Unsolved Problems after Update
@sdetweil Correct and it doesn’t for me so I would eliminate that as an issue.
Sorry for the late reply. I was busy. I will check if I have the file tomorrow.I will try what happens with the sample config.
And I will renew my api key.
Then I will come back to you all.
Many thanks for the help up till now !!!
So I tried with new API Key. But same problem:
0|MagicMirror | [23.11.2021 08:27.50.025] [LOG] Shutting down server... 0|MagicMirror | [23.11.2021 08:27.50.029] [LOG] Stopping module helper: updatenotification 0|MagicMirror | [23.11.2021 08:27.50.030] [LOG] Stopping module helper: MMM-MotionDetector 0|MagicMirror | [23.11.2021 08:27.50.032] [LOG] Stopping module helper: calendar 0|MagicMirror | [23.11.2021 08:27.50.035] [LOG] Stopping module helper: MMM-MyGarbage 0|MagicMirror | [23.11.2021 08:27.50.040] [LOG] Stopping module helper: MMM-BackgroundSlideshow 0|MagicMirror | [23.11.2021 08:27.50.045] [LOG] Stopping module helper: MMM-NOAA3 0|MagicMirror | [23.11.2021 08:27.50.050] [LOG] Stopping module helper: MMM-DWD-WarnWeather 0|MagicMirror | [23.11.2021 08:27.50.055] [LOG] Stopping module helper: MMM-TelegramBot 0|MagicMirror | [23.11.2021 08:27.50.058] [LOG] Stopping module helper: MMM-COVID19-AMPEL 0|MagicMirror | [23.11.2021 08:27.50.060] [LOG] Stopping module helper: newsfeed 0|MagicMirror | > magicmirror@2.17.1 start 0|MagicMirror | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMirror | [23.11.2021 08:28.01.293] [LOG] 0|MagicMirror | Starting MagicMirror: v2.17.1 0|MagicMirror | [23.11.2021 08:28.01.321] [LOG] 0|MagicMirror | Loading config ... 0|MagicMirror | [23.11.2021 08:28.01.342] [LOG] 0|MagicMirror | Loading module helpers ... 0|MagicMirror | [23.11.2021 08:28.01.353] [LOG] No helper found for module: alert. 0|MagicMirror | [23.11.2021 08:28.01.400] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.01.405] [LOG] Module helper loaded: updatenotification 0|MagicMirror | [23.11.2021 08:28.01.412] [LOG] No helper found for module: clock. 0|MagicMirror | [23.11.2021 08:28.01.429] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.01.431] [LOG] Module helper loaded: MMM-MotionDetector 0|MagicMirror | [23.11.2021 08:28.01.858] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.01.859] [LOG] Module helper loaded: calendar 0|MagicMirror | [23.11.2021 08:28.01.921] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.01.922] [LOG] Module helper loaded: MMM-MyGarbage 0|MagicMirror | [23.11.2021 08:28.02.243] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.02.246] [LOG] Module helper loaded: MMM-BackgroundSlideshow 0|MagicMirror | [23.11.2021 08:28.03.172] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.03.175] [LOG] Module helper loaded: MMM-NOAA3 0|MagicMirror | [23.11.2021 08:28.03.945] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.03.948] [LOG] Module helper loaded: MMM-DWD-WarnWeather 0|MagicMirror | [23.11.2021 08:28.03.953] [LOG] No helper found for module: MMM-Homematic. 0|MagicMirror | [23.11.2021 08:28.05.902] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.05.905] [LOG] Module helper loaded: MMM-TelegramBot 0|MagicMirror | [23.11.2021 08:28.06.126] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.06.127] [LOG] Module helper loaded: MMM-COVID19-AMPEL 0|MagicMirror | [23.11.2021 08:28.06.205] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:28.06.208] [LOG] Module helper loaded: newsfeed 0|MagicMirror | [23.11.2021 08:28.06.211] [LOG] All module helpers loaded. 