MMM-compliment showing evening compliment anytime
24 Posts 2 Posters 4.9k Views 2 Watching
    selyjohns
    I’ve a problem with MMM-compliment that showing evening compliment at anytime…
    The config is correct.
    I’ve adding hour configuration to be sure with morningStartTime, morningEndTime, afternoonStartTime and afternoonEndTime but problem persist…my MM say good night on morning…
    The date/time of my rpi3 is correct…any idea ?
    Thank you
    S 1 Reply Last reply Dec 2, 2021, 10:00 PM Reply Quote 0
      sdetweil @selyjohns
      @selyjohns did u look at any issues in the module github , issues tab?
      S 1 Reply Last reply Dec 3, 2021, 1:49 PM Reply Quote 0
        selyjohns @sdetweil
        @sdetweil No, nothing…
                                module: 'compliments',
                                position: 'lower_third',
                                        morningStartTime:3,
                                        morningEndTime:10,
                                        afternoonStartTime:13,
                                        afternoonEndTime:18,
                                        remoteFile: 'compliments.json'
        compliments.json is stored in MagicMirror/modules/default/compliments/ :) This part is good.
        S 1 Reply Last reply Dec 3, 2021, 2:08 PM Reply Quote 0
          sdetweil @selyjohns
          @selyjohns ok, one thing
          MMM-compliment means some external additional module
          module: ‘compliments’,
          means the one shipped with MagicMirror…
          S 1 Reply Last reply Dec 3, 2021, 2:17 PM Reply Quote 0
            selyjohns @sdetweil
            @sdetweil said in MMM-compliment showing evening compliment anytime:
            Oh OK, not evident.
            I speak about the module ‘compliments’, integrated with MM in default folder :)
            S 1 Reply Last reply Dec 3, 2021, 2:25 PM Reply Quote 0
              sdetweil @selyjohns
              @selyjohns well, you have a gap
                                              morningEndTime:10,
              can’t have a gap
              else it the same as ANY OTHER time but morning or afternoon…
              so 10:01->>> 12:59 OR 18:01 ->>>> 02:59
              note the defaults are
              		morningStartTime: 3,
              		morningEndTime: 12,
              		afternoonStartTime: 12,
              		afternoonEndTime: 17,
              morning 3-12, afternoon 12-17, rest 17-3
              S 1 Reply Last reply Dec 3, 2021, 2:55 PM Reply Quote 0
                selyjohns @sdetweil
                @sdetweil Ok, but i’ve added this configuration because i had the problem with default configuration.
                I can delete it. Normally we don’t need this, right ?
                S 1 Reply Last reply Dec 3, 2021, 2:57 PM Reply Quote 0
                  sdetweil @selyjohns
                  @selyjohns if u don’t need a different time set, then you would use the default…
                  all I was saying is that you have a gap in the time, and the code design demands no gap.
                  the code has
                  morning
                  afternoon
                  everything else
                  S 1 Reply Last reply Dec 3, 2021, 3:04 PM Reply Quote 0
                    selyjohns @sdetweil
                    @sdetweil Ok thank you.
                    Trying with no specific configuration -> MM say “goodnight” or “good evening” but it’s only 4 PM
                    Trying with specifig configuration with no gap, same result :(
                                                    morningStartTime:3,
                                                    morningEndTime:12,
                                                    afternoonStartTime:12,
                    S 1 Reply Last reply Dec 3, 2021, 3:09 PM Reply Quote 0
                      sdetweil @selyjohns
                      @selyjohns what does the remotefile look like?
                      I just want the things to the left of :
                      default is this
                      		compliments: {
                      			anytime: ["Hey there sexy!"],
                      			morning: ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
                      			afternoon: ["Hello, beauty!", "You look sexy!", "Looking good today!"],
                      			evening: ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
                      			"....-01-01": ["Happy new year!"]
                      S 1 Reply Last reply Dec 3, 2021, 3:25 PM Reply Quote 0
                      1 / 3
