    How to send a notification
    35 Posts 3 Posters 10.4k Views 3 Watching
      Alyx @sdetweil
      @sdetweil oh… where do you think I went wrong so?
        sdetweil @Alyx
        @alyx i don’t know… i didn’t change anything in your config…
        if you use the alexa app to turn the plug on or off, do you see the notifications?
          Alyx @sdetweil
          @sdetweil ok I re added the selfie device on the alexa app and it found it fine but its now coming up as unresponsive
            sdetweil @Alyx
            @alyx so, discovery records the IP address of the ‘device’ and the port.
            so, if your pi changes ip address during boot, then it won’t work again …
            all my pi type devices have fixed addresses to avoid this problem…
              Alyx @sdetweil
              @sdetweil ah ok I’ll set a static! TBH I did have that concern but i was wrong to assume it was dynamic with the IP’s
              I’ll come back if this works or not , I have a call rn
                sdetweil @Alyx
                @alyx yeh the Alexa design is devices don’t move around, and one would only do discovery occasionally
                then u have to delete the devices and rediscover
                  Alyx @sdetweil
                  @sdetweil ok so after fighting with my interfaces file for a few days I have a static IP
                  Only issue is that I can discover devices on the Alexa app but they arent usable and just come up an unresponsive…
                  It seems the static IP has messed with that feature ? Any advise on this please?
                    sdetweil @Alyx
                    @alyx no after u get a static IP, and your mm config.js has
                    address:"0.0.0.0",
                    ipWhitelist:[],
                    to allow incoming connections from outside the pi machine
                    it should work
                      Alyx @sdetweil
                      @sdetweil I did that but still isnt working
                        sdetweil @Alyx
                        @alyx sorry, don’t know how u to debug this. it’s really hard
                        you config works perfectly here
                        your devices are found (that means the module is running) and the ssdp discovery worked
                        now alexa will call back at the server (MM system) ip address and port for each switch
                        which goes into the node_helper and is then sent up to the modulename.js to send to other modules
                        A 2 Replies Last reply Reply Quote 0
                          Alyx @sdetweil
                          @sdetweil hmmmm would you think it has something to do with my static IP?
                          I did the whole thing via my interfaces file and then reserved an IP in my router for it also.
                          Edit: I did the static in in the DHCP file. Interfaces is just to activate my USB network adapter (PI OS on desktop)
                            Alyx @sdetweil
                            @sdetweil ok so I removed my static IP and the Alexa features are working again well some…
                            Also rebooted there with no luck and deleted the devices and repaired… The monitor on/off is working but the selfie shoot isnt. I checked the dev panel and the notification isnt being received and alexa is saying its not responsive?
                              sdetweil @Alyx
                              @alyx if it’s not responsive, that means the little web server Alexa is calling didn’t work
                              that is the port you set in the notification definition
                              when you start mm, there are messages that say which ports are listening
                              that is the info Alexa records on Alexa discover devices
                                Alyx @sdetweil
                                @sdetweil yes makes sense and no I cant see any indication of a port opening up for any devices even.
                                Dev Console tab on MM
                                main.js:481 Initializing MagicMirror.
                                translator.js:128 Loading core translation file: translations/en.json
                                translator.js:146 Loading core translation fallback file: translations/en.json
                                loader.js:184 Load script: modules/MMM-Config/MMM-Config.js
                                module.js:509 Module registered: MMM-Config
                                MMM-Config.js:31 undefined is in init!
                                loader.js:155 Bootstrapping module: MMM-Config
                                loader.js:160 Scripts loaded for: MMM-Config
                                loader.js:203 Load stylesheet: modules/MMM-Config/MMM-Config.css
                                loader.js:162 Styles loaded for: MMM-Config
                                translator.js:107 MMM-Config - Load translationfalse: translations/en.json
                                loader.js:164 Translations loaded for: MMM-Config
                                loader.js:184 Load script: modules/MMM-AlexaControl/MMM-AlexaControl.js
                                module.js:509 Module registered: MMM-AlexaControl
                                loader.js:155 Bootstrapping module: MMM-AlexaControl
                                loader.js:160 Scripts loaded for: MMM-AlexaControl
                                loader.js:162 Styles loaded for: MMM-AlexaControl
                                translator.js:107 MMM-AlexaControl - Load translationfalse: translations/en.json
                                loader.js:164 Translations loaded for: MMM-AlexaControl
                                loader.js:184 Load script: modules/MMM-SleepWake/MMM-SleepWake.js
                                module.js:509 Module registered: MMM-SleepWake
                                loader.js:155 Bootstrapping module: MMM-SleepWake
                                loader.js:160 Scripts loaded for: MMM-SleepWake
                                loader.js:162 Styles loaded for: MMM-SleepWake
                                loader.js:164 Translations loaded for: MMM-SleepWake
                                loader.js:184 Load script: modules/MMM-pages/MMM-pages.js
                                module.js:509 Module registered: MMM-pages
                                loader.js:155 Bootstrapping module: MMM-pages
                                loader.js:160 Scripts loaded for: MMM-pages
                                loader.js:203 Load stylesheet: modules/MMM-pages/pages.css
                                loader.js:162 Styles loaded for: MMM-pages
                                loader.js:164 Translations loaded for: MMM-pages
                                loader.js:184 Load script: modules/MMM-page-indicator/MMM-page-indicator.js
                                module.js:509 Module registered: MMM-page-indicator
                                loader.js:155 Bootstrapping module: MMM-page-indicator
                                loader.js:160 Scripts loaded for: MMM-page-indicator
                                loader.js:203 Load stylesheet: vendor/css/font-awesome.css
                                loader.js:203 Load stylesheet: modules/MMM-page-indicator/page-indicators.css
                                loader.js:162 Styles loaded for: MMM-page-indicator
                                loader.js:164 Translations loaded for: MMM-page-indicator
                                loader.js:184 Load script: modules/MMM-Selfieshot/MMM-Selfieshot.js
                                module.js:509 Module registered: MMM-Selfieshot
                                loader.js:155 Bootstrapping module: MMM-Selfieshot
                                loader.js:160 Scripts loaded for: MMM-Selfieshot
                                loader.js:203 Load stylesheet: modules/MMM-Selfieshot/MMM-Selfieshot.css
                                loader.js:244 File already loaded: font-awesome.css
                                loader.js:162 Styles loaded for: MMM-Selfieshot
                                loader.js:164 Translations loaded for: MMM-Selfieshot
                                loader.js:184 Load script: modules/MMM-Astro/MMM-Astro.js
                                module.js:509 Module registered: MMM-Astro
                                loader.js:155 Bootstrapping module: MMM-Astro
                                loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                loader.js:160 Scripts loaded for: MMM-Astro
                                loader.js:203 Load stylesheet: modules/MMM-Astro/MMM-Astro.css
                                loader.js:162 Styles loaded for: MMM-Astro
                                loader.js:164 Translations loaded for: MMM-Astro
                                loader.js:184 Load script: modules/MMM-MoonPhase/MMM-MoonPhase.js
                                module.js:501 Check MagicMirror version for module 'MMM-MoonPhase' - Minimum version:  2.1.0 - Current version: 2.17.1
                                module.js:503 Version is ok!