0|MagicMirror | [23.11.2021 08:28.06.543] [LOG] 0|MagicMirror | Starting server on port 8080 ... 0|MagicMirror | [23.11.2021 08:28.06.588] [LOG] 0|MagicMirror | Server started ... 0|MagicMirror | [23.11.2021 08:28.06.590] [LOG] Connecting socket for: updatenotification 0|MagicMirror | [23.11.2021 08:28.06.593] [LOG] Connecting socket for: MMM-MotionDetector 0|MagicMirror | [23.11.2021 08:28.06.652] [LOG] 0|MagicMirror | Connecting socket for: calendar 0|MagicMirror | [23.11.2021 08:28.06.656] [LOG] Starting node helper for: calendar 0|MagicMirror | [23.11.2021 08:28.06.658] [LOG] Connecting socket for: MMM-MyGarbage 0|MagicMirror | [23.11.2021 08:28.06.659] [LOG] Starting node_helper for module: MMM-MyGarbage 0|MagicMirror | [23.11.2021 08:28.06.661] [LOG] Connecting socket for: MMM-BackgroundSlideshow 0|MagicMirror | [23.11.2021 08:28.06.665] [LOG] Connecting socket for: MMM-NOAA3 0|MagicMirror | [23.11.2021 08:28.06.683] [LOG] 0|MagicMirror | Connecting socket for: MMM-DWD-WarnWeather 0|MagicMirror | [23.11.2021 08:28.06.689] [LOG] MMM-DWD-WarnWeather helper started... 0|MagicMirror | [23.11.2021 08:28.06.692] [LOG] Connecting socket for: MMM-TelegramBot 0|MagicMirror | [23.11.2021 08:28.06.694] [LOG] Connecting socket for: MMM-COVID19-AMPEL 0|MagicMirror | [23.11.2021 08:28.06.696] [LOG] Starting node helper for: MMM-COVID19-AMPEL 0|MagicMirror | [23.11.2021 08:28.06.699] [LOG] 0|MagicMirror | Connecting socket for: newsfeed 0|MagicMirror | [23.11.2021 08:28.06.706] [LOG] Starting node helper for: newsfeed 0|MagicMirror | [23.11.2021 08:28.06.712] [LOG] Sockets connected & modules started ... 0|MagicMirror | [23.11.2021 08:28.07.229] [INFO] 0|MagicMirror | MMM-MotionDetector: monitor status is display_power=1 0|MagicMirror | [23.11.2021 08:28.07.231] [INFO] MMM-MotionDetector: monitor is ON. 0|MagicMirror | [23.11.2021 08:28.07.290] [LOG] 0|MagicMirror | Launching application. 0|MagicMirror | [23.11.2021 08:28.14.631] [LOG] 0|MagicMirror | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f3hc4hvoq0kmkb20vu5mt7tbvo%40group.calendar.google.com/private-***************93989171bfe71/basic.ics - Interval: 300000 0|MagicMirror | [23.11.2021 08:28.15.126] [INFO] 0|MagicMirror | MMM-MotionDetector: activating monitor. 0|MagicMirror | [23.11.2021 08:28.15.312] [INFO] MMM-MotionDetector: monitor status is display_power=1 0|MagicMirror | [23.11.2021 08:28.15.397] [LOG] 0|MagicMirror | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/klmriov1e3toti8ab9gf8phchk%40group.calendar.google.com/private-*****************47f366685/basic.ics - Interval: 300000 0|MagicMirror | [23.11.2021 08:28.15.429] [LOG] wb 0|MagicMirror | [23.11.2021 08:28.15.536] [LOG] 0|MagicMirror | 1637652495 0|MagicMirror | [23.11.2021 08:28.15.592] [LOG] 0|MagicMirror | [TELBOT] MMM-TelegramBot Version: 1.3.8 0|MagicMirror | [23.11.2021 08:28.15.725] [LOG] 0|MagicMirror | [TELBOT] Ready! 0|MagicMirror | [23.11.2021 08:28.15.837] [LOG] 0|MagicMirror | Create new newsfetcher for url: https://www.wiesbadener-kurier.de/rss/lokales/rheingau - Interval: 300000 0|MagicMirror | [23.11.2021 08:28.15.864] [LOG] Create new newsfetcher for url: https://www.hessenschau.de/rheinmain/index.rss - Interval: 300000 0|MagicMirror | [23.11.2021 08:28.16.062] [INFO] 0|MagicMirror | Checking git for module: default 0|MagicMirror | [23.11.2021 08:28.16.158] [INFO] 0|MagicMirror | Checking git for module: MMM-MotionDetector 0|MagicMirror | [23.11.2021 08:28.16.240] [INFO] 0|MagicMirror | Checking git