    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
      pastormingle @mumblebaj
      @mumblebaj sorry mumblebaj that was a typo it’s not working… Any other suggestions?
        @mumblebaj
        /* Magic Mirror Config Sample
        * By Michael Teeuw https://michaelteeuw.nl
        * MIT Licensed.
        * see https://docs.magicmirror.builders/getting-started/configuration.html#general
        * and https://docs.magicmirror.builders/modules/configuration.html
        let config = {
           address: "localhost", 	// Address to listen on, can be:
           port: 8080,
           basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
           ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
           language: "en",
           locale: "en-US",
           timeFormat: 24,
           units: "metric",
           		module: "alert",
           		module: "updatenotification",
           		position: "top_bar"
           		module: "clock",
           		position: "top_left"
           		header: "US Holidays",
           					symbol: "calendar-check",
           					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
           		module: "compliments",
           		module: "newsfeed",
           		position: "bottom_bar",
           			feeds: [
           					title: "New York Times",
           					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
           			showSourceTitle: true,
           			showPublishDate: true,
           			broadcastNewsFeeds: true,
           			broadcastNewsUpdates: true
                   module: 'MMM-Carousel',
                       transitionInterval: 1000,
                       ignoreModules: [],
                       mode: 'global'
        mumblebajM 1 Reply Last reply
        • mumblebajM
          mumblebaj Module Developer @pastormingle
          @pastormingle As mentioned previously, are the any errors in the developers window? Do you have any errors in the terminal window? I am using the exact same config as you for Carousel and it work just fine for me
            sdetweil @mumblebaj
            @mumblebaj said in MMM-Carousel not displaying:
            That would wrap the config in a code block and make it look “pretty”.
            not pretty, just more readable
            P 1 Reply Last reply
              sdetweil @mumblebaj
              @mumblebaj yes, generally, w package.json you would need an npm install. but in this case, the dependencies after for testing not running
                pastormingle @sdetweil
                @sdetweil ```
                Here is what is in my developer window under the console tab… I don’t see anything that stands out.
                loader.js:164 Translations loaded for: clock
                loader.js:184 Load script: modules/default/calendar/calendar.js
                module.js:501 Check MagicMirror version for module ‘calendar’ - Minimum version: 2.1.0 - Current version: 2.16.0
                module.js:503 Version is ok!
                module.js:509 Module registered: calendar
                loader.js:155 Bootstrapping module: calendar
                loader.js:244 File already loaded: moment.js
                loader.js:160 Scripts loaded for: calendar
                loader.js:203 Load stylesheet: modules/default/calendar/calendar.css
                loader.js:244 File already loaded: font-awesome.css
                loader.js:162 Styles loaded for: calendar
                loader.js:164 Translations loaded for: calendar
                loader.js:184 Load script: modules/default/compliments/compliments.js
                module.js:509 Module registered: compliments
                loader.js:155 Bootstrapping module: compliments
                loader.js:160 Scripts loaded for: compliments
                loader.js:162 Styles loaded for: compliments
                loader.js:164 Translations loaded for: compliments
                loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
                module.js:509 Module registered: newsfeed
                loader.js:155 Bootstrapping module: newsfeed
                loader.js:160 Scripts loaded for: newsfeed
                loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
                loader.js:162 Styles loaded for: newsfeed
                loader.js:164 Translations loaded for: newsfeed
                loader.js:184 Load script: modules/MMM-Carousel/MMM-Carousel.js
                module.js:501 Check MagicMirror version for module ‘MMM-Carousel’ - Minimum version: 2.3.0 - Current version: 2.16.0
                module.js:509 Module registered: MMM-Carousel
                loader.js:155 Bootstrapping module: MMM-Carousel
                loader.js:160 Scripts loaded for: MMM-Carousel
                loader.js:203 Load stylesheet: modules/MMM-Carousel/MMM-Carousel.css
                loader.js:162 Styles loaded for: MMM-Carousel
                loader.js:164 Translations loaded for: MMM-Carousel
                loader.js:203 Load stylesheet: css/custom.css
                :8080/modules/default/alert/alert.js:165 Starting module: alert
                :8080/modules/defaul…enotification.js:21 Starting module: updatenotification
                :8080/modules/default/clock/clock.js:46 Starting module: clock
                :8080/modules/defaul…ndar/calendar.js:87 Starting module: calendar
                :8080/modules/defaul…s/compliments.js:38 Starting module: compliments
                :8080/modules/defaul…feed/newsfeed.js:63 Starting module: newsfeed
                main.js:499 All modules started!
