Clock format
41 Posts 2 Posters 15.6k Views 2 Watching
  • L Offline
    louise
    In my config.js I have timeformat set at 12.
    The calendar times are in 12 format but the actual clock is showing 24. I’ve went into dev to see if there is a problem but nothing was showed. I overwrote the config.js from sample, change to 12 and imperial. Although the imperial always changes, the clock stays at 24.
    I’ve looked in the clock module but I do not see anything that I could change.
    S 1 Reply Last reply Dec 2, 2021, 10:04 PM Reply Quote 0
      sdetweil @louise
      @louise by default the clock uses the value up top for time format
      var config = {
          address: "0.0.0.0",
          port: 8090,
          basePath: "/",
          language: "en",
          locale: "en-US",
          logLevel: [
            "INFO",
            "LOG",
            "WARN",
            "ERROR",
            //"DEBUG"
          timeFormat: 24,    // <------ this value
          units: "metric",
          useHttps: false,
          ipWhitelist: [],
      I just changed mine to 12, and then the clock was amp/pm on restart
      • L Offline
        louise
        @sdetweil Sorry, I tired to use block but again, 1st time so it didn’t work. But this si what I have:
        language: "en",
        	locale: "en-US",
        	timeFormat: 12,
        	units: "imperial"
        S 1 Reply Last reply Dec 2, 2021, 10:14 PM Reply Quote 0
          sdetweil @louise
          @louise and what do you have in the clock config?
          L S 2 Replies Last reply Dec 2, 2021, 10:16 PM Reply Quote 0
          • L Offline
            louise @sdetweil
            @sdetweil /* global SunCalc */
            /* Magic Mirror
            • Module: Clock
            • By Michael Teeuw https://michaelteeuw.nl
            • MIT Licensed.
              Module.register(“clock”, {
              // Module config defaults.
              defaults: {
              displayType: “digital”, // options: digital, analog, both
               timeFormat: config.timeFormat,
               timezone: null,
               displaySeconds: true,
               showPeriod: true,
               showPeriodUpper: false,
               clockBold: false,
               showDate: true,
               showTime: true,
               showWeek: false,
               dateFormat: "dddd, LL",
               /* specific to the analog clock */
               analogSize: "175px",
               analogFace: "simple", // options: 'none', 'simple', 'face-###' (where ### is 001 to 012 inclusive)
               analogPlacement: "bottom", // options: 'top', 'bottom', 'left', 'right'
               analogShowDate: "top", // OBSOLETE, can be replaced with analogPlacement and showTime, options: false, 'top', or 'bottom'
               secondsColor: "#888888",
               showSunTimes: false,
               showMoonTimes: false,
               lat: 47.630539,
               lon: -122.344147
              // Define required scripts.
              getScripts: function () {
              return [“moment.js”, “moment-timezone.js”, “suncalc.js”];
              // Define styles.
              getStyles: function () {
              return [“clock_styles.css”];
              // Define start sequence.
              start: function () {
               // Schedule update interval.
               this.second = moment().second();
               this.minute = moment().minute();
               // Calculate how many ms should pass until next update depending on if seconds is displayed or not
               const delayCalculator = (reducedSeconds) => {
               	const EXTRA_DELAY = 50; // Deliberate imperceptible delay to prevent off-by-one timekeeping errors
               	if (this.config.displaySeconds) {
               		return 1000 - moment().milliseconds() + EXTRA_DELAY;
               	} else {
               		return (60 - reducedSeconds) * 1000 - moment().milliseconds() + EXTRA_DELAY;
               // A recursive timeout function instead of interval to avoid drifting
               const notificationTimer = () => {
               	this.updateDom();
               	// If seconds is displayed CLOCK_SECOND-notification should be sent (but not when CLOCK_MINUTE-notification is sent)
               		if (this.second !== 0) {
               			this.sendNotification("CLOCK_SECOND", this.second);
               			setTimeout(notificationTimer, delayCalculator(0));
               			return;
               	// If minute changed or seconds isn't displayed send CLOCK_MINUTE-notification
               	this.sendNotification("CLOCK_MINUTE", this.minute);
               // Set the initial timeout with the amount of seconds elapsed as reducedSeconds so it will trigger when the minute changes
               setTimeout(notificationTimer, delayCalculator(this.second));
               // Set locale.
               moment.locale(config.language);
              // Override dom generator.
              getDom: function () {
              const wrapper = document.createElement(“div”);
              wrapper.classList.add(“clockGrid”);
                * Create wrappers for analog and digital clock
               const analogWrapper = document.createElement("div");
               analogWrapper.className = "clockCircle";
               const digitalWrapper = document.createElement("div");
               digitalWrapper.className = "digital";
               digitalWrapper.style.gridArea = "center";
                * Create wrappers for DIGITAL clock
               const dateWrapper = document.createElement("div");
               const timeWrapper = document.createElement("div");
               const secondsWrapper = document.createElement("sup");
               const periodWrapper = document.createElement("span");
               const sunWrapper = document.createElement("div");
               const moonWrapper = document.createElement("div");
               const weekWrapper = document.createElement("div");
               // Style Wrappers
               dateWrapper.className = "date normal medium";
               timeWrapper.className = "time bright large light";
               secondsWrapper.className = "seconds dimmed";
               sunWrapper.className = "sun dimmed small";
               moonWrapper.className = "moon dimmed small";
               weekWrapper.className = "week dimmed medium";
               // Set content of wrappers.