for module: MMM-MyGarbage 0|MagicMirror | [23.11.2021 08:28.16.381] [INFO] Checking git for module: MMM-BackgroundSlideshow 0|MagicMirror | [23.11.2021 08:28.16.463] [INFO] 0|MagicMirror | Checking git for module: MMM-NOAA3 0|MagicMirror | [23.11.2021 08:28.16.615] [INFO] 0|MagicMirror | Checking git for module: MMM-DWD-WarnWeather 0|MagicMirror | [23.11.2021 08:28.16.837] [INFO] 0|MagicMirror | Checking git for module: MMM-Homematic 0|MagicMirror | [23.11.2021 08:28.16.997] [INFO] 0|MagicMirror | Checking git for module: MMM-TelegramBot 0|MagicMirror | [23.11.2021 08:28.17.099] [INFO] 0|MagicMirror | Checking git for module: MMM-COVID19-AMPEL 0|MagicMirror | [23.11.2021 08:28.17.327] [INFO] 0|MagicMirror | BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/wir/" for images. 0|MagicMirror | [23.11.2021 08:28.17.353] [INFO] 0|MagicMirror | BACKGROUNDSLIDESHOW: 16 files found 0|MagicMirror | [23.11.2021 08:28.19.049] [INFO] 0|MagicMirror | BACKGROUNDSLIDESHOW_NEXT_IMAGE 0|MagicMirror | [23.11.2021 08:28.19.058] [INFO] 0|MagicMirror | BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages/wir//IMG_4869.jpg" 0|MagicMirror | [23.11.2021 08:28.20.050] [INFO] 0|MagicMirror | Newsfeed-Fetcher: Broadcasting 10 items. 0|MagicMirror | [23.11.2021 08:28.21.860] [INFO] 0|MagicMirror | Newsfeed-Fetcher: Broadcasting 24 items. 0|MagicMirror | [23.11.2021 08:28.27.223] [INFO] 0|MagicMirror | Calendar-Fetcher: Broadcasting 3 events. 0|MagicMirror | [23.11.2021 08:28.31.603] [INFO] 0|MagicMirror | Calendar-Fetcher: Broadcasting 4 events. 0|MagicMirror | [23.11.2021 08:29.17.389] [INFO] BACKGROUNDSLIDESHOW_NEXT_IMAGE 0|MagicMirror | [23.11.2021 08:29.17.390] [INFO] BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages/wir//IMG_2031.JPG" 0|MagicMirror | [23.11.2021 08:29.20.996] [LOG] Shutting down server...
Then I tried with sample config.js, same issue:
0|MagicMir | [23.11.2021 08:32.09.460] [LOG] Connecting socket for: calendar 0|MagicMir | [23.11.2021 08:32.09.463] [LOG] Starting node helper for: calendar 0|MagicMir | [23.11.2021 08:32.09.466] [LOG] Connecting socket for: newsfeed 0|MagicMir | [23.11.2021 08:32.09.472] [LOG] Starting node helper for: newsfeed 0|MagicMir | [23.11.2021 08:32.09.476] [LOG] Sockets connected & modules started ... 0|MagicMir | [23.11.2021 08:32.10.229] [LOG] Launching application. 0|MagicMir | 0|MagicMir | > magicmirror@2.17.1 start 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMirror | [23.11.2021 08:32.17.658] [LOG] 0|MagicMirror | Starting MagicMirror: v2.17.1 0|MagicMirror | [23.11.2021 08:32.17.681] [LOG] 0|MagicMirror | Loading config ... 0|MagicMirror | [23.11.2021 08:32.17.703] [LOG] 0|MagicMirror | Loading module helpers ... 0|MagicMirror | [23.11.2021 08:32.17.712] [LOG] No helper found for module: alert. 0|MagicMirror | [23.11.2021 08:32.17.760] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:32.17.762] [LOG] Module helper loaded: updatenotification 0|MagicMirror | [23.11.2021 08:32.17.766] [LOG] No helper found for module: clock. 0|MagicMirror | [23.11.2021 08:32.18.182] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:32.18.185] [LOG] Module helper loaded: calendar 0|MagicMirror | [23.11.2021 08:32.18.188] [LOG] No helper found for module: compliments. 0|MagicMirror | [23.11.2021 08:32.18.191] [LOG] No helper found for module: weather. 0|MagicMirror | [23.11.2021 08:32.18.253] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:32.18.254] [LOG] Module helper loaded: newsfeed 0|MagicMirror | [23.11.2021 08:32.18.256] [LOG] All module helpers loaded. 