                                module.js:509 Module registered: MMM-MoonPhase
                                loader.js:155 Bootstrapping module: MMM-MoonPhase
                                loader.js:160 Scripts loaded for: MMM-MoonPhase
                                loader.js:203 Load stylesheet: modules/MMM-MoonPhase/MMM-MoonPhase.css
                                loader.js:162 Styles loaded for: MMM-MoonPhase
                                translator.js:107 MMM-MoonPhase - Load translationfalse: translations/en.json
                                loader.js:164 Translations loaded for: MMM-MoonPhase
                                loader.js:184 Load script: modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.js
                                module.js:501 Check MagicMirror version for module 'MMM-OpenWeatherMapForecast' - Minimum version:  2.2.0 - Current version: 2.17.1
                                module.js:509 Module registered: MMM-OpenWeatherMapForecast
                                loader.js:155 Bootstrapping module: MMM-OpenWeatherMapForecast
                                loader.js:244 File already loaded: moment.js
                                loader.js:184 Load script: modules/MMM-OpenWeatherMapForecast/skycons.js
                                loader.js:160 Scripts loaded for: MMM-OpenWeatherMapForecast
                                loader.js:203 Load stylesheet: modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.css
                                loader.js:162 Styles loaded for: MMM-OpenWeatherMapForecast
                                loader.js:164 Translations loaded for: MMM-OpenWeatherMapForecast
                                loader.js:184 Load script: modules/lifecounter/lifecounter.js
                                module.js:509 Module registered: lifecounter
                                loader.js:155 Bootstrapping module: lifecounter
                                loader.js:160 Scripts loaded for: lifecounter
                                loader.js:162 Styles loaded for: lifecounter
                                loader.js:164 Translations loaded for: lifecounter
                                loader.js:184 Load script: modules/default/alert/alert.js
                                module.js:509 Module registered: alert
                                loader.js:155 Bootstrapping module: alert
                                loader.js:184 Load script: modules/default/alert/notificationFx.js
                                loader.js:160 Scripts loaded for: alert
                                loader.js:203 Load stylesheet: modules/default/alert/notificationFx.css
                                loader.js:162 Styles loaded for: alert
                                translator.js:107 alert - Load translationfalse: translations/en.json
                                loader.js:164 Translations loaded for: alert
                                loader.js:184 Load script: modules/default/clock/clock.js
                                module.js:509 Module registered: clock
                                loader.js:155 Bootstrapping module: clock
                                loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                                loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
                                loader.js:160 Scripts loaded for: clock
                                loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
                                loader.js:162 Styles loaded for: clock
                                loader.js:164 Translations loaded for: clock
                                loader.js:184 Load script: modules/default/compliments/compliments.js
                                module.js:509 Module registered: compliments
                                loader.js:155 Bootstrapping module: compliments
                                loader.js:160 Scripts loaded for: compliments
                                loader.js:162 Styles loaded for: compliments
                                loader.js:164
                                Snap of Config
                                let config = {
                                	address: "0.0.0.0", 	// Address to listen on, can be:
                                	port: 8080,
                                	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                	ipWhitelist: [], 	// Set [] to allow all IP addresses
                                	language: "en",
                                	locale: "en-UK",
                                	timeFormat: 12,
                                	units: "metric",
                                	serverOnly:  true,
                                		disabled: false,
                                		module:"MMM-Config",
                                		position:"top_right",  // the QR code (if requested) will appear here
                                		config:{
                                			showQR: false,
                                			//restart: "pm2",
                                			//force_update: true,
                                			//debug: true
                                        module: 'MMM-AlexaControl',
                                        position: 'middle_center',
                                	config:{
                                            image: true,
                                	    deviceName: "mirror",
                                            pm2ProcessName: "mm",
                                            vcgencmd: "hide",
                                	    startPort: 11001,
                                	    refresh: true,
                                	    restart: true,
                                	    //stop: true,
                                	    reboot: true,
                                	    shutdown: true,
                                	    monitorToggle: true,
                                	    //cecAddress: "0.0.0.0",
                                	    //usb: false
                                	    pages: 3,
                                	    notifications:[
                                        port: 11106,
                                        OnOff: false,
                                        notification: ["SELFIE_SHOOT"]
