    Clock format
    41 Posts 2 Posters 26.2k Views 2 Watching
    • L
      louise
      In my config.js I have timeformat set at 12.
      The calendar times are in 12 format but the actual clock is showing 24. I’ve went into dev to see if there is a problem but nothing was showed. I overwrote the config.js from sample, change to 12 and imperial. Although the imperial always changes, the clock stays at 24.
      I’ve looked in the clock module but I do not see anything that I could change.
        sdetweil @louise
        @louise by default the clock uses the value up top for time format
        var config = {
            address: "0.0.0.0",
            port: 8090,
            basePath: "/",
            language: "en",
            locale: "en-US",
            logLevel: [
              "INFO",
              "LOG",
              "WARN",
              "ERROR",
              //"DEBUG"
            timeFormat: 24,    // <------ this value
            units: "metric",
            useHttps: false,
            ipWhitelist: [],
        I just changed mine to 12, and then the clock was amp/pm on restart
        • L
          louise
          @sdetweil Sorry, I tired to use block but again, 1st time so it didn’t work. But this si what I have:
          language: "en",
          	locale: "en-US",
          	timeFormat: 12,
          	units: "imperial"
            sdetweil @louise
            @louise and what do you have in the clock config?
            L S 2 Replies Last reply
            • L
              louise @sdetweil
              @sdetweil /* global SunCalc */
              /* Magic Mirror
              • Module: Clock
              • By Michael Teeuw https://michaelteeuw.nl
              • MIT Licensed.
                Module.register(“clock”, {
                // Module config defaults.
                defaults: {
                displayType: “digital”, // options: digital, analog, both
                 timeFormat: config.timeFormat,
                 timezone: null,
                 displaySeconds: true,
                 showPeriod: true,
                 showPeriodUpper: false,
                 clockBold: false,
                 showDate: true,
                 showTime: true,
                 showWeek: false,
                 dateFormat: "dddd, LL",
                 /* specific to the analog clock */
                 analogSize: "175px",
                 analogFace: "simple", // options: 'none', 'simple', 'face-###' (where ### is 001 to 012 inclusive)
                 analogPlacement: "bottom", // options: 'top', 'bottom', 'left', 'right'
                 analogShowDate: "top", // OBSOLETE, can be replaced with analogPlacement and showTime, options: false, 'top', or 'bottom'
                 secondsColor: "#888888",
                 showSunTimes: false,
                 showMoonTimes: false,
                 lat: 47.630539,
                 lon: -122.344147
                // Define required scripts.
                getScripts: function () {
                return [“moment.js”, “moment-timezone.js”, “suncalc.js”];
                // Define styles.
                getStyles: function () {
                return [“clock_styles.css”];
                // Define start sequence.
                start: function () {
                 // Schedule update interval.
                 this.second = moment().second();
                 this.minute = moment().minute();
                 // Calculate how many ms should pass until next update depending on if seconds is displayed or not
                 const delayCalculator = (reducedSeconds) => {
                 	const EXTRA_DELAY = 50; // Deliberate imperceptible delay to prevent off-by-one timekeeping errors
                 	if (this.config.displaySeconds) {
                 		return 1000 - moment().milliseconds() + EXTRA_DELAY;
                 	} else {
                 		return (60 - reducedSeconds) * 1000 - moment().milliseconds() + EXTRA_DELAY;
                 // A recursive timeout function instead of interval to avoid drifting
                 const notificationTimer = () => {
                 	this.updateDom();
                 	// If seconds is displayed CLOCK_SECOND-notification should be sent (but not when CLOCK_MINUTE-notification is sent)
                 		if (this.second !== 0) {
                 			this.sendNotification("CLOCK_SECOND", this.second);
                 			setTimeout(notificationTimer, delayCalculator(0));
                 			return;
                 	// If minute changed or seconds isn't displayed send CLOCK_MINUTE-notification
                 	this.sendNotification("CLOCK_MINUTE", this.minute);
                 // Set the initial timeout with the amount of seconds elapsed as reducedSeconds so it will trigger when the minute changes
                 setTimeout(notificationTimer, delayCalculator(this.second));
                 // Set locale.
