    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 58.6k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @pastormingle
      @pastormingle That means that something is already running with that IP. Do you only have 1 instance of MM running?
        pastormingle @mumblebaj
        @mumblebaj The IP conflict is due to me ssh into the pi and starting magic mirror… I am referring to the commits from sdetweil that said “please use code block around config info” So still not working… But it looks like the carousel module is working…
          @pastormingle What Sam was saying was the when posting your config, you need to set it in a code block. That is done by selecting the config you posted and then pressing the </> button at the top of the window. That would wrap the config in a code block and make it look “pretty”.
          I am glad your Carousel is now working.
          P S 2 Replies Last reply Reply Quote 0
            @mumblebaj sorry mumblebaj that was a typo it’s not working… Any other suggestions?
              @mumblebaj
              /* Magic Mirror Config Sample
              * By Michael Teeuw https://michaelteeuw.nl
              * MIT Licensed.
              * see https://docs.magicmirror.builders/getting-started/configuration.html#general
              * and https://docs.magicmirror.builders/modules/configuration.html
              let config = {
                 address: "localhost", 	// Address to listen on, can be:
                 port: 8080,
                 basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                 ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                 language: "en",
                 locale: "en-US",
                 timeFormat: 24,
                 units: "metric",
                 		module: "alert",
                 		module: "updatenotification",
                 		position: "top_bar"
                 		module: "clock",
                 		position: "top_left"
                 		header: "US Holidays",
                 					symbol: "calendar-check",
                 					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                 		module: "compliments",
                 		module: "newsfeed",
                 		position: "bottom_bar",
                 			feeds: [
                 					title: "New York Times",
                 					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                 			showSourceTitle: true,
                 			showPublishDate: true,
                 			broadcastNewsFeeds: true,
                 			broadcastNewsUpdates: true
                         module: 'MMM-Carousel',
                             transitionInterval: 1000,
                             ignoreModules: [],
                             mode: 'global'
                @pastormingle As mentioned previously, are the any errors in the developers window? Do you have any errors in the terminal window? I am using the exact same config as you for Carousel and it work just fine for me
                  sdetweil @mumblebaj
                  @mumblebaj said in MMM-Carousel not displaying:
                  not pretty, just more readable
                    sdetweil @mumblebaj
                    @mumblebaj yes, generally, w package.json you would need an npm install. but in this case, the dependencies after for testing not running
                      pastormingle @sdetweil
                      @sdetweil ```
                      Here is what is in my developer window under the console tab… I don’t see anything that stands out.
                      loader.js:164 Translations loaded for: clock
                      loader.js:184 Load script: modules/default/calendar/calendar.js
                      module.js:501 Check MagicMirror version for module ‘calendar’ - Minimum version: 2.1.0 - Current version: 2.16.0
                      module.js:503 Version is ok!
                      module.js:509 Module registered: calendar
                      loader.js:155 Bootstrapping module: calendar
                      loader.js:244 File already loaded: moment.js
                      loader.js:160 Scripts loaded for: calendar
                      loader.js:203 Load stylesheet: modules/default/calendar/calendar.css
                      loader.js:244 File already loaded: font-awesome.css
                      loader.js:162 Styles loaded for: calendar
                      loader.js:164 Translations loaded for: calendar
                      loader.js:184 Load script: modules/default/compliments/compliments.js
                      module.js:509 Module registered: compliments
                      loader.js:155 Bootstrapping module: compliments
                      loader.js:160 Scripts loaded for: compliments
                      loader.js:162 Styles loaded for: compliments
                      loader.js:164 Translations loaded for: compliments
                      loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
                      module.js:509 Module registered: newsfeed
                      loader.js:155 Bootstrapping module: newsfeed
                      loader.js:160 Scripts loaded for: newsfeed
                      loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
                      loader.js:162 Styles loaded for: newsfeed
                      loader.js:164 Translations loaded for: newsfeed
                      loader.js:184 Load script: modules/MMM-Carousel/MMM-Carousel.js
                      module.js:501 Check MagicMirror version for module ‘MMM-Carousel’ - Minimum version: 2.3.0 - Current version: 2.16.0
                      module.js:509 Module registered: MMM-Carousel
                      loader.js:155 Bootstrapping module: MMM-Carousel
                      loader.js:160 Scripts loaded for: MMM-Carousel
                      loader.js:203 Load stylesheet: modules/MMM-Carousel/MMM-Carousel.css
                      loader.js:162 Styles loaded for: MMM-Carousel
                      loader.js:164 Translations loaded for: MMM-Carousel
                      loader.js:203 Load stylesheet: css/custom.css
                      :8080/modules/default/alert/alert.js:165 Starting module: alert
                      :8080/modules/defaul…enotification.js:21 Starting module: updatenotification
                      :8080/modules/default/clock/clock.js:46 Starting module: clock
                      :8080/modules/defaul…ndar/calendar.js:87 Starting module: calendar
                      :8080/modules/defaul…s/compliments.js:38 Starting module: compliments
                      :8080/modules/defaul…feed/newsfeed.js:63 Starting module: newsfeed
                      main.js:499 All modules started!
                      9
                      XHR finished loading: GET “”.
                      mumblebajM S 2 Replies Last reply Reply Quote 0
                        @sdetweil I tried to manual run the MMM-Carousel.js but returned the following. 20bc915c-97a4-40af-9e49-7932576b932b-image.png MMM-c93303dc-dee4-475f-9a04-d0f51fd8b8f2-image.png
                        • 10
                        • 3 / 10
