    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
      pastormingle @mumblebaj
      @mumblebaj
      /* Magic Mirror Config Sample
      * By Michael Teeuw https://michaelteeuw.nl
      * MIT Licensed.
      * see https://docs.magicmirror.builders/getting-started/configuration.html#general
      * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
         address: "localhost", 	// Address to listen on, can be:
         port: 8080,
         basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
         ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
         language: "en",
         locale: "en-US",
         timeFormat: 24,
         units: "metric",
         		module: "alert",
         		module: "updatenotification",
         		position: "top_bar"
         		module: "clock",
         		position: "top_left"
         		header: "US Holidays",
         					symbol: "calendar-check",
         					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
         		module: "compliments",
         		module: "newsfeed",
         		position: "bottom_bar",
         			feeds: [
         					title: "New York Times",
         					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
         			showSourceTitle: true,
         			showPublishDate: true,
         			broadcastNewsFeeds: true,
         			broadcastNewsUpdates: true
                 module: 'MMM-Carousel',
                     transitionInterval: 1000,
                     ignoreModules: [],
                     mode: 'global'
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @pastormingle
        @pastormingle As mentioned previously, are the any errors in the developers window? Do you have any errors in the terminal window? I am using the exact same config as you for Carousel and it work just fine for me
          sdetweil @mumblebaj
          @mumblebaj said in MMM-Carousel not displaying:
          That would wrap the config in a code block and make it look “pretty”.
          not pretty, just more readable
          P 1 Reply Last reply
            sdetweil @mumblebaj
            @mumblebaj yes, generally, w package.json you would need an npm install. but in this case, the dependencies after for testing not running
              pastormingle @sdetweil
              @sdetweil ```
              Here is what is in my developer window under the console tab… I don’t see anything that stands out.
              loader.js:164 Translations loaded for: clock
              loader.js:184 Load script: modules/default/calendar/calendar.js
              module.js:501 Check MagicMirror version for module ‘calendar’ - Minimum version: 2.1.0 - Current version: 2.16.0
              module.js:503 Version is ok!
              module.js:509 Module registered: calendar
              loader.js:155 Bootstrapping module: calendar
              loader.js:244 File already loaded: moment.js
              loader.js:160 Scripts loaded for: calendar
              loader.js:203 Load stylesheet: modules/default/calendar/calendar.css
              loader.js:244 File already loaded: font-awesome.css
              loader.js:162 Styles loaded for: calendar
              loader.js:164 Translations loaded for: calendar
              loader.js:184 Load script: modules/default/compliments/compliments.js
              module.js:509 Module registered: compliments
              loader.js:155 Bootstrapping module: compliments
              loader.js:160 Scripts loaded for: compliments
              loader.js:162 Styles loaded for: compliments
              loader.js:164 Translations loaded for: compliments
              loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
              module.js:509 Module registered: newsfeed
              loader.js:155 Bootstrapping module: newsfeed
              loader.js:160 Scripts loaded for: newsfeed
              loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
              loader.js:162 Styles loaded for: newsfeed
              loader.js:164 Translations loaded for: newsfeed
              loader.js:184 Load script: modules/MMM-Carousel/MMM-Carousel.js
              module.js:501 Check MagicMirror version for module ‘MMM-Carousel’ - Minimum version: 2.3.0 - Current version: 2.16.0
              module.js:509 Module registered: MMM-Carousel
              loader.js:155 Bootstrapping module: MMM-Carousel
              loader.js:160 Scripts loaded for: MMM-Carousel
              loader.js:203 Load stylesheet: modules/MMM-Carousel/MMM-Carousel.css
              loader.js:162 Styles loaded for: MMM-Carousel
              loader.js:164 Translations loaded for: MMM-Carousel
              loader.js:203 Load stylesheet: css/custom.css
              :8080/modules/default/alert/alert.js:165 Starting module: alert
              :8080/modules/defaul…enotification.js:21 Starting module: updatenotification
              :8080/modules/default/clock/clock.js:46 Starting module: clock
              :8080/modules/defaul…ndar/calendar.js:87 Starting module: calendar
              :8080/modules/defaul…s/compliments.js:38 Starting module: compliments
              :8080/modules/defaul…feed/newsfeed.js:63 Starting module: newsfeed
              main.js:499 All modules started!