0|MagicMirror | [23.11.2021 08:32.18.522] [LOG] 0|MagicMirror | Starting server on port 8080 ... 0|MagicMirror | [23.11.2021 08:32.18.563] [LOG] 0|MagicMirror | Server started ... 0|MagicMirror | [23.11.2021 08:32.18.567] [LOG] Connecting socket for: updatenotification 0|MagicMirror | [23.11.2021 08:32.18.574] [LOG] Connecting socket for: calendar 0|MagicMirror | [23.11.2021 08:32.18.578] [LOG] Starting node helper for: calendar 0|MagicMirror | [23.11.2021 08:32.18.582] [LOG] Connecting socket for: newsfeed 0|MagicMirror | [23.11.2021 08:32.18.586] [LOG] Starting node helper for: newsfeed 0|MagicMirror | [23.11.2021 08:32.18.590] [LOG] Sockets connected & modules started ... 0|MagicMirror | [23.11.2021 08:32.19.124] [LOG] 0|MagicMirror | Launching application. 0|MagicMirror | [23.11.2021 08:32.23.297] [LOG] Shutting down server... 0|MagicMirror | [23.11.2021 08:32.23.321] [LOG] Stopping module helper: updatenotification 0|MagicMirror | [23.11.2021 08:32.23.323] [LOG] Stopping module helper: calendar 0|MagicMirror | [23.11.2021 08:32.23.325] [LOG] Stopping module helper: newsfeed 0|MagicMirror | > magicmirror@2.17.1 start 0|MagicMirror | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMirror | [23.11.2021 08:32.34.248] [LOG] 0|MagicMirror | Starting MagicMirror: v2.17.1 0|MagicMirror | [23.11.2021 08:32.34.264] [LOG] 0|MagicMirror | Loading config ... 0|MagicMirror | [23.11.2021 08:32.34.290] [LOG] 0|MagicMirror | Loading module helpers ... 0|MagicMirror | [23.11.2021 08:32.34.295] [LOG] No helper found for module: alert. 0|MagicMirror | [23.11.2021 08:32.34.345] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:32.34.350] [LOG] 0|MagicMirror | Module helper loaded: updatenotification 0|MagicMirror | [23.11.2021 08:32.34.355] [LOG] No helper found for module: clock. 0|MagicMirror | [23.11.2021 08:32.34.765] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:32.34.768] [LOG] Module helper loaded: calendar 0|MagicMirror | [23.11.2021 08:32.34.775] [LOG] No helper found for module: compliments. 0|MagicMirror | [23.11.2021 08:32.34.782] [LOG] No helper found for module: weather. 0|MagicMirror | [23.11.2021 08:32.34.844] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:32.34.846] [LOG] Module helper loaded: newsfeed 0|MagicMirror | [23.11.2021 08:32.34.848] [LOG] All module helpers loaded. 0|MagicMirror | [23.11.2021 08:32.35.122] [LOG] 0|MagicMirror | Starting server on port 8080 ... 0|MagicMirror | [23.11.2021 08:32.35.158] [LOG] 0|MagicMirror | Server started ... 0|MagicMirror | [23.11.2021 08:32.35.160] [LOG] Connecting socket for: updatenotification 0|MagicMirror | [23.11.2021 08:32.35.163] [LOG] Connecting socket for: calendar 0|MagicMirror | [23.11.2021 08:32.35.166] [LOG] Starting node helper for: calendar 0|MagicMirror | [23.11.2021 08:32.35.172] [LOG] Connecting socket for: newsfeed 0|MagicMirror | [23.11.2021 08:32.35.178] [LOG] Starting node helper for: newsfeed 0|MagicMirror | [23.11.2021 08:32.35.182] [LOG] Sockets connected & modules started ... 0|MagicMirror | [23.11.2021 08:32.35.749] [LOG] 0|MagicMirror | Launching application. 0|MagicMirror | [23.11.2021 08:32.41.508] [LOG] 0|MagicMirror | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMirror | [23.11.2021 08:32.41.775] [LOG] 0|MagicMirror | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 0|MagicMirror | [23.11.2021 08:32.41.862] [INFO] 0|MagicMirror | Checking git for module: default 0|MagicMirror | [23.11.2021 08:32.42.919] [INFO] 0|MagicMirror | Calendar-Fetcher: Broadcasting 2 events. 