    MMM-compliment showing evening compliment anytime
    24 Posts 2 Posters 6.5k Views 2 Watching
      selyjohns @sdetweil
      @sdetweil No, nothing…
                              module: 'compliments',
                              position: 'lower_third',
                                      morningStartTime:3,
                                      morningEndTime:10,
                                      afternoonStartTime:13,
                                      afternoonEndTime:18,
                                      remoteFile: 'compliments.json'
      compliments.json is stored in MagicMirror/modules/default/compliments/ :) This part is good.
        sdetweil @selyjohns
        @selyjohns ok, one thing
        MMM-compliment means some external additional module
        module: ‘compliments’,
        means the one shipped with MagicMirror…
          selyjohns @sdetweil
          @sdetweil said in MMM-compliment showing evening compliment anytime:
          Oh OK, not evident.
          I speak about the module ‘compliments’, integrated with MM in default folder :)
            sdetweil @selyjohns
            @selyjohns well, you have a gap
                                            morningEndTime:10,
            can’t have a gap
            else it the same as ANY OTHER time but morning or afternoon…
            so 10:01->>> 12:59 OR 18:01 ->>>> 02:59
            note the defaults are
            		morningStartTime: 3,
            		morningEndTime: 12,
            		afternoonStartTime: 12,
            		afternoonEndTime: 17,
            morning 3-12, afternoon 12-17, rest 17-3
              selyjohns @sdetweil
              @sdetweil Ok, but i’ve added this configuration because i had the problem with default configuration.
              I can delete it. Normally we don’t need this, right ?
                sdetweil @selyjohns
                @selyjohns if u don’t need a different time set, then you would use the default…
                all I was saying is that you have a gap in the time, and the code design demands no gap.
                the code has
                morning
                afternoon
                everything else
                  selyjohns @sdetweil
                  @sdetweil Ok thank you.
                  Trying with no specific configuration -> MM say “goodnight” or “good evening” but it’s only 4 PM
                  Trying with specifig configuration with no gap, same result :(
                                                  morningStartTime:3,
                                                  morningEndTime:12,
                                                  afternoonStartTime:12,
                    sdetweil @selyjohns
                    @selyjohns what does the remotefile look like?
                    I just want the things to the left of :
                    default is this
                    		compliments: {
                    			anytime: ["Hey there sexy!"],
                    			morning: ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
                    			afternoon: ["Hello, beauty!", "You look sexy!", "Looking good today!"],
                    			evening: ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
                    			"....-01-01": ["Happy new year!"]
                      selyjohns @sdetweil
                      Here’s :)
                      	"anytime": [
                      			"Comment ça va ?",
                      			"Bonjour"
                      	"morning": [
                      			"Un petit café ?",
                      			"Bien dormi ?",
                      			"Bonne journée !"
                      	"evening": [
                      			"Bonne soirée !",
                      			"Bonne nuit...",
                      			"Agréable soirée"
                      	"day_sunny": [
                      			"Le temps est ensoleillé aujourd'hui !",
                      			"C'est une belle journée"
                      	"day_cloudy": [
                      			"C'est nuageux aujourd'hui..."
                      	"snow": [
                      			"Bataille de boules de neige !!!"
                      	"rain": [
                      			"N'oublie pas ton parapluie...",
                      			"Et si on restait au sec aujourd'hui ?"
                      With " as indicated on the readme when using remote file.
                      But, i had the problem before using remote file, i’ve do this hoping this would resolve the problem, but it’s dont.
                      Is it possible to “remove/reinstall” default module like compliments ?
                        sdetweil @selyjohns
                        @selyjohns said in MMM-compliment showing evening compliment anytime:
                        no, but u can get the original code back (which you shouldn’t have changed)
                        do
                        check for changed files
                        git status
                        if the compliments module has anything is listed as modified
                        git checkout modules/default/compliments/compliments.js   (or whatever filename
