    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
      pastormingle @sdetweil
      @sdetweil i have a calendar listed but i have multiple calendars.
      d577000e-9e4e-4cd9-84b6-3180eb403492-image.png {
      module: ‘MMM-Carousel’,
      transitionInterval: 10000,
      ignoreModules: [‘clock’, ‘alert’],
      mode: ‘slides’,
      slides: [
      [‘helloworld’,‘calendar’],
      [‘MMM-RAIN-MAP’,‘weather’],
      module: “weather”,
      position: “right_top”,
      header: “Weather Forecast”,
      weatherProvider: “openweathermap”,
      type: “forecast”,
      units: “imperial”,
      windUnits: “imperial”,
      fade: “false”,
      //locationID: “5128581”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      apiKey: “2f0339fa6aa1b719849a3562a0c18d11”
      module: “MMM-RAIN-MAP”,
      position: “center_bottom”,
      header: “Sumiton Weather Radar”,
      animationSpeed: 600,
      displayClockSymbol: true,
      displayTime: true,
      extraDelayLastFrame: 2000,
      height: “405px”,
      lat: 33.75563027313188,
      lng: -87.02770795126425,
      map: “OSM”,
      markers: [
      { lat: 33.7556305527313188, lng: -87.0277075595126425, color: “red” },
      { lat: 33.75563027313188, lng: -87.02770795126425, color: “blue” }
      onlyOnRain: false,
      opacity: 0.65,
      timeFormat: 12,
      updateIntervalInSeconds: 3000,
      width: “415px”,
      zoom: 9.9,
      zoomOutEach: 1,
      zoomOutLevel: 2,
      					module: "helloworld",
      					position: "top_left",	// This can be any of the regions.
      						text: "Hello World 123345"
      								colored: true,
      					                        header: "Charlottes Calendar",
      								position: "left",
      					                        timeFormat: 'absolute',
      					                        broadcastPastEvents: false,
      					                        fade: false,
      					                        showEnd: true,
      					                        color: '#ffffff',
      					                              tableClass: "medium",
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @pastormingle
        @pastormingle right_top and center_bottom are not positions on the mirror if I am not mistaken. See this link for more information regarding positions: https://forum.magicmirror.builders/topic/286/regions
        P S 2 Replies Last reply
          pastormingle @mumblebaj
          @mumblebaj So I’ve loaded the default config.js just to see if the course module is working at all. I’ve sent to use the global function and still, I see nothing changing on the screen.
          /* Magic Mirror Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * see https://docs.magicmirror.builders/getting-started/configuration.html#general
           * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
          	address: "localhost", 	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
          	language: "en",
          	locale: "en-US",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			header: "US Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          			module: "compliments",
          			position: "lower_third"
          			module: "weather",
          				type: "current",
          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				apiKey: "YOUR_OPENWEATHER_API_KEY"
          			module: "weather",
          			header: "Weather Forecast",
          				type: "forecast",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
                      module: 'MMM-Carousel',
                          ignoreModules: [''],
                          mode: 'global'
          • mumblebajM
            @pastormingle said in MMM-Carousel not displaying:
            MMM-Carousel
            Just a silly question, when you installed the module. did you go into the MMM-Carousel folder and ran npm install?
            P 1 Reply Last reply
              sdetweil @mumblebaj
              @pastormingle @mumblebaj also see position here
                @mumblebaj said in MMM-Carousel not displaying:
                npm install
                not a silly question as it’s not in the install readme file…
                Installation
                Run these commands at the root of your magic mirror install.
                cd modules
                git clone https://github.com/shbatm/MMM-Carousel
                Using the module
                To use this module, add the following configuration block to the modules array in the config/config.js file:
                S mumblebajM 2 Replies Last reply
                  sdetweil @pastormingle
                  @pastormingle doesn’t have a node helper, so doesn’t need an npm install
                  • mumblebajM
                    @pastormingle Yes, you have to run nom install in the module folder. I saw that the module has a package.json with dependencies. I just installed it on my machine and it works. One thing to note, it only rotates modules that occupying the same position on the mirror. I have 2 modules that occupy the top_right position and those are rotating and the others remain unchanged when using the global config option.
                    • mumblebajM
                      @sdetweil Hi Sam, For my understanding. What about dependencies in the package.json? If those are not default with MM then you have to run npm install I would think? Or is my understanding incorrect?
                        @mumblebaj do you have an example of your config?
                        P mumblebajM 2 Replies Last reply
                          pastormingle @pastormingle
                          @pastormingle I sent my weather module to use the same as the clock position but still nothing…
                          • mumblebajM
                            @pastormingle I used one of the default.
                                            ignoreModules: [],
                                            mode: 'positional',
                                            top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000},
                                            top_right: {enabled: true, ignoreModules: ['currentweather']}
                            Just tested the Global option and it works fine and rotates all the modules one by one.
                            Here is the config for global
                                            ignoreModules: ['clock'],
                                            mode: 'global'
                              @mumblebaj hum… this is my config…
                               * MIT Licensed.
                              let config = {
                              	port: 8080,
                              	language: "en",
                              	locale: "en-US",
                              	timeFormat: 24,
                              	units: "metric",
                              			module: "alert",
                              			position: "top_bar"
                              			module: "clock",
                              			module: "weather",
                              				type: "current",
                              			module: "weather",
                              				type: "forecast",
                              			module: "newsfeed",
                              				feeds: [
                                              ignoreModules: [],
                                              mode: 'global'
                              mumblebajM S 2 Replies Last reply
                              • mumblebajM
                                @pastormingle Are there any errors where you start the mirror? I.e. if you do npm start are there any errors in the terminal window or if you use pm2 you can check the pm2 logs. You can also check the Developer Console, do shift_ctrl + i and select the console tab. See if there are any errors there. If no errors you should see something like the below, modules suspended…module resumed
                                P 2 Replies Last reply
                                  @pastormingle please use code block around config info
                                      @sdetweil not sure what that means?
                                      • mumblebajM
                                        @pastormingle That means that something is already running with that IP. Do you only have 1 instance of MM running?
                                          @mumblebaj The IP conflict is due to me ssh into the pi and starting magic mirror… I am referring to the commits from sdetweil that said “please use code block around config info” So still not working… But it looks like the carousel module is working…
                                          • mumblebajM
                                            @pastormingle What Sam was saying was the when posting your config, you need to set it in a code block. That is done by selecting the config you posted and then pressing the </> button at the top of the window. That would wrap the config in a code block and make it look “pretty”.
                                            I am glad your Carousel is now working.
                                            • 1 / 5