                 moment.locale(config.language);
                // Override dom generator.
                getDom: function () {
                const wrapper = document.createElement(“div”);
                wrapper.classList.add(“clockGrid”);
                  * Create wrappers for analog and digital clock
                 const analogWrapper = document.createElement("div");
                 analogWrapper.className = "clockCircle";
                 const digitalWrapper = document.createElement("div");
                 digitalWrapper.className = "digital";
                 digitalWrapper.style.gridArea = "center";
                  * Create wrappers for DIGITAL clock
                 const dateWrapper = document.createElement("div");
                 const timeWrapper = document.createElement("div");
                 const secondsWrapper = document.createElement("sup");
                 const periodWrapper = document.createElement("span");
                 const sunWrapper = document.createElement("div");
                 const moonWrapper = document.createElement("div");
                 const weekWrapper = document.createElement("div");
                 // Style Wrappers
                 dateWrapper.className = "date normal medium";
                 timeWrapper.className = "time bright large light";
                 secondsWrapper.className = "seconds dimmed";
                 sunWrapper.className = "sun dimmed small";
                 moonWrapper.className = "moon dimmed small";
                 weekWrapper.className = "week dimmed medium";
                 // Set content of wrappers.
                 // The moment().format("h") method has a bug on the Raspberry Pi.
                 // So we need to generate the timestring manually.
                 // See issue: https://github.com/MichMich/MagicMirror/issues/181
                 let timeString;
                 const now = moment();
                 if (this.config.timezone) {
                 	now.tz(this.config.timezone);
                 let hourSymbol = "HH";
                 if (this.config.timeFormat !== 12) {
                 	hourSymbol = "h";
                 if (this.config.clockBold) {
                 	timeString = now.format(hourSymbol + '[<span class="bold">]mm[</span>]');
                 } else {
                 	timeString = now.format(hourSymbol + ":mm");
                 if (this.config.showDate) {
                 	dateWrapper.innerHTML = now.format(this.config.dateFormat);
                 	digitalWrapper.appendChild(dateWrapper);
                 if (this.config.displayType !== "analog" && this.config.showTime) {
                 	timeWrapper.innerHTML = timeString;
                 	secondsWrapper.innerHTML = now.format("ss");
                 	if (this.config.showPeriodUpper) {
                 		periodWrapper.innerHTML = now.format("A");
                 	} else {
                 		periodWrapper.innerHTML = now.format("a");
                 		timeWrapper.appendChild(secondsWrapper);
                 	if (this.config.showPeriod && this.config.timeFormat !== 24) {
                 		timeWrapper.appendChild(periodWrapper);
                 	digitalWrapper.appendChild(timeWrapper);
                  * Format the time according to the config
                  * @param {object} config The config of the module
                  * @param {object} time time to format
                  * @returns {string} The formatted time string
                 function formatTime(config, time) {
                 	let formatString = hourSymbol + ":mm";
                 	if (config.showPeriod && config.timeFormat !== 12) {
                 		formatString += config.showPeriodUpper ? "A" : "a";
                 	return moment(time).format(formatString);
                  * Create wrappers for Sun Times, only if specified in config
                 if (this.config.showSunTimes) {
                 	const sunTimes = SunCalc.getTimes(now, this.config.lat, this.config.lon);
                 	const isVisible = now.isBetween(sunTimes.sunrise, sunTimes.sunset);
                 	let nextEvent;
                 	if (now.isBefore(sunTimes.sunrise)) {
                 		nextEvent = sunTimes.sunrise;
                 	} else if (now.isBefore(sunTimes.sunset)) {
                 		nextEvent = sunTimes.sunset;
                 	} else {
                 		const tomorrowSunTimes = SunCalc.getTimes(now.clone().add(1, "day"), this.config.lat, this.config.lon);
                 		nextEvent = tomorrowSunTimes.sunrise;
                 	const untilNextEvent = moment.duration(moment(nextEvent).diff(now));
                 	const untilNextEventString = untilNextEvent.hours() + "h " + untilNextEvent.minutes() + "m";
                 	sunWrapper.innerHTML =
                 		'<span class="' +
                 		(isVisible ? "bright" : "") +
                 		'"><i class="fa fa-sun-o" aria-hidden="true"></i> ' +
                 		untilNextEventString +
                 		"</span>" +
                 		'<span><i class="fa fa-arrow-up" aria-hidden="true"></i> ' +
                 		formatTime(this.config, sunTimes.sunrise) +
                 		"</span>" +
