2021 08:28.19.058] [INFO]
                        0|MagicMirror  | BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages/wir//IMG_4869.jpg"
                        0|MagicMirror  | [23.11.2021 08:28.20.050] [INFO]
                        0|MagicMirror  | Newsfeed-Fetcher: Broadcasting 10 items.
                        0|MagicMirror  | [23.11.2021 08:28.21.860] [INFO]
                        0|MagicMirror  | Newsfeed-Fetcher: Broadcasting 24 items.
                        0|MagicMirror  | [23.11.2021 08:28.27.223] [INFO]
                        0|MagicMirror  | Calendar-Fetcher: Broadcasting 3 events.
                        0|MagicMirror  | [23.11.2021 08:28.31.603] [INFO]
                        0|MagicMirror  | Calendar-Fetcher: Broadcasting 4 events.
                        0|MagicMirror  | [23.11.2021 08:29.17.389] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
                        0|MagicMirror  | [23.11.2021 08:29.17.390] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages/wir//IMG_2031.JPG"
                        0|MagicMirror  | [23.11.2021 08:29.20.996] [LOG]   Shutting down server...
                        Then I tried with sample config.js, same issue:
                        0|MagicMir | [23.11.2021 08:32.09.460] [LOG]   Connecting socket for: calendar
                        0|MagicMir | [23.11.2021 08:32.09.463] [LOG]   Starting node helper for: calendar
                        0|MagicMir | [23.11.2021 08:32.09.466] [LOG]   Connecting socket for: newsfeed
                        0|MagicMir | [23.11.2021 08:32.09.472] [LOG]   Starting node helper for: newsfeed
                        0|MagicMir | [23.11.2021 08:32.09.476] [LOG]   Sockets connected & modules started ...
                        0|MagicMir | [23.11.2021 08:32.10.229] [LOG]   Launching application.
                        0|MagicMir |
                        0|MagicMir | > magicmirror@2.17.1 start
                        0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        0|MagicMir |
                        0|MagicMirror  | [23.11.2021 08:32.17.658] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.17.681] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.17.703] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.17.712] [LOG]   No helper found for module: alert.
                        0|MagicMirror  | [23.11.2021 08:32.17.760] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.17.762] [LOG]   Module helper loaded: updatenotification
                        0|MagicMirror  | [23.11.2021 08:32.17.766] [LOG]   No helper found for module: clock.
                        0|MagicMirror  | [23.11.2021 08:32.18.182] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.18.185] [LOG]   Module helper loaded: calendar
                        0|MagicMirror  | [23.11.2021 08:32.18.188] [LOG]   No helper found for module: compliments.
                        0|MagicMirror  | [23.11.2021 08:32.18.191] [LOG]   No helper found for module: weather.
                        0|MagicMirror  | [23.11.2021 08:32.18.253] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.18.254] [LOG]   Module helper loaded: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.18.256] [LOG]   All module helpers loaded.
                        0|MagicMirror  | [23.11.2021 08:32.18.522] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.18.563] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.18.567] [LOG]   Connecting socket for: updatenotification
                        0|MagicMirror  | [23.11.2021 08:32.18.574] [LOG]   Connecting socket for: calendar
                        0|MagicMirror  | [23.11.2021 08:32.18.578] [LOG]   Starting node helper for: calendar
                        0|MagicMirror  | [23.11.2021 08:32.18.582] [LOG]   Connecting socket for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.18.586] [LOG]   Starting node helper for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.18.590] [LOG]   Sockets connected & modules started ...
                        0|MagicMirror  | [23.11.2021 08:32.19.124] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.23.297] [LOG]   Shutting down server...
                        0|MagicMirror  | [23.11.2021 08:32.23.321] [LOG]   Stopping module helper: updatenotification
                        0|MagicMirror  | [23.11.2021 08:32.23.323] [LOG]   Stopping module helper: calendar
                        0|MagicMirror  | [23.11.2021 08:32.23.325] [LOG]   Stopping module helper: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.34.248] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.34.264] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.34.290] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.34.295] [LOG]   No helper found for module: alert.