              9
              XHR finished loading: GET “”.
              mumblebajM S 2 Replies Last reply
                @sdetweil I tried to manual run the MMM-Carousel.js but returned the following. 20bc915c-97a4-40af-9e49-7932576b932b-image.png MMM-c93303dc-dee4-475f-9a04-d0f51fd8b8f2-image.png
                  sdetweil @pastormingle
                  @pastormingle don’t know why you would do that. it has to run under MagicMirror…
                  • mumblebajM
                    @pastormingle Do you see any of the module suspended or module resumed stuff?
                      @pastormingle @mumblebaj
                      ok, I just debugged this, and there is a MM design changed that impacts this module… and maybe others…
                      if there is NO ‘position’ set, then the initial getDom() is not called. and this module DEPENDS on that
                      note that without position its getDom() is NEVER called…
                      so, set
                      position: ‘bottom_bar’
                      in the MMM-Carousel module config
                        @sdetweil said in MMM-Carousel not displaying:
                        so that would be in the config.js file or the www-Carousel.js file?
                          @pastormingle ALL config options ALWAYS go in config.js
                          NEVER edit the module source file…
                          the design is options in config.js override any options defined in the module
                          any options not USED in config.js use the defaults provided by the module
                          but position is a MM config option (outside the config:{} block for the module),
                          NOT a module config option (inside the config:{} block for module)
                          see
                          https://docs.magicmirror.builders/modules/configuration.html#example
                            @pastormingle
                                 position: 'bottom_bar',
                                    whatever config for this module
                              @sdetweil ```
                              So now is gets an Undefined displayed at the bottom of the display..
                                              transitionInterval: 10000,
                                              ignoreModules: [],
                                              mode: 'global'
                              ![45d7e7ab-536a-4ba1-b849-c0ba73a9344f-image.png](/assets/uploads/files/1638977941062-45d7e7ab-536a-4ba1-b849-c0ba73a9344f-image.png)
                                pastormingle @pastormingle
                                @pastormingle getting the following error in the dev windows now.
                                TypeError: Failed to execute ‘appendChild’ on ‘Node’: parameter 1 is not of type ‘Node’.
                                at updateModuleContent (main.js:215)
                                at main.js:142
                                at new Promise ()
                                at updateDomWithContent (main.js:140)
                                at main.js:122
                                  @pastormingle this is my config
                                                  ignoreModules: ['clock', 'alert'],
                                                  mode: 'slides',
                                                  slides: [
                                                      ['calendar', 'compliments', 'weather'],
                                                      ['newsfeed'],
                                  but you wanted slides mode… why are u set to global?
                                    @pastormingle
                                    I changed ‘slides’ to ‘global’ and it worked too
                                    you are using this version
                                    https://github.com/shbatm/MMM-Carousel.git
                                    in the MMM-Carousel folder do
                                    git remote -v
                                      pastormingle
                                      git remote -v
                                      same.
                                      • mumblebajM
                                        @pastormingle So, what @sdetweil meant was that in the terminal window in the ~/MagicMirror/modules/MMM-Carousel/ folder you should run the command git remote -v and post the output of that.
                                        For me it is:
                                        origin  https://github.com/barnabycolby/MMM-Carousel (fetch)
                                        origin  https://github.com/barnabycolby/MMM-Carousel (push)
                                          sdetweil @mumblebaj
                                          @mumblebaj hm… that one also works… (but works without position, but doesn’t have a getDom function)
                                          the sabatm version has page indicator buttons u can push too…
                                          • mumblebajM
                                            @sdetweil Ah, now I understand the earlier differences. We were looking at different modules. Which one is @pastormingle using?
                                            • 2 / 5