                 		'<span><i class="fa fa-arrow-down" aria-hidden="true"></i> ' +
                 		formatTime(this.config, sunTimes.sunset) +
                 		"</span>";
                 	digitalWrapper.appendChild(sunWrapper);
                  * Create wrappers for Moon Times, only if specified in config
                 if (this.config.showMoonTimes) {
                 	const moonIllumination = SunCalc.getMoonIllumination(now.toDate());
                 	const moonTimes = SunCalc.getMoonTimes(now, this.config.lat, this.config.lon);
                 	const moonRise = moonTimes.rise;
                 	let moonSet;
                 	if (moment(moonTimes.set).isAfter(moonTimes.rise)) {
                 		moonSet = moonTimes.set;
                 	} else {
                 		const nextMoonTimes = SunCalc.getMoonTimes(now.clone().add(1, "day"), this.config.lat, this.config.lon);
                 		moonSet = nextMoonTimes.set;
                 	const isVisible = now.isBetween(moonRise, moonSet) || moonTimes.alwaysUp === true;
                 	const illuminatedFractionString = Math.round(moonIllumination.fraction * 100) + "%";
                 	moonWrapper.innerHTML =
                 		'<span class="' +
                 		'"><i class="fa fa-moon-o" aria-hidden="true"></i> ' +
                 		illuminatedFractionString +
                 		"</span>" +
                 		(moonRise ? formatTime(this.config, moonRise) : "...") +
                 		"</span>" +
                 		(moonSet ? formatTime(this.config, moonSet) : "...") +
                 		"</span>";
                 	digitalWrapper.appendChild(moonWrapper);
                 if (this.config.showWeek) {
                 	weekWrapper.innerHTML = this.translate("WEEK", { weekNumber: now.week() });
                 	digitalWrapper.appendChild(weekWrapper);
                  * Create wrappers for ANALOG clock, only if specified in config
                 if (this.config.displayType !== "digital") {
                 	// If it isn't 'digital', then an 'analog' clock was also requested
                 	// Calculate the degree offset for each hand of the clock
                 	const second = now.seconds() * 6,
                 		minute = now.minute() * 6 + second / 60,
                 		hour = ((now.hours() % 12) / 12) * 360 + 90 + minute / 12;
                 	// Create wrappers
                 	analogWrapper.style.width = this.config.analogSize;
                 	analogWrapper.style.height = this.config.analogSize;
                 	if (this.config.analogFace !== "" && this.config.analogFace !== "simple" && this.config.analogFace !== "none") {
                 		analogWrapper.style.background = "url(" + this.data.path + "faces/" + this.config.analogFace + ".svg)";
                 		analogWrapper.style.backgroundSize = "100%";
                 		// The following line solves issue: https://github.com/MichMich/MagicMirror/issues/611
                 		// analogWrapper.style.border = "1px solid black";
                 		analogWrapper.style.border = "rgba(0, 0, 0, 0.1)"; //Updated fix for Issue 611 where non-black backgrounds are used
                 	} else if (this.config.analogFace !== "none") {
                 		analogWrapper.style.border = "2px solid white";
                 	const clockFace = document.createElement("div");
                 	clockFace.className = "clockFace";
                 	const clockHour = document.createElement("div");
                 	clockHour.id = "clockHour";
                 	clockHour.style.transform = "rotate(" + hour + "deg)";
                 	clockHour.className = "clockHour";
                 	const clockMinute = document.createElement("div");
                 	clockMinute.id = "clockMinute";
                 	clockMinute.style.transform = "rotate(" + minute + "deg)";
                 	clockMinute.className = "clockMinute";
                 	// Combine analog wrappers
                 	clockFace.appendChild(clockHour);
                 	clockFace.appendChild(clockMinute);
                 		const clockSecond = document.createElement("div");
                 		clockSecond.id = "clockSecond";
                 		clockSecond.style.transform = "rotate(" + second + "deg)";
                 		clockSecond.className = "clockSecond";
                 		clockSecond.style.backgroundColor = this.config.secondsColor;
                 		clockFace.appendChild(clockSecond);
                 	analogWrapper.appendChild(clockFace);
                  * Update placement, respect old analogShowDate even if its not needed anymore
                 if (this.config.displayType === "analog") {
                 	// Display only an analog clock
                 	if (this.config.analogShowDate === "top") {
                 		wrapper.classList.add("clockGrid--bottom");
                 	} else if (this.config.analogShowDate === "bottom") {
                 		wrapper.classList.add("clockGrid--top");
                 	} else {
                 		//analogWrapper.style.gridArea = "center";
                 } else if (this.config.displayType === "both") {
                 	wrapper.classList.add("clockGrid--" + this.config.analogPlacement);