0|MagicMirror | [23.11.2021 08:32.43.462] [INFO] 0|MagicMirror | Newsfeed-Fetcher: Broadcasting 58 items. 0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM 0|MagicMirror | > magicmirror@2.17.1 start 0|MagicMirror | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMirror | [23.11.2021 08:34.04.951] [LOG] 0|MagicMirror | Starting MagicMirror: v2.17.1 0|MagicMirror | [23.11.2021 08:34.04.969] [LOG] 0|MagicMirror | Loading config ... 0|MagicMirror | [23.11.2021 08:34.04.994] [LOG] 0|MagicMirror | Loading module helpers ... 0|MagicMirror | [23.11.2021 08:34.04.999] [LOG] No helper found for module: alert. 0|MagicMirror | [23.11.2021 08:34.05.054] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:34.05.057] [LOG] Module helper loaded: updatenotification 0|MagicMirror | [23.11.2021 08:34.05.059] [LOG] No helper found for module: clock. 0|MagicMirror | [23.11.2021 08:34.05.482] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:34.05.485] [LOG] Module helper loaded: calendar 0|MagicMirror | [23.11.2021 08:34.05.488] [LOG] No helper found for module: compliments. 0|MagicMirror | [23.11.2021 08:34.05.491] [LOG] No helper found for module: weather. 0|MagicMirror | [23.11.2021 08:34.05.555] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:34.05.557] [LOG] Module helper loaded: newsfeed 0|MagicMirror | [23.11.2021 08:34.05.558] [LOG] All module helpers loaded. 0|MagicMirror | [23.11.2021 08:34.05.829] [LOG] 0|MagicMirror | Starting server on port 8080 ... 0|MagicMirror | [23.11.2021 08:34.05.882] [LOG] 0|MagicMirror | Server started ... 0|MagicMirror | [23.11.2021 08:34.05.887] [LOG] Connecting socket for: updatenotification 0|MagicMirror | [23.11.2021 08:34.05.890] [LOG] Connecting socket for: calendar 0|MagicMirror | [23.11.2021 08:34.05.892] [LOG] Starting node helper for: calendar 0|MagicMirror | [23.11.2021 08:34.05.894] [LOG] Connecting socket for: newsfeed 0|MagicMirror | [23.11.2021 08:34.05.896] [LOG] Starting node helper for: newsfeed 0|MagicMirror | [23.11.2021 08:34.05.899] [LOG] Sockets connected & modules started ... 0|MagicMirror | [23.11.2021 08:34.06.443] [LOG] 0|MagicMirror | Launching application. 0|MagicMirror | [23.11.2021 08:34.12.581] [LOG] 0|MagicMirror | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMirror | [23.11.2021 08:34.12.796] [LOG] 0|MagicMirror | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 0|MagicMirror | [23.11.2021 08:34.12.890] [INFO] 0|MagicMirror | Checking git for module: default 0|MagicMirror | [23.11.2021 08:34.14.262] [INFO] 0|MagicMirror | Calendar-Fetcher: Broadcasting 2 events. 0|MagicMirror | [23.11.2021 08:34.14.395] [INFO] 0|MagicMirror | Newsfeed-Fetcher: Broadcasting 58 items. 0|MagicMirror | [23.11.2021 08:35.24.724] [LOG] Shutting down server... 0|MagicMirror | [23.11.2021 08:35.24.728] [LOG] Stopping module helper: updatenotification 0|MagicMirror | [23.11.2021 08:35.24.729] [LOG] Stopping module helper: calendar 0|MagicMirror | [23.11.2021 08:35.24.733] [LOG] 0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM 0|MagicMirror | > magicmirror@2.17.1 start 0|MagicMirror | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMirror | [23.11.2021 08:35.35.658] [LOG] 0|MagicMirror | Starting MagicMirror: v2.17.1 0|MagicMirror | [23.11.2021 08:35.35.688] [LOG] 0|MagicMirror | Loading config ... 0|MagicMirror | [23.11.2021 08:35.35.710] [LOG] 0|MagicMirror | Loading module helpers ... 