    Parallel operation on TV & PC WEB-Browser
    4 Posts 4 Posters 1.1k Views 4 Watching
      bjoern
      Question:
      MM is currently running on a Pi that is connected directly to the TV. Runs without problems!
      Can I also call MM up on another computer at the same time in Browser e.g?
      If so, how can I do that?
      THX
        sdetweil @bjoern
        @bjoern
        yes, edit the MM config.js and change the address: and ipWhitelist: values
        I start with
        address:"0.0.0.0",  // means any network interface (wifi AND wired ethernet)  allows incoming requests
        ipWhitelist:[]  // allow any device on your local network to access the MM app
        with that any system in your house can access the mirror app for the same displayed content
        then on your remote computer
        http://MM_ip:MM_port
          bjoern @sdetweil
          @sdetweil thx a lot. Works fine !
            scumbelly
            bjoern,
            You could run VNC (Virtual Network Computing) as well.