                 wrapper.appendChild(analogWrapper);
                 wrapper.appendChild(digitalWrapper);
                 // Return the wrapper to the dom.
                 return wrapper;
                @sdetweil on the code block
                has to be a blank line before and after
                and the character was ~ not `
                did u do that manually, type in the chars of hit the </> after selecting the text ?
                L 1 Reply Last reply
                • L
                  louise @sdetweil
                  @sdetweil I just did a ctrl a then copy and pasted
                    sdetweil @louise
                    @louise
                    NEVER change the CODE
                    in config.js
                    			module: "clock",
                    			position: "top_left"
                    whatever u need to configure goes inside a config:{} section,…
                    if not there, add one
                    			module: "clock",
                                                .... whatever
                    • L
                      louise @sdetweil
                      @sdetweil I didn’t think I did change anything.
                        sdetweil @louise
                        @louise after the paste
                        select the text in the message, and the push the </> button above the editor
                        • L
                          louise @sdetweil
                          @sdetweil OH, that’s what you meant by block.
                          But as far as changing anything in the code I didn’t, except the 12 and imperial
                          • L
                            louise @louise
                            @louise
                            deleted  sam
                              sdetweil @louise
                              @louise said in Clock format:
                              then u changed something
                              NEVER edit the source files… ALL changes go thru config.js
                              the design is that things u specify in config.js override thing in the source code… so you NEVER have to touch the source file.
                              if you DON’T specify something, then the module default setting will be used…
                              (each module should document what that is… )
                                sdetweil @louise
                                @louise again you are pasting the source code… and missed a step,
                                after the paste into the message here, SELECT the text AGAIN, and then push the code button
                                we want to see what settings are in config.js for clock, not clock.js
                                • L
                                  louise @sdetweil
                                  aaaaa
                                  • L
                                    louise @louise
                                    @louise I forgot to take out private stuff again
                                      sdetweil @louise
                                      @louise nope, still don’t want to see the code
                                      edit your ~/MagicMirror/config/config.js
                                      find the section that says
                                         module:"clock"
                                      and copy from the line above that is
                                      to the macthing line below
                                      that is
                                      and paste THAT, and then select it all (ctrl a)
                                      and then it the button
                                      please read the two topics below in my signature…
                                      • L
                                        louise @sdetweil
                                        @sdetweil This?
                                        		module: "clock",
                                        code_text
                                        			module: "clock",
                                        code_text
                                          sdetweil @louise
                                          @louise hmm… still not sure what the problem is
                                          select/copy from config.js
                                          replay to message here
                                          paste text
                                          ctrl-a (select all)
                                          (it will have my userid in the select of the reply )
                                          press code block button
                                          I just did this and got
                                          @louise
                                          			module: "clock",
                                          L 2 Replies Last reply
                                          • L
                                            louise @sdetweil
                                            @sdetweil Would it be easier if I just started over?