                        0|MagicMirror  | [23.11.2021 08:32.34.345] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.34.350] [LOG]
                        0|MagicMirror  | Module helper loaded: updatenotification
                        0|MagicMirror  | [23.11.2021 08:32.34.355] [LOG]   No helper found for module: clock.
                        0|MagicMirror  | [23.11.2021 08:32.34.765] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.34.768] [LOG]   Module helper loaded: calendar
                        0|MagicMirror  | [23.11.2021 08:32.34.775] [LOG]   No helper found for module: compliments.
                        0|MagicMirror  | [23.11.2021 08:32.34.782] [LOG]   No helper found for module: weather.
                        0|MagicMirror  | [23.11.2021 08:32.34.844] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.34.846] [LOG]   Module helper loaded: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.34.848] [LOG]   All module helpers loaded.
                        0|MagicMirror  | [23.11.2021 08:32.35.122] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.35.158] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.35.160] [LOG]   Connecting socket for: updatenotification
                        0|MagicMirror  | [23.11.2021 08:32.35.163] [LOG]   Connecting socket for: calendar
                        0|MagicMirror  | [23.11.2021 08:32.35.166] [LOG]   Starting node helper for: calendar
                        0|MagicMirror  | [23.11.2021 08:32.35.172] [LOG]   Connecting socket for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.35.178] [LOG]   Starting node helper for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:32.35.182] [LOG]   Sockets connected & modules started ...
                        0|MagicMirror  | [23.11.2021 08:32.35.749] [LOG]
                        0|MagicMirror  | [23.11.2021 08:32.41.508] [LOG]
                        0|MagicMirror  | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                        0|MagicMirror  | [23.11.2021 08:32.41.775] [LOG]
                        0|MagicMirror  | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        0|MagicMirror  | [23.11.2021 08:32.41.862] [INFO]
                        0|MagicMirror  | [23.11.2021 08:32.42.919] [INFO]
                        0|MagicMirror  | Calendar-Fetcher: Broadcasting 2 events.
                        0|MagicMirror  | [23.11.2021 08:32.43.462] [INFO]
                        0|MagicMirror  | Newsfeed-Fetcher: Broadcasting 58 items.
                        0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
                        0|MagicMirror  | [23.11.2021 08:34.04.951] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.04.969] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.04.994] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.04.999] [LOG]   No helper found for module: alert.
                        0|MagicMirror  | [23.11.2021 08:34.05.054] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.05.057] [LOG]   Module helper loaded: updatenotification
                        0|MagicMirror  | [23.11.2021 08:34.05.059] [LOG]   No helper found for module: clock.
                        0|MagicMirror  | [23.11.2021 08:34.05.482] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.05.485] [LOG]   Module helper loaded: calendar
                        0|MagicMirror  | [23.11.2021 08:34.05.488] [LOG]   No helper found for module: compliments.
                        0|MagicMirror  | [23.11.2021 08:34.05.491] [LOG]   No helper found for module: weather.
                        0|MagicMirror  | [23.11.2021 08:34.05.555] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.05.557] [LOG]   Module helper loaded: newsfeed
                        0|MagicMirror  | [23.11.2021 08:34.05.558] [LOG]   All module helpers loaded.
                        0|MagicMirror  | [23.11.2021 08:34.05.829] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.05.882] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.05.887] [LOG]   Connecting socket for: updatenotification
                        0|MagicMirror  | [23.11.2021 08:34.05.890] [LOG]   Connecting socket for: calendar
                        0|MagicMirror  | [23.11.2021 08:34.05.892] [LOG]   Starting node helper for: calendar
                        0|MagicMirror  | [23.11.2021 08:34.05.894] [LOG]   Connecting socket for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:34.05.896] [LOG]   Starting node helper for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:34.05.899] [LOG]   Sockets connected & modules started ...