               // The moment().format("h") method has a bug on the Raspberry Pi.
               // So we need to generate the timestring manually.
               // See issue: https://github.com/MichMich/MagicMirror/issues/181
               let timeString;
               const now = moment();
               if (this.config.timezone) {
               	now.tz(this.config.timezone);
               let hourSymbol = "HH";
               if (this.config.timeFormat !== 12) {
               	hourSymbol = "h";
               if (this.config.clockBold) {
               	timeString = now.format(hourSymbol + '[<span class="bold">]mm[</span>]');
               } else {
               	timeString = now.format(hourSymbol + ":mm");
               if (this.config.showDate) {
               	dateWrapper.innerHTML = now.format(this.config.dateFormat);
               	digitalWrapper.appendChild(dateWrapper);
               if (this.config.displayType !== "analog" && this.config.showTime) {
               	timeWrapper.innerHTML = timeString;
               	secondsWrapper.innerHTML = now.format("ss");
               	if (this.config.showPeriodUpper) {
               		periodWrapper.innerHTML = now.format("A");
               	} else {
               		periodWrapper.innerHTML = now.format("a");
               		timeWrapper.appendChild(secondsWrapper);
               	if (this.config.showPeriod && this.config.timeFormat !== 24) {
               		timeWrapper.appendChild(periodWrapper);
               	digitalWrapper.appendChild(timeWrapper);
                * Format the time according to the config
                * @param {object} config The config of the module
                * @param {object} time time to format
                * @returns {string} The formatted time string
               function formatTime(config, time) {
               	let formatString = hourSymbol + ":mm";
               	if (config.showPeriod && config.timeFormat !== 12) {
               		formatString += config.showPeriodUpper ? "A" : "a";
               	return moment(time).format(formatString);
                * Create wrappers for Sun Times, only if specified in config
               if (this.config.showSunTimes) {
               	const sunTimes = SunCalc.getTimes(now, this.config.lat, this.config.lon);
               	const isVisible = now.isBetween(sunTimes.sunrise, sunTimes.sunset);
               	let nextEvent;
               	if (now.isBefore(sunTimes.sunrise)) {
               		nextEvent = sunTimes.sunrise;
               	} else if (now.isBefore(sunTimes.sunset)) {
               		nextEvent = sunTimes.sunset;
               	} else {
               		const tomorrowSunTimes = SunCalc.getTimes(now.clone().add(1, "day"), this.config.lat, this.config.lon);
               		nextEvent = tomorrowSunTimes.sunrise;
               	const untilNextEvent = moment.duration(moment(nextEvent).diff(now));
               	const untilNextEventString = untilNextEvent.hours() + "h " + untilNextEvent.minutes() + "m";
               	sunWrapper.innerHTML =
               		'<span class="' +
               		(isVisible ? "bright" : "") +
               		'"><i class="fa fa-sun-o" aria-hidden="true"></i> ' +
               		untilNextEventString +
               		"</span>" +
               		'<span><i class="fa fa-arrow-up" aria-hidden="true"></i> ' +
               		formatTime(this.config, sunTimes.sunrise) +
               		"</span>" +
               		'<span><i class="fa fa-arrow-down" aria-hidden="true"></i> ' +
               		formatTime(this.config, sunTimes.sunset) +
               		"</span>";
               	digitalWrapper.appendChild(sunWrapper);
                * Create wrappers for Moon Times, only if specified in config
               if (this.config.showMoonTimes) {
               	const moonIllumination = SunCalc.getMoonIllumination(now.toDate());
               	const moonTimes = SunCalc.getMoonTimes(now, this.config.lat, this.config.lon);
               	const moonRise = moonTimes.rise;
               	let moonSet;
               	if (moment(moonTimes.set).isAfter(moonTimes.rise)) {
               		moonSet = moonTimes.set;
               	} else {
               		const nextMoonTimes = SunCalc.getMoonTimes(now.clone().add(1, "day"), this.config.lat, this.config.lon);
               		moonSet = nextMoonTimes.set;
               	const isVisible = now.isBetween(moonRise, moonSet) || moonTimes.alwaysUp === true;
               	const illuminatedFractionString = Math.round(moonIllumination.fraction * 100) + "%";
               	moonWrapper.innerHTML =
               		'<span class="' +
               		'"><i class="fa fa-moon-o" aria-hidden="true"></i> ' +
               		illuminatedFractionString +
               		"</span>" +
               		(moonRise ? formatTime(this.config, moonRise) : "...") +
               		"</span>" +
               		(moonSet ? formatTime(this.config, moonSet) : "...") +
               		"</span>";
               	digitalWrapper.appendChild(moonWrapper);
               if (this.config.showWeek) {
