    MMM-SpotifyConnectUI
    7 Posts 2 Posters 3.7k Views 2 Watching
      schlachtkreuzer6
      I followed the instructions from here: https://github.com/CatoAntonsen/MMM-SpotifyConnectUI but now there is no module on my MM…
      sudo systemctl status spotifyconnect.service showing this:
      pi@MagicMirror:~ $ sudo systemctl status spotifyconnect.service
      ● spotifyconnect.service - Spotify Connect
      Loaded: loaded (/etc/systemd/system/spotifyconnect.service; enabled)
      Active: active (running) since Thu 2016-12-22 08:36:06 UTC; 1h 41min ago
      Process: 502 ExecStartPre=/bin/sleep 25 (code=exited, status=0/SUCCESS)
      Main PID: 1188 (spotifyconnect.)
      CGroup: /system.slice/spotifyconnect.service
      ├─1188 /bin/bash /home/pi/spotify-connect-web/spotifyconnect.sh
      ├─1191 ./spotify-connect-web -n MAGICMIRROR -o plughw:CARD=ALSA,DEV=1
      └─1192 ./spotify-connect-web -n MAGICMIRROR -o plughw:CARD=ALSA,DEV=1
      Dec 22 10:17:38 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:38] “GET /api/info/status HTTP/1.1” 200 216 0.005329
      Dec 22 10:17:41 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:41] “GET /api/info/status HTTP/1.1” 200 216 0.073932
      Dec 22 10:17:43 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:43] “GET /api/info/status HTTP/1.1” 200 216 0.005693
      Dec 22 10:17:46 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:46] “GET /api/info/status HTTP/1.1” 200 216 0.013439
      Dec 22 10:17:48 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:48] “GET /api/info/status HTTP/1.1” 200 216 0.007797
      Dec 22 10:17:51 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:51] “GET /api/info/status HTTP/1.1” 200 216 0.006512
      Dec 22 10:17:53 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:53] “GET /api/info/status HTTP/1.1” 200 216 0.010040
      Dec 22 10:17:56 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:56] “GET /api/info/status HTTP/1.1” 200 216 0.010266
      Dec 22 10:17:58 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:17:58] “GET /api/info/status HTTP/1.1” 200 216 0.005638
      Dec 22 10:18:01 MagicMirror spotifyconnect.sh[1188]: 127.0.0.1 - - [2016-12-22 10:18:01] “GET /api/info/status HTTP/1.1” 200 216 0.005184
      further in spotify on my android device, is no magicmirror as a connected device to play on
      is there any trick? thanks for your help!
        Cato Module Developer
        What do you mean it’s “no module on my MM”? Did you follow the instructions under “Installation of the module”?
          schlachtkreuzer6
          Yeah, thats why I´m so confused ^^ do i need to install any node helper? npm install stuff like in other modules?
            Really not sure what you are talking about!
            You have understood that Spotify Connect Web is a third party service/application? I didn’t make this, so sorry for it has to go somewhere else.
            Spotify Connect UI is the module for MM I made. Just follow the instructions I referred to in my last post.
              schlachtkreuzer6
              Okay, I followed your installation guide.
              I git clone the spotify module and copy and paste the example code to my config.js but nothing is there. So no grey logo with the magic mirror letters.
              For now I fixed it with deleting the module and git clone it again :O what ever happened before!?!
                Cato Module Developer @schlachtkreuzer6
                @schlachtkreuzer6 I really don’t know. Maybe network problem during git clone? But I would guess you’ve got an error in that case.
                  Cato Module Developer @Cato
                  @Cato Auto correct error in my second post above: sorry = support