                        0|MagicMirror  | [23.11.2021 08:34.06.443] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.12.581] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.12.796] [LOG]
                        0|MagicMirror  | [23.11.2021 08:34.12.890] [INFO]
                        0|MagicMirror  | [23.11.2021 08:34.14.262] [INFO]
                        0|MagicMirror  | [23.11.2021 08:34.14.395] [INFO]
                        0|MagicMirror  | [23.11.2021 08:35.24.724] [LOG]   Shutting down server...
                        0|MagicMirror  | [23.11.2021 08:35.24.728] [LOG]   Stopping module helper: updatenotification
                        0|MagicMirror  | [23.11.2021 08:35.24.729] [LOG]   Stopping module helper: calendar
                        0|MagicMirror  | [23.11.2021 08:35.24.733] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.35.658] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.35.688] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.35.710] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.35.724] [LOG]
                        0|MagicMirror  | No helper found for module: alert.
                        0|MagicMirror  | [23.11.2021 08:35.35.773] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.35.783] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.35.789] [LOG]
                        0|MagicMirror  | No helper found for module: clock.
                        0|MagicMirror  | [23.11.2021 08:35.36.210] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.36.213] [LOG]   Module helper loaded: calendar
                        0|MagicMirror  | [23.11.2021 08:35.36.219] [LOG]   No helper found for module: compliments.
                        0|MagicMirror  | [23.11.2021 08:35.36.222] [LOG]
                        0|MagicMirror  | No helper found for module: weather.
                        0|MagicMirror  | [23.11.2021 08:35.36.285] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.36.287] [LOG]   Module helper loaded: newsfeed
                        0|MagicMirror  | [23.11.2021 08:35.36.288] [LOG]   All module helpers loaded.
                        0|MagicMirror  | [23.11.2021 08:35.36.554] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.36.598] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.36.603] [LOG]   Connecting socket for: updatenotification
                        0|MagicMirror  | [23.11.2021 08:35.36.611] [LOG]   Connecting socket for: calendar
                        0|MagicMirror  | [23.11.2021 08:35.36.617] [LOG]   Starting node helper for: calendar
                        0|MagicMirror  | [23.11.2021 08:35.36.622] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.36.624] [LOG]   Starting node helper for: newsfeed
                        0|MagicMirror  | [23.11.2021 08:35.36.625] [LOG]   Sockets connected & modules started ...
                        0|MagicMirror  | [23.11.2021 08:35.37.160] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.43.173] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.43.431] [LOG]
                        0|MagicMirror  | [23.11.2021 08:35.43.540] [INFO]
                        0|MagicMirror  | [23.11.2021 08:35.44.913] [INFO]
                        0|MagicMirror  | [23.11.2021 08:35.45.032] [INFO]
                        But here I found this in red letters
                        Is this maybe the problem ?
                        • mumblebajM
                          mumblebaj Module Developer @Dotmatrix812
                          @dotmatrix812 said in Problems after Update:
                          Out of interest, are you using MMM-WatchDog? To me it seems like it might be a long running process that could be crashing the UI. Are there any errors in the Dev Console? shift_ctrl+i and select the Console tab and look for any errors. If you are using MMM-WatchDog, what is the value set to?
                          • Dotmatrix812D
                            Dotmatrix812 @mumblebaj
                            @mumblebaj
                            I don’t have a keyboard connected to the MM…
                            But is it correct. I connect a keyboard to the MM and while it shows me the UI I open the DEV Console and check there for errors ?
                            I don’t use MMM-Watchdog.
                            Thanks for your assistance
                            mumblebajM S 2 Replies Last reply
                            • mumblebajM
                              That is correct. You could also VNC into the mirror and do the same action from the machine you use to VNC into the mirror.
                                @dotmatrix812
                                because it fails on the sample config.
                                try this
                                rm -rf node_modules
                                npm install
                                and then try again w the sample config.
                                how old is that sd card
                                • Dotmatrix812D
                                  I tried this, but same problem with sample config.
                                  SD-Card is in there fro the beginning, at max one year… Will try a new one, but have to get one first ;-)
                                  Maybe this is the solution.
                                  Thanks, I will come back to you.
                                  If it’s not the SD I will try to connect the keyboard and check the DEV Console for errors.