               	weekWrapper.innerHTML = this.translate("WEEK", { weekNumber: now.week() });
               	digitalWrapper.appendChild(weekWrapper);
                * Create wrappers for ANALOG clock, only if specified in config
               if (this.config.displayType !== "digital") {
               	// If it isn't 'digital', then an 'analog' clock was also requested
               	// Calculate the degree offset for each hand of the clock
               	const second = now.seconds() * 6,
               		minute = now.minute() * 6 + second / 60,
               		hour = ((now.hours() % 12) / 12) * 360 + 90 + minute / 12;
               	// Create wrappers
               	analogWrapper.style.width = this.config.analogSize;
               	analogWrapper.style.height = this.config.analogSize;
               	if (this.config.analogFace !== "" && this.config.analogFace !== "simple" && this.config.analogFace !== "none") {
               		analogWrapper.style.background = "url(" + this.data.path + "faces/" + this.config.analogFace + ".svg)";
               		analogWrapper.style.backgroundSize = "100%";
               		// The following line solves issue: https://github.com/MichMich/MagicMirror/issues/611
               		// analogWrapper.style.border = "1px solid black";
               		analogWrapper.style.border = "rgba(0, 0, 0, 0.1)"; //Updated fix for Issue 611 where non-black backgrounds are used
               	} else if (this.config.analogFace !== "none") {
               		analogWrapper.style.border = "2px solid white";
               	const clockFace = document.createElement("div");
               	clockFace.className = "clockFace";
               	const clockHour = document.createElement("div");
               	clockHour.id = "clockHour";
               	clockHour.style.transform = "rotate(" + hour + "deg)";
               	clockHour.className = "clockHour";
               	const clockMinute = document.createElement("div");
               	clockMinute.id = "clockMinute";
               	clockMinute.style.transform = "rotate(" + minute + "deg)";
               	clockMinute.className = "clockMinute";
               	// Combine analog wrappers
               	clockFace.appendChild(clockHour);
               	clockFace.appendChild(clockMinute);
               		const clockSecond = document.createElement("div");
               		clockSecond.id = "clockSecond";
               		clockSecond.style.transform = "rotate(" + second + "deg)";
               		clockSecond.className = "clockSecond";
               		clockSecond.style.backgroundColor = this.config.secondsColor;
               		clockFace.appendChild(clockSecond);
               	analogWrapper.appendChild(clockFace);
                * Update placement, respect old analogShowDate even if its not needed anymore
               if (this.config.displayType === "analog") {
               	// Display only an analog clock
               	if (this.config.analogShowDate === "top") {
               		wrapper.classList.add("clockGrid--bottom");
               	} else if (this.config.analogShowDate === "bottom") {
               		wrapper.classList.add("clockGrid--top");
               	} else {
               		//analogWrapper.style.gridArea = "center";
               } else if (this.config.displayType === "both") {
               	wrapper.classList.add("clockGrid--" + this.config.analogPlacement);
               wrapper.appendChild(analogWrapper);
               wrapper.appendChild(digitalWrapper);
               // Return the wrapper to the dom.
               return wrapper;
            S 1 Reply Last reply Dec 2, 2021, 10:19 PM Reply Quote 0
              @sdetweil on the code block
              has to be a blank line before and after
              and the character was ~ not `
              did u do that manually, type in the chars of hit the </> after selecting the text ?
              L 1 Reply Last reply Dec 2, 2021, 10:18 PM Reply Quote 0
              • L Offline
                louise @sdetweil
                @sdetweil I just did a ctrl a then copy and pasted
                S 1 Reply Last reply Dec 2, 2021, 10:21 PM Reply Quote 0
                  sdetweil @louise
                  @louise
                  NEVER change the CODE
                  in config.js
                  			module: "clock",
                  			position: "top_left"
                  whatever u need to configure goes inside a config:{} section,…
                  if not there, add one
                  			module: "clock",
                                              .... whatever
                  L 1 Reply Last reply Dec 2, 2021, 10:20 PM Reply Quote 0
                  • L Offline
                    louise @sdetweil
                    @sdetweil I didn’t think I did change anything.
                      sdetweil @louise
                      @louise after the paste
                      select the text in the message, and the push the </> button above the editor
                      L 1 Reply Last reply Dec 2, 2021, 10:23 PM Reply Quote 0
                      • 1 / 5
                      1 / 5