                9
                XHR finished loading: GET “”.
                mumblebajM S 2 Replies Last reply
                  @sdetweil I tried to manual run the MMM-Carousel.js but returned the following. 20bc915c-97a4-40af-9e49-7932576b932b-image.png MMM-c93303dc-dee4-475f-9a04-d0f51fd8b8f2-image.png
                    sdetweil @pastormingle
                    @pastormingle don’t know why you would do that. it has to run under MagicMirror…
                    • mumblebajM
                      @pastormingle Do you see any of the module suspended or module resumed stuff?
                        @pastormingle @mumblebaj
                        ok, I just debugged this, and there is a MM design changed that impacts this module… and maybe others…
                        if there is NO ‘position’ set, then the initial getDom() is not called. and this module DEPENDS on that
                        note that without position its getDom() is NEVER called…
                        so, set
                        position: ‘bottom_bar’
                        in the MMM-Carousel module config
                          @sdetweil said in MMM-Carousel not displaying:
                          so that would be in the config.js file or the www-Carousel.js file?
                            @pastormingle ALL config options ALWAYS go in config.js
                            NEVER edit the module source file…
                            the design is options in config.js override any options defined in the module
                            any options not USED in config.js use the defaults provided by the module
                            but position is a MM config option (outside the config:{} block for the module),
                            NOT a module config option (inside the config:{} block for module)
                            see
                            https://docs.magicmirror.builders/modules/configuration.html#example
                              @pastormingle
                                   position: 'bottom_bar',
                                      whatever config for this module
                                @sdetweil ```
                                So now is gets an Undefined displayed at the bottom of the display..
                                                transitionInterval: 10000,
                                                ignoreModules: [],
                                                mode: 'global'
                                ![45d7e7ab-536a-4ba1-b849-c0ba73a9344f-image.png](/assets/uploads/files/1638977941062-45d7e7ab-536a-4ba1-b849-c0ba73a9344f-image.png)
                                  pastormingle @pastormingle
                                  @pastormingle getting the following error in the dev windows now.
                                  TypeError: Failed to execute ‘appendChild’ on ‘Node’: parameter 1 is not of type ‘Node’.
                                  at updateModuleContent (main.js:215)
                                  at main.js:142
                                  at new Promise ()
                                  at updateDomWithContent (main.js:140)
                                  at main.js:122
                                    @pastormingle this is my config
                                                    ignoreModules: ['clock', 'alert'],
                                                    mode: 'slides',
                                                    slides: [
                                                        ['calendar', 'compliments', 'weather'],
                                                        ['newsfeed'],
                                    but you wanted slides mode… why are u set to global?
                                      @pastormingle
                                      I changed ‘slides’ to ‘global’ and it worked too
                                      you are using this version
                                      https://github.com/shbatm/MMM-Carousel.git
                                      in the MMM-Carousel folder do
                                      git remote -v
                                        pastormingle
                                        git remote -v
                                        same.
                                        • mumblebajM
                                          @pastormingle So, what @sdetweil meant was that in the terminal window in the ~/MagicMirror/modules/MMM-Carousel/ folder you should run the command git remote -v and post the output of that.
                                          For me it is:
                                          origin  https://github.com/barnabycolby/MMM-Carousel (fetch)
                                          origin  https://github.com/barnabycolby/MMM-Carousel (push)
                                            sdetweil @mumblebaj
                                            @mumblebaj hm… that one also works… (but works without position, but doesn’t have a getDom function)
                                            the sabatm version has page indicator buttons u can push too…
                                            • 2 / 5
