    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 71.0k Views 4 Watching
      pastormingle @mumblebaj
      @mumblebaj said in MMM-Carousel not displaying:
      npm install
      not a silly question as it’s not in the install readme file…
      Installation
      Run these commands at the root of your magic mirror install.
      cd modules
      git clone https://github.com/shbatm/MMM-Carousel
      Using the module
      To use this module, add the following configuration block to the modules array in the config/config.js file:
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @pastormingle
        @pastormingle doesn’t have a node helper, so doesn’t need an npm install
        • mumblebajM Offline
          mumblebaj Module Developer @pastormingle
          @pastormingle Yes, you have to run nom install in the module folder. I saw that the module has a package.json with dependencies. I just installed it on my machine and it works. One thing to note, it only rotates modules that occupying the same position on the mirror. I have 2 modules that occupy the top_right position and those are rotating and the others remain unchanged when using the global config option.
            @sdetweil Hi Sam, For my understanding. What about dependencies in the package.json? If those are not default with MM then you have to run npm install I would think? Or is my understanding incorrect?
              @mumblebaj do you have an example of your config?
              P mumblebajM 2 Replies Last reply Reply Quote 0
                pastormingle @pastormingle
                @pastormingle I sent my weather module to use the same as the clock position but still nothing…
                  @pastormingle I used one of the default.
                              module: 'MMM-Carousel',
                                  transitionInterval: 10000,
                                  ignoreModules: [],
                                  mode: 'positional',
                                  top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000},
                                  top_right: {enabled: true, ignoreModules: ['currentweather']}
                  Just tested the Global option and it works fine and rotates all the modules one by one.
                  Here is the config for global
                                  ignoreModules: ['clock'],
                                  mode: 'global'
                    @mumblebaj hum… this is my config…
                     * By Michael Teeuw https://michaelteeuw.nl
                     * MIT Licensed.
                     * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                     * and https://docs.magicmirror.builders/modules/configuration.html
                    let config = {
                    	address: "localhost", 	// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                    	language: "en",
                    	locale: "en-US",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "weather",
                    				type: "current",
                    				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				apiKey: "YOUR_OPENWEATHER_API_KEY"
                    			module: "weather",
                    			header: "Weather Forecast",
                    				type: "forecast",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                                    ignoreModules: [],
                                    mode: 'global'
                    mumblebajM S 2 Replies Last reply Reply Quote 0
                      @pastormingle Are there any errors where you start the mirror? I.e. if you do npm start are there any errors in the terminal window or if you use pm2 you can check the pm2 logs. You can also check the Developer Console, do shift_ctrl + i and select the console tab. See if there are any errors there. If no errors you should see something like the below, modules suspended…module resumed
                      P 2 Replies Last reply Reply Quote 0
                        @pastormingle please use code block around config info
                            pastormingle @sdetweil
                            @sdetweil not sure what that means?
                              @pastormingle That means that something is already running with that IP. Do you only have 1 instance of MM running?
                                @mumblebaj The IP conflict is due to me ssh into the pi and starting magic mirror… I am referring to the commits from sdetweil that said “please use code block around config info” So still not working… But it looks like the carousel module is working…
                                  @pastormingle What Sam was saying was the when posting your config, you need to set it in a code block. That is done by selecting the config you posted and then pressing the </> button at the top of the window. That would wrap the config in a code block and make it look “pretty”.
                                  I am glad your Carousel is now working.
                                  P S 2 Replies Last reply Reply Quote 0
                                    @mumblebaj sorry mumblebaj that was a typo it’s not working… Any other suggestions?
                                      @mumblebaj
                                      /* Magic Mirror Config Sample
                                      * MIT Licensed.
                                      let config = {
                                         port: 8080,
                                         language: "en",
                                         locale: "en-US",
                                         timeFormat: 24,
                                         units: "metric",
                                         		module: "alert",
                                         		position: "top_bar"
                                         		module: "clock",
                                         		module: "newsfeed",
                                         			feeds: [
                                                     transitionInterval: 1000,
                                                     ignoreModules: [],
                                                     mode: 'global'
                                        @pastormingle As mentioned previously, are the any errors in the developers window? Do you have any errors in the terminal window? I am using the exact same config as you for Carousel and it work just fine for me
                                          sdetweil @mumblebaj
                                          not pretty, just more readable
                                            sdetweil @mumblebaj
                                            @mumblebaj yes, generally, w package.json you would need an npm install. but in this case, the dependencies after for testing not running
                                            • 2 / 5