0|MagicMirror | [23.11.2021 08:35.35.724] [LOG] 0|MagicMirror | No helper found for module: alert. 0|MagicMirror | [23.11.2021 08:35.35.773] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:35.35.783] [LOG] 0|MagicMirror | Module helper loaded: updatenotification 0|MagicMirror | [23.11.2021 08:35.35.789] [LOG] 0|MagicMirror | No helper found for module: clock. 0|MagicMirror | [23.11.2021 08:35.36.210] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:35.36.213] [LOG] Module helper loaded: calendar 0|MagicMirror | [23.11.2021 08:35.36.219] [LOG] No helper found for module: compliments. 0|MagicMirror | [23.11.2021 08:35.36.222] [LOG] 0|MagicMirror | No helper found for module: weather. 0|MagicMirror | [23.11.2021 08:35.36.285] [LOG] 0|MagicMirror | Initializing new module helper ... 0|MagicMirror | [23.11.2021 08:35.36.287] [LOG] Module helper loaded: newsfeed 0|MagicMirror | [23.11.2021 08:35.36.288] [LOG] All module helpers loaded. 0|MagicMirror | [23.11.2021 08:35.36.554] [LOG] 0|MagicMirror | Starting server on port 8080 ... 0|MagicMirror | [23.11.2021 08:35.36.598] [LOG] 0|MagicMirror | Server started ... 0|MagicMirror | [23.11.2021 08:35.36.603] [LOG] Connecting socket for: updatenotification 0|MagicMirror | [23.11.2021 08:35.36.611] [LOG] Connecting socket for: calendar 0|MagicMirror | [23.11.2021 08:35.36.617] [LOG] Starting node helper for: calendar 0|MagicMirror | [23.11.2021 08:35.36.622] [LOG] 0|MagicMirror | Connecting socket for: newsfeed 0|MagicMirror | [23.11.2021 08:35.36.624] [LOG] Starting node helper for: newsfeed 0|MagicMirror | [23.11.2021 08:35.36.625] [LOG] Sockets connected & modules started ... 0|MagicMirror | [23.11.2021 08:35.37.160] [LOG] 0|MagicMirror | Launching application. 0|MagicMirror | [23.11.2021 08:35.43.173] [LOG] 0|MagicMirror | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMirror | [23.11.2021 08:35.43.431] [LOG] 0|MagicMirror | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 0|MagicMirror | [23.11.2021 08:35.43.540] [INFO] 0|MagicMirror | Checking git for module: default 0|MagicMirror | [23.11.2021 08:35.44.913] [INFO] 0|MagicMirror | Calendar-Fetcher: Broadcasting 2 events. 0|MagicMirror | [23.11.2021 08:35.45.032] [INFO] 0|MagicMirror | Newsfeed-Fetcher: Broadcasting 58 items.
But here I found this in red letters
Is this maybe the problem ?
@dotmatrix812 said in Problems after Update:
Out of interest, are you using MMM-WatchDog? To me it seems like it might be a long running process that could be crashing the UI. Are there any errors in the Dev Console?
shift_ctrl+i
and select the Console tab and look for any errors. If you are using MMM-WatchDog, what is the value set to? -
@mumblebaj
I don’t have a keyboard connected to the MM…But is it correct. I connect a keyboard to the MM and while it shows me the UI I open the DEV Console and check there for errors ?
I don’t use MMM-Watchdog.
Thanks for your assistance
That is correct. You could also VNC into the mirror and do the same action from the machine you use to VNC into the mirror.
because it fails on the sample config.
try this
cd ~/MagicMirror rm -rf node_modules npm install
and then try again w the sample config.
how old is that sd card
I tried this, but same problem with sample config.
SD-Card is in there fro the beginning, at max one year… Will try a new one, but have to get one first ;-)
Maybe this is the solution.
Thanks, I will come back to you.
If it’s not the SD I will try to connect the keyboard and check the DEV Console for errors.
