    Enabling MM-QR Code to read the output of MM-Remote Control
    9 Posts 3 Posters 1.8k Views 3 Watching
      @sdetweil you could make the MM start script fix the config entry
      here is a little script you can use to modify the config when MM is started
      #!/bin/bash
      # get the active adapter name
      adapter=$(ip link show | grep mtu | grep -v lo | grep up | grep -v -i docker | grep "state UP" | awk -F: '{print $2}' | awk '{print $1}')
      # use the adapter name to get the assigned IP address
      address=$(ifconfig $adapter | grep "inet " | awk '{print $2}')
      # use for debugging
      # echo address for  adapter $adapter  is $address
      # use the address in sed replace of the line that starts with text:"http:/
      # -i means update file in place
      # file at the end needs the path   (~/MagicMirror/config/config.js
      sed -i "/text:\"http:/ c \    \"text\"\:\"http://$address:8080/modules/remoteControl.html\","  config.js
      u could add this to the mm.sh used to start MM on boot,etc…
      I don’t know the end of the remotecontrol link… so that has to be fixed too…
      just have something in config.js when this runs , this should run before npm start
      this works for ipV4… haven’t tried with ipV6 network
      the grep "inet " filters out the v6 address “inet6” would select just that address
      docs says
      Because IPv6 addresses contain colons, they cannot be directly used in URLs because the colons would conflict with both the protocol declaration (http:// or https://) and port numbers. Therefore, when a literal IPv6 address is used, it is encased in a bracket, like http://[2001:db8::1]:80.
      so that would be a tiny change to the sed string
      • I Offline
        Integria92
        @sdetweil did the start up script work alone to make the qr code work with mmm-remotecontrol
        address? sorry little confused
          sdetweil @Integria92
          @integria92 the qrcode module creates the qr… it takes a hard coded url
          but if u don’t know the value, its hard
          so the text above added to the mm.sh can update the config.js for the QRCode module before MM starts and all will be well…
          • I Offline
            Integria92 @sdetweil
            @sdetweil Interesting. Thanks for the quick response. so in the example above; for the qrcode config… What would the text =
            to find the output from the script?
            again, thanks a lot for your help
              @integria92 the qrcode takes some text and makes it available to the scanner
              it can be anything
              IF the text is a url, the client app offers to open it
              so, you config the module with a dummy url
              https://github.com/evghenix/MMM-QRCode
              and the the script additions change it to the machine IP address at the time mm starts.
              which the op’s daughter in college would not generally know.
              if the machine was powered off for a day/week, it’s ip address would likely change, and so a hard coded ip address would be bad.
              this code handles any dhcp address
              change and then the qrcode launches remote controls expected
              remember, until mm starts, the config.js is a useless text file
